Making a wooden tripod for my classic telescopes.
110 replies to this topic
#101 Garyth64
Garyth64
  • Loc: SE Michigan
Posted 16 September 2020 - 08:11 PM
Well, I can add more:
I believe I posted this next tripod before in its own thread.  After the Maple and Poplar tripods, I made an Oak tripod.
I had a large piece of Oak that was 1-3/8" thick and 56" long.  I cut 6 pieces, each 7/8".  I varied from my first two tripods, and made this one like a crutch.  I still used a solid eyepiece tray.
This tripod was used with an old Edmund mount.
It was easier to make than the first two.
Edited by Garyth64, 16 September 2020 - 08:45 PM.
  • Pete W, Marc-Andre, Terra Nova and 4 others like this
#102 Garyth64
Garyth64
  • Loc: SE Michigan
Posted 16 September 2020 - 08:22 PM
Recently, I showed a picture of my Meade 395 on an old Meade Starfinder mount.
That Oak tripod was used for this setup.
Edited by Garyth64, 16 September 2020 - 09:25 PM.
#103 Terra Nova
Terra Nova
  • Loc: Northern Kentucky
Posted 16 September 2020 - 08:25 PM
Beautiful tripods Gary!
  • Garyth64 likes this
#104 Garyth64
Garyth64
  • Loc: SE Michigan
Posted 16 September 2020 - 08:26 PM
Liking the crutch style that I had made, I decided a needed a better tripod for my 7TE-5 mount.  So I made a 4th tripod.
This one is also out of Oak.  6 sections, 3/4" x 1-1/2" x 60".
I like all these designs like mine and many others.  They provide a very stable platform.
  • Pete W, Marc-Andre, Terra Nova and 3 others like this
#105 Defenderslideguitar
Defenderslideguitar
  • Loc: Connecticut
Posted 16 September 2020 - 08:39 PM
Gary
 Love the crutch style tripod   very nice tripods
    nice tapering     it is tapered right?
     How do the tray supports meet under the tray or do they?
#106 Garyth64
Garyth64
  • Loc: SE Michigan
Posted 16 September 2020 - 09:01 PM
The crutch is tapered only because it is joined together at the bottom with a bolt,  then spreads out for the eyepiece tray, and then a little more when it meets the hub.
I like the crutch-style too.
If you look back to #57 you can see the bottom of  an eyepiece tray.  Those 3 sections of wood stick thru the tripod legs.
On my first two mounts, the tray rested on a lower section of the tripod.  There is a bolt to hold it firmly in place.
In the crutch-style tripods, the tray rests on a bolt that goes thru the two sections of a leg.  A bolt can be tightened to secure the tray.  There is also a lot of tension there, and if not careful, it can bite a finger or two. (ask me how I know that lol.gif )
Now with these 4 wood tripods that can carry most of my scopes, I no longer use the 3 steel piers that I have.  They are just in the way in the garage, and I will probably sell them off.  (hint, hint, hint)
Edited by Garyth64, 16 September 2020 - 09:06 PM.
  • Defenderslideguitar likes this
#107 Pete W
Pete W
  • Loc: Hutto, TX
Posted 16 September 2020 - 09:37 PM
Great reboot, Barry.  I’m still thinkin’ about a tripod for the Sears refractor.  I really like Walter A’s design with a slit in the adjustable leg and bicycle skewers:
Perhaps when things cool down here...too sweaty to work in the garage right now.
  • Terra Nova, PawPaw, Bomber Bob and 3 others like this
#108 walter a
walter a
  • Loc: Prawda Manitoba Canada
Posted 17 September 2020 - 05:02 AM
Thanks Pete but I cant take credit for the slit design as I copied it from a mizar tripod. Btw those slits are a pita to cut if you dont have the right length router bit.
Edited by walter a, 17 September 2020 - 05:04 AM.
  • Pete W, PawPaw and Defenderslideguitar like this
#109 Senex Bibax
Senex Bibax
  • Loc: Ottawa, ON
Posted 17 September 2020 - 08:18 AM
I might need to try something like this for my latest acquisition. The tripod legs are severely warped. After stripping them, I soaked them in hot water then left them to dry clamped flat but it only helped a little.
#110 Pete W
Pete W
  • Loc: Hutto, TX
Posted 17 September 2020 - 05:51 PM
Walter, I don't have the tools to cut an accurate slit, so I was planning to make the leg out of three pieces of lumber, two 1/2" or 3/4" boards fastened together with a 1/4" board in-between as a top and bottom spacer to form the gap.
#111 walter a
walter a
Posted 18 September 2020 - 06:51 AM
Pete that should work nicely.
