What software do you use for your all-sky camera?
23 replies to this topic
#1 Lord Beowulf
Lord Beowulf
    Vendor - Orion Ranch Observatory
  • Loc: Cedar Park, TX
Posted 26 August 2017 - 12:14 AM
Hi All,
This topic is primarily directed to those who've made their own all-sky camera and are automating capture and/or upload to a website from their camera.  I'm tired of the rather poor performance and low resolution of the standard NTSC camera I'm using currently.  Given it feeds into my security DVR that uses their own proprietary format, I've never made any progress in getting it to a point where I could capture or upload from it to my website.  With the sale ZWO was running on some of their new cameras, I decided to spring for an ASI290MC camera that comes with a wide angle lens suitable for all-sky photography.  I was originally going to go for the ASI120MC, but since the 290 had a higher resolution and a wider field lens, I decided to go for the upgrade.  Unfortunately the USB 3.0 interface means the Cat 6 cable I have running up to the camera location won't work for an extender, and the scheme published elsewhere for using a Raspberry Pi doesn't give me USB 3.0 either.  I decided to go for an ASUS PC stick that had USB 3 and will support running the various PC based capture software, but I'm not seeing anything really designed for full unattended automation.  Thus my question as to what others are using.
Of course this is all assuming that I'll be able to get a good enough Wi-Fi connection to the PC stick with the metal roof in the way.  I should have bought one with an Ethernet port, but didn't realize I'd missed that at the time.  Finding USB 3.0 was hard enough.
Beo
#2 HomerPepsi
HomerPepsi
  • Loc: Canada
Posted 26 August 2017 - 01:58 AM
Sharp Cap plus images that save to a folder in my google drive desktop folder. These folders are synced with google drive and I can view them as soon as they are sync'd (a few seconds after sharp cap down loads the image). Ghetto, but it works. Something with image compression would save more bandwidth though.
#3 Lord Beowulf
Lord Beowulf
Posted 26 August 2017 - 08:39 AM
Is there a way to get Sharp Cap up and running automatically?
Beo
#4 roelb  Happy Birthday!
roelb
  • Loc: Belgium, Antwerp
Posted 26 August 2017 - 08:45 AM
SharpCap scripts?
#5 StarmanDan
StarmanDan
  • Loc: Where the stars at night are big and bright...
Posted 28 August 2017 - 08:48 AM
I use a program called UFO Capture.  It's pricey, but is very capable.  With a second all sky camera linked to it at a distant location, it can calculate meteor orbits.
http://sonotaco.com/e_index.html
You can see my prototype setup here:
https://www.cloudyni...cam-for-my-obs/
  • mclewis1 likes this
#6 Raginar
Raginar
  • Loc: Pensacola, FL
Posted 28 August 2017 - 04:24 PM
https://store3.esell...PageCatalog.htm
I love my all sky cam but it's not made any more.  The software is really awesome; I'd highly recommend it.
Chris
  • Mark Bailey likes this
#7 SonnyE
SonnyE
  • Loc: Cali for ni a
Posted 30 August 2017 - 10:36 AM
Hi!
I have a suggestion for a possible different tact for you.
I belong to Weatherbug.com I feed my weather station up to the web.
But there are often folks with weather cams, and probably in your area.
This link takes you to Wearthbugs cameras in my area. But if you enter your zip code in the upper right area, you may find some great local coverage.
These are usually public feeds and free.
https://weather.weat...weather-camera/
  • Raginar likes this
#8 Lord Beowulf
Lord Beowulf
Posted 07 September 2017 - 08:34 PM
Thanks for the suggestions.  I looked at those and found that neither was quite as versatile for my current needs as what I found from another thread online.  There's a program called iSpy Connect that's pretty powerful (and free!).  Unfortunately, it appears that ZWO hasn't tested/updated their DirectShow drivers for the ASI290MC I bought, and it has a problem that crashed both iSpy and the MoonGlow software.  It may crash the others too, but I haven't tested enough.  At any rate, now I'm just hoping they'll fix it soon.
Sonny, I'm not looking for an alternative to an all-sky camera, I want to control the camera I have and post the data on my website, etc.  I appreciate the suggestion, but it's off-topic.
Beo
#9 Raginar
Raginar
Posted 09 September 2017 - 11:27 AM
There's a ton of direct show programs. Go in the EAA forum and start looking.
#10 Lord Beowulf
Lord Beowulf
Posted 09 September 2017 - 09:50 PM
It doesn't matter how many programs I use if the driver for the camera doesn't work.
Beo
#11 iwannabswiss
iwannabswiss
  • Loc: Somewhere in Space
Posted 10 September 2017 - 08:48 PM
Here's an idea using a Raspberry Pi, if you're willing to do a little work.  I've thought about making something like this, but using a different camera.  We'll see, but may end up going this route myself.   http://www.instructa...All-Sky-Camera/
#12 Lord Beowulf
Lord Beowulf
Posted 11 September 2017 - 12:17 PM
I started my original investigation looking at that (and most other items available from a Google search), but Raspberry Pi doesn't support USB 3.0.  I went a different route and am building around a stick PC.  A bit more expensive, but running full Windows, which gives me a wide array of possibilities.  I just need the driver for the camera to work reliably!  Or to find something with the capabilities of  iSpy that uses the native driver or ASCOM instead of the DirectShow driver and ideally for the same price!  (free)  grin.gif  I don't really have the spare time to waste with scripting (and the yearly cost for the option) in SharpCap or writing something at the API level.  I'm waiting for ZWO to confirm they intend to fix their driver for this camera or I need to send it back and look for another alternative.
Beo
#13 iwannabswiss
iwannabswiss
Posted 11 September 2017 - 09:46 PM
Beo
Sorry, I didn't realize you said that in your first post.  I guess being sick is just as bad as drinking and replying.
I look forward to your build and see what you create.
#14 50N8O
50N8O
Posted 12 September 2017 - 01:39 PM
I use a Starlight Xpress Oculus with a software from Michael Poelzl called AllSkEye. Works great!
Recently he created a version that works with cameras with Ascom drivers.
There are two Yahoo groups where you find more information.
Friedhelm
#15 Raginar
Raginar
Posted 12 September 2017 - 07:10 PM
Sounds like you have the wrong tool for the job.
#16 Lord Beowulf
Lord Beowulf
Posted 18 September 2017 - 12:03 AM
Friedhelm
Thanks for the suggestion.  That does seem to be working reasonably well with the ASCOM driver, but unfortunately it appears to only treat the images as B&W.  I don't see any option for color output.  It also appears to be a bit more manual than I'd hoped for.  I'm not giving up on it yet, but it's just not a perfect fit.  Still, might get me started.
Beo
  • iwols likes this
#17 iwols
iwols
  • Loc: doncaster uk
Posted 14 August 2021 - 09:45 AM
i know its an old threa
Beo
d but did you find anything?
#18 EmeraldHills
EmeraldHills
  • Loc: Louisville, Kentucky
Posted 14 August 2021 - 12:19 PM
I'm just now considering this as well. I'm curious: Could we start a second instance of Sharpcap for this purpose?
#19 StarmanDan
StarmanDan
Posted 14 August 2021 - 04:29 PM
Beo
I had the same B&W issue with my zwo120 when I first started using AllSkyEye. The fix is to change the default Bayer pattern in the settings for ASE. Not at my computer atm so cant walk ya through it. But that fixed the issue for me.
#20 outofdark
outofdark
  • Loc: SLC
Posted 14 August 2021 - 11:06 PM
Reading. The spec on the pi4 shows support for 2 usb3.0 ports
https://www.raspberr...specifications/
2 USB 3.0 ports; 2 USB 2.0 ports.
Beo
#21 Tiago Ferreira
Tiago Ferreira
  • Loc: Algarve - Portugal
Posted 15 August 2021 - 03:27 PM
Yes Doug. And it works fine!
Please don't forget to consider an allsky space in your future observatory ;)
  • EmeraldHills likes this
#22 EmeraldHills
EmeraldHills
Posted 15 August 2021 - 07:31 PM
I'll do it, Tiago!
Please don't forget to consider an allsky space in your future observatory wink.gif
  • Tiago Ferreira likes this
#23 Lord Beowulf
Lord Beowulf
Posted 23 September 2021 - 07:43 AM
Hi iwols,
Actually I worked with Michael Poelzl debugging AllSkEye for quite a while and he made great strides on it.  He got it working quite well and while I know he's made more updates that I haven't upgraded to as I haven't had time to mess with it in a long time, I'd highly recommend it.
FYI, here's a thread on the build of my all-sky camera, and here's the link from my website with more detail.
Beo
Edited by Lord Beowulf, 23 September 2021 - 07:46 AM.
#24 Viventius
Viventius
  • Loc: Saint Charles, MO
Posted 24 September 2021 - 06:15 AM
I have been running Thomas Jacquin AllSky for close to 5 months now. It is running 24/7 outside and I have an sftp to my website where you can see the images taken every 10sec or so, startrails, keograms and timelapse. Running this to eventually add onto a RoR and help with automation. I like Thomas Jacquin AllSky because I can run it 100% remotely.
I had run Michael Poelzl AllSkeye for a little while but that one seems to be better if you are connected to a computer via ethernet. If you run PoE or are connected straight into a computer then AllSkeye is a good one to go with. If you arent Thomas Jacquin is pretty solid. Still, AllSkeye is a great software and awesome interface but wasn't a good fit for me and my needs.
Link to my AllSky - https://www.photonpup.com/allsky/
Link to my build - https://www.photonpu...y-allsky-build/
Link to programming - https://www.photonpu...tware-onto-pi4/
  • xthestreams likes this
