45 or 90 degree 100mm binoculars ?
21 replies to this topic
#1 kcb
kcb
Posted 04 September 2017 - 12:11 AM
hi,
thinking of purchasing 100mm binoculars by altairastro, they have two models, one is 45 degree angle, one is 90 degree angle, which is the better angle for stargazing ,any preference ? thanks, kevin
#2 SMark
SMark
Posted 04 September 2017 - 12:19 AM
I have 90° and wouldn't have it any other way. The best views are at zenith anyway, so why not make it more comfortable to actually view that way? Not that 45° would be impossible, as that certainly isn't the case. But I love my 90° APM, and when I move up to something larger, it will also be 90°. like-button.jpg
#3 rockethead26
rockethead26
Posted 04 September 2017 - 12:38 AM
45° if you want to use them both for astro and daytime use. 90° for astro only. My APM 100's are 90° just like SMark.
#4 Astro Boy
Astro Boy
Posted 04 September 2017 - 01:04 AM
Another vote for 90s the 45s are a pain in the neck ( literally ) when viewing at high altitudes
#5 PETER DREW
PETER DREW
Posted 04 September 2017 - 03:48 AM
It's very much a personal preference decision. I would always go for 90 degrees regardless as I find 90 degree viewing terrestrially is still more comfortable than 45 degrees for astronomy.
#6 Jon Isaacs
Posted 04 September 2017 - 08:23 AM
As far a comfort goes, 90 degrees is fine for terrestrial viewing.  For astronomy, 45 degrees is a pain in the neck...
#7 Allan Wade
Allan Wade
Posted 04 September 2017 - 08:29 AM
My experience is also that the 45 degree models become very painful, very quick for astro use. 90 degree is the way to go for astro observing.
#8 paulsky
paulsky
Posted 04 September 2017 - 09:46 AM
Hello,
Long time used a giant of 100mm Miyauchi of 45º and from a certain altitude was very annoying and complicated to observe, for terrestrial very well .. but for astro ... mmmm !!
Paul
#9 Rich V.
Rich V.
Posted 04 September 2017 - 10:27 AM
The fact is, many of us that currently have 45° BTs would have gladly purchased 90° models if they had been available at the time.  45° viewing was a way better alternative than straight-through designs at the time, so what was there to do?
Unfortunately, a number of the early 90° models had diminished effective aperture and prism cutoff/vignette.  It was really only lately after APM came out with 90° versions of their BTs that we've had a choice.  I'm sure if they offered the 90° models originally, there would be far fewer 45° BTs out there now.
Rich
#10 tropical
tropical
Posted 04 September 2017 - 11:28 AM
No way I will buy a 45 deg BT binoculars.  Been there done that and it  was a painful experience. grin.gif
#11 Mr. Bill
Mr. Bill
Posted 04 September 2017 - 12:01 PM
What helps when using 45 oculars is a tripod with elevation crank....I can easily get to 80 degrees.
OTOH, IF I buy the APM 82mm, it would be 90 degrees.
#12 junomike
junomike
Posted 04 September 2017 - 01:02 PM
Although I'd probably prefer the 90° I'm ok with the 45's as It allows me to view Zenith while only needing to look up at a 45° angle.
As Bill says, a Tripod with elevation cranks works wonderfully.  I use a Manfrotto 3251.
#13 Mike Harvey
Mike Harvey
Posted 05 September 2017 - 02:06 AM
I bought the APM 100's with 45 degree prisms.
When I "moved up" to the 120's I bought the 90 degree model.
Even though I did (and do) have a cranking adjustable center post
(Manfrotto 161Bmk2), the 90 has proven much more comfortable and user-friendly.
#14 lulz
lulz
Posted 05 September 2017 - 04:14 AM
As I will probably have the same dilemma, come spring 2018, can anyone post a short video or some photos how it is to view with 90* BTs for daytime use?
#15 edwincjones
edwincjones
    Close Enough
Posted 05 September 2017 - 08:31 AM
Hello,
Paul
45*
 I have never understood the interest in 90*
Both are difficult >75*
edj
#16 Jon Isaacs
Posted 05 September 2017 - 11:23 AM
Hello,
Paul
45*
edj
Realistically, 90 degree focusers at 90 degrees are like 45 degree focusers at 45 degrees..
:shrug:
#17 Mr. Bill
Mr. Bill
Posted 05 September 2017 - 12:12 PM
No matter which you use, you have to deal with "Dobson's hole" while using an alti azimuth mount near zenith.
Edited by Mr. Bill, 05 September 2017 - 01:33 PM.
#18 Gordon Rayner
Gordon Rayner
Posted 05 September 2017 - 07:46 PM
Unless the azimuth axis can be tilted, thus moving the azimuth axis  such that is points somewhere   other than the Zenith.   Pivoting backward below the azimuth bearing, or  by  shortening one or two tripod  legs.   Caution to  keep the center of mass of the binoc- mount -tripod    away from the limit at which a fallover is impending.
A safety rope could be tied to a   stake, a wall , an automobile bumper, etc.
Edited by Gordon Rayner, 05 September 2017 - 07:48 PM.
#19 eklf
eklf
Posted 05 September 2017 - 09:04 PM
I was never comfortable with 45* for night use, although for terrestrial use it was quite enjoyable.
Even with a tripod equipped with a crankable elevetor post I found them uncomfortabe to look though at any elevataion above 45 deg.
#20 GamesForOne
GamesForOne
Posted 05 September 2017 - 10:37 PM
The key for comfort for me with the 45 degree model is to have a tripod high enough that I can either stand or sit between extended legs to get under the binocular. This is fairly comfortable to me for 60 to 85 degrees elevation.
The problems I have with 90 degree models are:
1) I have to lean over to look through them for low elevation (e.g. Sco/Sag in the summer or Mon/Canis Major in the winter) targets and I spend a lot of time looking at such targets, and
2) when pointed vertically it is difficult to look through a zero power finder. It's like trying to crane your neck with a zero power finder on a dob pointed straight up. The position underneath the bino that I describe above with the 45 degree model is more conducive to finder use.
Michael Mc
#21 Keith g
Keith g
Posted 06 September 2017 - 05:32 AM
I have the 90 degree APM120's, I wouldn't have it any other way for astro. I find this angle is very comfortable.
K
#22 edwincjones
edwincjones
    Close Enough
Posted 06 September 2017 - 06:17 AM
always a difficult place to be
edj
