Budget high power EP for 12" f/5
32 replies to this topic
#1 drneilmb
drneilmb
  • Loc: Decorah, IA, USA
Posted 13 September 2017 - 11:06 PM
I am making progress on a 12" f/5 reflector build, and I'm ready to consider the impact on my eyepiece needs. I bought a 2-inch 32mm Agena SWA for the low-power end, and with my current scopes (4.5f8, 8f6) I am content with a GSO 32mm plossl and Celestron 8-24mm zoom.
With the larger exit pupils from the f/5, I'm interested in another eyepiece around 5mm focal length to give 300x and 1mm exit pupil. In case you couldn't tell from my other eyepiece choices, I have limited funds and would like to keep the budget comfortably under $100.
Some possibilities I've looked at are
BST 5mm UWA which they swear isn't a TMB clone: http://agenaastro.co...epiece-5mm.html
Agena Starguider Dual ED 5mm: http://agenaastro.co...epiece-5mm.html
And the Celestron X-cel LX 5mm (the one for sale here on CN got me started thinking about this): http://agenaastro.co...iece-93421.html
What inexpensive eyepieces would you suggest around 5mm for a 300/1500 reflector?
Thanks in advance for any suggestions you can offer.
-Neil
  • aeajr likes this
#2 havasman
havasman
  • Loc: Dallas, Texas
Posted 13 September 2017 - 11:43 PM
I think those Agena Starguider Dual ED eyepieces are really nice. They're better in longer focal ratios but that will likely be true of all your chosen options. Given that potential relatively minor qualification, they are quite nice.
#3 Usquebae
Usquebae
  • Loc: 43° N, 73° W
Posted 14 September 2017 - 01:24 AM
The Sky-Watcher brand version of the 5mm BST ships with their very popular refractors.  There are probably a lot of them lying around unused.  Maybe trying posting a want add for $35.  I like mine.  That said, one of the best bargains out there is the 5.5mm Meade UWA.  The extra FoV comes in handy at high powers on a manual dob.
  • izar187 likes this
#4 Ernest_SPB
Ernest_SPB
  • Loc: St.-Petersburg, Russia
Posted 14 September 2017 - 01:40 AM
Consider 4.5 mm HD60/Meade and 4 mm NLV/Vixen
I use on the same scope 4.7 mm from 82° Explore Scientific and quite happy with it
Edited by Ernest_SPB, 14 September 2017 - 01:41 AM.
#5 sec4aa
sec4aa
  • Loc: Long Island, NY
Posted 14 September 2017 - 07:43 AM
5.5mm Meade UWA is probably the best deal around 100...
  • REC and NOLAMusEd like this
#6 aeajr
aeajr
  • Loc: Long Island, New York, USA
Posted 15 September 2017 - 04:50 PM
Why not just barlow the Celestron 8-24 zoom?    I do.
#7 tony_spina
tony_spina
  • Loc: So. Cal.
Posted 15 September 2017 - 05:11 PM
I agree.  Check Amazon. It usually sells for $109. Great eyepiece!  82 degree field of helps when you have a manual mount with no tracking to keep the object longer in view before nudging the scope
#8 NOLAMusEd
NOLAMusEd
  • Loc: Louisiana
Posted 15 September 2017 - 05:13 PM
+1 on the Meade 5.5 UWA
#9 aeajr
aeajr
Posted 15 September 2017 - 05:30 PM
I also have the Meade UWA 5.5 and like it very much.
I have the Meade HD60 but have not been particularly pleased with it.
Edited by aeajr, 15 September 2017 - 05:32 PM.
#10 vtornado
vtornado
  • Loc: Northern Illinois
Posted 15 September 2017 - 09:46 PM
Do you have a 2x barlow?
If so, or not even if so, I would get a good 10mm plossl and a reasonable barlow.
I do lots of planet and lunar viewing at high power.  This combo gives me the most detailed view.
This is in my 10 inch f/5 dob.
#11 aeajr
aeajr
Posted 15 September 2017 - 10:40 PM
-Neil
Sometimes I need to go back to the original question and ask why.
Each of the eyepieces you have listed have fairly good reputations at their price points. In an F5 scope they are not going to be as good around the edges as say an Explore Scientific 68 degree but they should work.  I don't own any of them but you would probably do fine with any of them.
However, I have to wonder why you are buying an eyepiece for 300X.  That seems an odd priority magnification to focus upon. If you are like so many here on CN, you will spend most of your time topped out below 250X based on limitations imposed by seeing and transparency.  I have a 4.5 mm eyepiece, 266X that is rarely ever used.  I don't even list it as an active eyepiece.   I barlow my zoom for high power so I can tune in for the best mag that night.
If you are a budget minded person, a 2X barlow would be my suggested next purchase, not an eyepiece for 300X  that is likely to be rarely used.    Your zoom, with a 2X barlow will take you to 375X.     You can get a 2X barlow for $35 o $60 that will work well with your zoom.  GSO, Antares barlows have good reputations. I have a 2" GSO barlow so I can barlow my two 2" eyepieces as well as my 1.25 eyepieces and my zooms.
http://agenaastro.co...-extenders.html
Using the zoom in the barlow you can learn what you typical useable high power will be. Then you can start to fill in with eyepieces that will give you the best views at magnifications that you will use often.
Is FOV a concern?  At 300X that zoom eyepiece will be operating at about 50 to 52 degrees, similar to a Plossl.  The eyepieces you are looking at are only 58 to 60 degrees, not that much wider.  So you are not gaining that much FOV over the zoom.
So, why 300X?  I am just curious.
Edited by aeajr, 16 September 2017 - 01:48 PM.
#12 Tank
Tank
  • Loc: Stoney Creek, Ontario, CANADA
Posted 16 September 2017 - 05:30 AM
5.5 meade UWA
or
4.7 ES 82
  • george tatsis likes this
#13 russell23
russell23
  • Loc: Upstate NY
Posted 16 September 2017 - 06:00 AM
The 5.5mm Meade UWA is excellent.  That was my first thought.
But the 5mm BST is also good - just doesn't have the wide FOV for high magnification manual tracking.
#14 Jon Isaacs
Posted 16 September 2017 - 08:05 AM
I read, "comfortably under $100."
So what qualifies?
- A 2x Barlow for the Celestron zoom.  Probably a workable combination though I suspect the Celestron zoom loses something at F/5. A decent 2x Barlow is something everyone ought to have.
- The BST is reputely very similar in performance to the TMB Planetary series.  They're reasonable performers at F/5. I have a set of the TMBs, they're not T-6 Naglers but they do a good job and I often use them in my 10 inch F/5 instead of the T-6, they don't give up that much.
- I don't know about the Starguiders and such, there's others out there.
- 300x, in Iowa there's probably not a lot of nights when 300x is useful for planetary but in a 12 inch, it's a 1mm exit pupil and that's useful for DSOs even if the seeing is so-so.
  • aeajr likes this
#15 csrlice12
csrlice12
  • Loc: Denver, CO
Posted 16 September 2017 - 12:18 PM
Maybe a used 4.8T1 Nagler.  Tight eye relief, but nice views...it's also a small eyepiece, so no size/weight problem.  Probably find a used one for $100ish.
#16 REC
REC
  • Loc: NC
Posted 16 September 2017 - 01:14 PM
-Neil
I had the Dual ED 5mm, nice eyepiece, but sold it as I could hardly ever use it....too much power in my scopes. You really need some good skies and good seeing conditions to support that much power. That would be around 300x in that 12" scope?
#17 sec4aa
sec4aa
Posted 16 September 2017 - 02:30 PM
You can gather a lot of light on a 12" reflector but the /f5 will make it hard on EPs. You can definitely get down to 1mm for the exit pupil and that will work on DSO and sometimes on the planets (seeing conditions, jetstream, transparency, etc).
Yes, you can barlow 2x down from a very good plossl...I do that sometimes with my 10.5mm TV smoothie.
I cannot do the same with my 12mm Paradigm  without having some problems. The 12mm Paradigm gives me the magic 2mm exit pupil and the EP is great on its own, but I don't like it barlowed. I do barlow a lot with my ES 68 16mm down to 8mm and it looks great...as you can see it is a mixed bag.
The Meade 5k UWA 5.5mm is my favorite high power but the Jetstream interfere 50% of the time and the views of Saturn won't always calm down...then I switch to globular clusters.
  • aeajr likes this
#18 Mike W.
Mike W.
  • Loc: Washington State
Posted 17 September 2017 - 06:25 AM
under a $100,,,,,, I see very often on the classifieds here ES 4.7 & 6.7 82°for $110.
or double your budget and get a Williams Optics 5mm100°
#19 Syzlak817
Syzlak817
  • Loc: Mid-Michigan
Posted 17 September 2017 - 11:03 AM
Another vote for the 5.5mm Meade UWA.  When your seeing allows it use, the extra FOV is nice to have on a manually tracking scope.
Not to mention its extremely comfortable to use unlike most budget and for that matter many premium eyepieces.
  • aeajr likes this
#20 drneilmb
drneilmb
Posted 17 September 2017 - 10:54 PM
Thanks everyone for the suggestions. I'll think about the Nagler or ES82 if it's worth it, but I agree with everyone that I'll rarely be using 300x in Iowa, so it's hard to justify too much spending on a rarely used item.
Ed, I haven't had a great experience  with the Celestron zoom barlowed, especially at the highest magnifications. I have a 2x barlow (an old Criterion) although I haven't been as successful as I hoped with it. It's possible that my homemade scopes don't have enough in-focus to get there with the barlowed zoom. It's also possible that I need to check my collimation more rigorously.
The reason for 300x was to have something at a 1mm exit pupil, which for me has been my practical lower limit. I know some people say 50x per inch but I'm more comfortable with 25x per inch = 1mm exit pupil = magnification equal to aperture in mm [magnification = FL/epFL = D*f/epFL = D/(exit pupil)]
As I build this bigger, faster scope, I have an interest in being able to access its full capabilities, even if they are only rarely used in observing. It's also my impression that high magnifications around 1mm exit pupil are necessary for seeing the diffraction rings used in star testing (but I might be wrong, I don't know that I've ever been able to see diffraction rings yet).
  • aeajr likes this
#21 aeajr
aeajr
Posted 18 September 2017 - 02:33 AM
If you have the Celestron zoom and the barlow then you have what I was suggesting.   Clearly the next step is to go to single FL eyepieces or to upgrade the zoom.   .
The Celestron was good and useful but I did find I wanted better high power options.  So I accumulated 2 ES 82s, 8.8 and 6.7  and the Meade 5000 82 5.5 and the Meade HD60 4.5.
Now that I have the Baader zoom, I rarely go to them anymore.   I like the Baader Zoom a lot.  It is better and wider than the Celestron.  And in my 2" GSO barlow it works very well.   I also barlow my 2" eyepieces from time to time.
That is just my experience.   Clearly you may prefer the single FL eyepiece approach.  The joy is we have choices.
#22 drneilmb
drneilmb
Posted 22 September 2017 - 02:32 PM
Thanks to everyone in this thread, I'm reconsidering my high power options. I got to do lots of thinking about the balance between exit pupil, magnification, AFOV, TFOV, and cost. I think now that a 1mm exit pupil might be optimal in some sense but isn't a realistic magnification for blowing a chunk of my eyepiece budget.  Instead, I'm starting to think in terms of low, medium and high magnification fixed focal length eyepieces (I have a Celestron 8-24mm zoom already). Again, the scope is a f/5 (D=300 F=1500) homemade truss dob with a 2-inch focuser.
For the low power I think I'm covered, with a 24mm ES68 at 63x, 1.1 deg TFOV, 4.8mm exit pupil (great deal used, just arrived, hallelujah!), 32mm Agena SWA for largest exit pupil 47x, 1.5 deg TFOV, 6.5mm exit pupil, and a GSO 32mm Plossl (could say goodbye to this one now?).
For the medium power, I am looking for something around 2-3mm exit pupil, 100-150x, so 10-15 mm FL. There are the 60 degree Paradigms and clones at 12mm (125x, .48 deg, 2.4mm) and 15mm (100x, .6 deg, 3mm) and the X-Cel LX and HD-60 at 12mm. (Honorable mention to the 14mm ES62 (107x, .6 deg, 2.8mm) on sale now for only $80).
For high power, I think I might just punt to the 8mm end of the Celestron zoom or my existing 2x Criterion barlow. If I was going to get another eyepiece, I was thinking about a 7-8mm FL for around 200x. If the seeing in Iowa ever gets better than that, I can always use a Barlow :)
Thanks again to all of you denizens of the Eyepieces forum. I know you love to talk about your solid-gold Ethos and Naglers, but you did a wonderful job making suggestions and getting me thinking about my overall setup with more modest eyepieces.
-Neil
#23 aeajr
aeajr
Posted 22 September 2017 - 02:55 PM
Sounds like a good plan.
Here are the FOV measurements for your Celestron zoom, as tested in this report
https://www.cloudyni...-zoom-eyepiece/
Celestron Zoom:
24mm = 39°
18mm (next setting) = 47°
15mm (half-step) = 50°
12mm (next setting) = 54°
10mm = (half-step) = 59°
8mm = 63°
The FOV is pretty good below 10 mm.
#24 drneilmb
drneilmb
Posted 22 September 2017 - 04:17 PM
Celestron Zoom:
24mm = 39°
8mm = 63°
With some more time with the Celestron zoom and my 2x barlow last night and the help of a comment I saw somewhere in a review on CN, I think that I just got a less-than-perfect specimen.
Up against the stop at 8mm, the best focus is still quite blurry. I'm able to see it come into focus and go out of focus as I rack back and forth, but the best spot in the middle doesn't have sharp stars. I usually end up backing off the zoom a small amount to a lower magnification and then I get back to a sharper focus. In my particular case, the large AFOV in the last half-step of the magnification range is not terribly useful. Highly variable QC helps me reconcile some of the widely divergent opinions I've seen on the Celestron zoom.
I've been quite bullish on the Celestron zoom up to now, but now I either have reservations or just a sense of "you get what you pay for". I'm looking in the $60-90 per eyepiece range right now, so it's hard to justify the upgrade to the Baader zoom when I could just get a 12mm and 8mm Dual ED for less than half what the Baader zoom costs, and the Baader's FOV doesn't get over 60 degrees until the 12mm mark anyways. If I think of the Baader as replacing 4 eyepieces I can see where the economics work out, but if it's replacing 2 at the shorter FL end, then I don't see the same value.
#25 aeajr
aeajr
Posted 22 September 2017 - 04:49 PM
I certainly would not put the $65 Celestron zoom up against higher priced single FL eyepieces.   I compare it to my Plossls.  But I don't have a focus issue anywhere along the range of the Celestron.
The BHZ I compare to my ES eyepieces in terms of quality of image.  But you might not agree.
Just because I like the zooms doesn't mean anyone else has to like them.  We all have to decide what works best for us.
