M1 - Crab - SHO - Edge 11
12 replies to this topic
#1 anismo
anismo
  • Loc: Austin, TX, USA
Posted 13 September 2017 - 11:50 PM
I have been trying to post in CCD imaging forum but there is not much in terms of feedback there. So back to the tried and trusted place for feedback.
This year I have been working on bright targets at longer focal length to keep acquisition easier and it is very enjoyable :) .The camera is ASI1600MM-Cool @unity gain and the scope is Edge11 at native focal length of 2800mm. my setup is waay oversampled at 0.28 arcsec/pix. Yes, I do read about optimal sampling and seeing .. but it is what I have and it seems to be working quite well. The seeing has been very good lately with almost no wind here in austin and the mount is having a pretty good time tracking typically under 0.4 arcsecs. I do see some elongation in RA when seeing is bad, but it is still manageable.
This is a SHO mapping of M1 . This target has pretty good signal in all three channels resulting in psychedelic colors after the mix. I also have two other mixes that are more sedate but I still prefer this. This is a bright target and is quite forgiving with shot subs (5min subs for all three channels).
I threw about 2 nights worth of subs and kept only the sharpest ones. Even minor deconvolution gives it a over sharpened look. I will also post the other two mixes I have with sedate colors.
C&c welcome as always
Compressed CN version
AB Version
  • John Wunderlin, drjolo, nicknacknock and 14 others like this
#2 happylimpet
happylimpet
  • Loc: Southampton, UK
Posted 14 September 2017 - 04:49 AM
So SHO = RGB in this mix?
(Superb by the way!)
#3 anismo
anismo
Posted 14 September 2017 - 09:04 AM
Thanks Happylimpet. Yes, this is a straight SII/Ha/OIII channel mapping to R/G/B channels .
  • happylimpet likes this
#4 entilza
entilza
  • Loc: Oakville, ON, Canada
Posted 14 September 2017 - 09:10 AM
Hey Anis, I can see what you mean about oversharpened, but that is so cool regardless!  What if you didn't decon this image?
#5 rigel123
rigel123
  • Loc: SW Ohio
Posted 14 September 2017 - 09:14 AM
I remember imaging this years ago in the same palette.  Great job, and psychedelic for sure!
#6 anismo
anismo
Posted 14 September 2017 - 09:39 AM
Thanks Martin and Warren
@Martin, It actually looks pretty shar before decon. I did very very minor just to tighten the star. I will post a version with no decon at all. It looks almost like the "worms" you get when you do too much deconvolution but it actually was there from the start.
The L channel itself is a 0.33Ha/0.33OIII/0.34SII
Edited by anismo, 14 September 2017 - 09:40 AM.
#7 FiremanDan
FiremanDan
  • Loc: Virginia
Posted 14 September 2017 - 01:25 PM
That resolution tho...
Stunning.
#8 anismo
anismo
Posted 14 September 2017 - 01:41 PM
Thank you Dan!
#9 ImNewHere
ImNewHere
  • Loc: Nashville, IN
Posted 14 September 2017 - 08:44 PM
Sublime
#10 Jeff2011
Jeff2011
  • Loc: Sugar Land, TX
Posted 14 September 2017 - 09:01 PM
#11 anismo
anismo
Posted 15 September 2017 - 08:57 AM
Thanks Scotty and Jeff :) I am pretty happy the way it turned out.
#12 f430
f430
  • Loc: La Mesa, CA.
Posted 15 September 2017 - 09:24 AM
Beautiful!
And wow, you certainly set a high bar for possibilities with the 11" Edge HD and ZWO 1600MM-C camera!
Thanks, John
#13 anismo
anismo
Posted 15 September 2017 - 09:37 AM
Thanks John. I threw out about 50% of the subs (most of which were during full moon and bad seeing) but when the conditions permit it has been an amazing setup. My main objective with the Edge11 was to do both high res DSO and planetary imaging and it has delivered well on both front.
The ASI1600 has been an excellent camera and I am happy I made the switch. It worked very well with the Tak FSQ106 and I was thinking the oversampling is going to be an issue with the Edge11 but that hasnt been a problem (In fact I like the resolution when the seeing permits).. not to mention it is nice to do lunar imaging without touching the train during those clear/moon nights.
