Psi Persei and Phi Persei, spectroscopy
2 replies to this topic
#1 old_frankland
old_frankland
Posted 22 September 2017 - 04:26 PM
Psi and Phi Persei. Be shell stars with prominent emission lines in both the H-Balmer, H-alpha and H-beta, and a number of Fe II lines. Much the same as what I have been posting, so I will spare you a wordy post.
psi-persei_phi-persei_shell-stars_jferre
psi-per_calib-response_jferreira_18sep20
#2 Olivier Thizy
Olivier Thizy
Posted 25 September 2017 - 09:45 PM
Hello,
I took recent spectra of phi Per and psi Per (they are in BeSS Be Star Spectra database). phi Per shows clear changes in the Halpha emission between august and september; psi Per emission is more intense as per this graph:
I liked your iron FeII emission lines so I looked at rhem and found them with very shape:
Cordialement,
Olivier
#3 old_frankland
old_frankland
Posted 26 September 2017 - 03:25 PM
Fe II  at 5169 in the Psi Per spectrum is an excellent example of a shell line with the central absorption dipping well below continuum level.  Very pronounce change in Phi Per H-alpha V/R.   Excellent stuff, Olivier.  That echelle spectrograph is most impressive.  Keep it coming!
