Some progress with my eclipse images
7 replies to this topic
#1 Robin
Robin
Posted 28 September 2017 - 02:00 PM
Hi folks,
A few weeks ago I uploaded one of my stacked eclipse images in a previous thread. But in the mean time I did some more image processing.
Exposure settings: 20 images with 1/3200 - 4 sec exposure time, ISO 200, white balance: sunny, TS ED 60/330 APO with flattener, Canon EOS 70D.
Applied 8-16 dark frames for each exposure longer than 1/30 second (more dark frames for longer exposures) and 285 flat frames (taken with a white shirt in front of the telescope aperture).
Tracked with a Skywatcher StarAdventurer mount on a carbon tripod, stabilized by a half-full gallon bottle of mineral water attached to the tripod.
Here are three different versions:
Single frames stacked manually with Photoshop. For exposures shorter than 1/125 sec, I used prominences at the right hand side as a reference. For exposures longer than 1/125 sec, I used Regulus as a reference. For 1/125 sec I used both.
Larson-Sekanina Filter:
With Fitswork, I applied the Larson-Sekanina filter (5 different versions with radius 0.5 pixels and rotation 1, 2, 3, 4, and 5 degrees, respectively). I multiplied each of these filtered results with the original stacks. Then I removed artifacts (2 dark spots next to each brighter star) with the clone stamp tool in PS and stacked the 5 images together.
Very similar to this method: http://www.gva-hambu...fitswork_uk.htm
Total solar eclipse - Larson-Sekanina and Pellett combined:
At first, I applied the Pellett method (with a radial blur filter, amount: 10, method: spin, quality: best) as described by Jerry Lodriguss on his website ("more visually realistic method", thank you, Jerry, for providing this information on your website. And then I additionally applied the Larson-Sekanina-Filter as descibed above.
Total solar eclipse - Larson-Sekanina and Pellett combined 2 highlights reduced.jpg
I took the previous image and reduced the highlights somewhat to better show details close to the sun. This image is not quite visually realistic, but it shows a lot of coronal structures with a lot of detail.
Probably this is not the end yet...  I'm still looking for ways to make the images better. I'd love to read about your suggestions... :-)
At next, I'll have to process the images of the second half of the eclipse. I still don't know how to merge all of the frames together. If I include all my totality images, I will get several moon images, because I use the corona and stars as references. If I use the moon as a reference, the corona would be smeared out.
Clear skies
Robin
Edited by Robin, 28 September 2017 - 02:04 PM.
  • zjc26138 likes this
#2 Robin
Robin
Posted 28 September 2017 - 02:01 PM
#3 Robin
Robin
Posted 28 September 2017 - 02:02 PM
  • dghundt likes this
#4 Robin
Robin
Posted 28 September 2017 - 02:03 PM
#5 dghundt
dghundt
Posted 28 September 2017 - 02:17 PM
All very nice.
#2 is my pick.
I also found the 'realistic' Pellette method described by Jerry worked the best. It provides nice detail but still has a natural look.
To fix moon edge artifacts I simply took the moon from my brightest exposure, enlarged it slightly and put it over my composite.
Edited by dghundt, 28 September 2017 - 02:27 PM.
#6 Robin
Robin
Posted 26 October 2017 - 02:12 PM
That's a nice idea to insert a slightly enlarged moon.
Since I didn't like my overexposed moon image, I actually generated a composite of two differently exposed moon images, enlarged it and inserted it.
This way, I was able to use images taken during the whole span of totality.
Clear skies,
Robin
  • REC, dan_hm, charotarguy and 1 other like this
#7 dan_hm
dan_hm
  • Loc: New Jersey
Posted 27 October 2017 - 11:49 AM
Latest one is really impressive!  The only thing I would change is the color of the prominences to red instead of green.
#8 Robin
Robin
Posted 28 October 2017 - 03:11 PM
Well, on my screen and to my eyes they rather look white. Somehow, I wasn't able to retain the red color from shorter exposures, because I included longer exposures with  saturated prominences.
Clear skies
Robin
