PnP Focus: The simplest-ever Arduino focus controller
252 replies to this topic
#251 tiddler
tiddler
Posted 09 September 2020 - 07:24 AM
Can't say this enough.  Many of the ardumotor boards do not come with the logic-V set to 5V.  If it is not selected to 5V because the leonardo uses 5V logic, the LED sequence will not be correct and the stepper will just make a noise and not move when using slow or fast speeds.  If you step through 4 steps, every position should show a light pattern.  If one pattern extinguishes the lights, you do not have the logic voltage selected.  Be sure to look at post 226 for an example of the logic-V pads.  They are very small and you might need a microscope to make the solder bridge on the 5V side to the center pad.
logicV
I have the moonlite hi-res focuser and struggled with the connections not realizing the logic-V was not set.  Note the Moonlight focuser documentation incorrectly states the wire color to dB9 pin definition.  When I disassembled my focuser, I found 1-Blue, 2- Red, 3-Black, 4-White, 5 the additional 2 wires for the center tap. The image shows these correct wire-pin colours and connection to the board.
moonlitefocuser
Finally I decided that I wanted the temperature probe to be installed in the connector at the motor.  I found a DS18B20 board that I wired into the motorboard.  It probably would have worked to just leave it in the case.  However I cut off the sensor and installed wiring through to the dB9 connector which attached to the stepper motor.  I installed header and individual pushon wire connectors and use the open wires in the dB9 connector to bring the connection back to the controller.  I used an RJ45 Ethernet cable as my cable and used a RJ-45-dB9 module for the connection at the motor.
temp board1
temp board2
https://www.ebay.ca/...872.m2749.l2649
#252 tjay
tjay
  • Loc: just outside of Toronto
Posted 14 September 2020 - 06:07 PM
I'm wondering if I could update this with an ESP32 to add Wifi and Bluetooth support
#253 MikeCMP
MikeCMP
  • Loc: Chardon OH
Posted 18 September 2020 - 09:54 PM
Finally used my focused as a controller with SGP. Worked like a charm!
had to tweak the step size but other than that it worked very well.
thanks for this project!
