Trouble updating Starbook
8 replies to this topic
#1 amys
amys
  • Loc: Groton, CT
Posted 12 October 2017 - 12:24 PM
I'm trying to update my Vixen Starbook for my SXW.  I don't have a PC but I have Windows 10 running as a virtual PC on my Mac. I have the Starbook connected to my Mac via a crossover cable and ethernet-to-Thunderbolt adapter.  I downloaded the latest firmware to the desktop and confirmed that the IP address of my Starbook is correct.  When I click to install the update, I get a message saying that it can't connect to the Starbook.  Is it not possible to update the Starbook using this configuration?
#2 Tim
Tim
  • Loc: southern Ontario
Posted 12 October 2017 - 06:55 PM
Hi I have the sxd mount and just found out that an update was available. Guess it’s been out for a few years. I am using Mac with windows running on it and wasn’t able to do the update. However when using the sky x it connected no problem. I would think it’s possible but I couldn’t figure it out. I purchased minix pc portable computer that I will set up and use a with another mount. I was easily able to do the update with that.
Side note I think the update is great unguided with a sloppy polar alignment I was getting 60 second exposure at 900mm focal length. I hadn’t used the mount in years but it was never that good before. I think the upgrade has made a big difference.
#3 amys
amys
  • Loc: Groton, CT
Posted 12 October 2017 - 07:24 PM
Are you running Windows on a separate partition or as a VM?
#4 Tim
Tim
Posted 12 October 2017 - 08:02 PM
I am running parallel software with windows so that would be virtual I guess
Mac recognizes the connection with sky x but couldn’t make it work with windows.
#5 amys
amys
  • Loc: Groton, CT
Posted 12 October 2017 - 08:07 PM
Ok.  Thanks for responding.  I guess I’ll try installing Windows via Bootcamp before trying to borrow someone ‘s PC.
#6 Betelgeuze
Betelgeuze
  • Loc: Europe
Posted 13 October 2017 - 12:27 PM
Be careful, it is possible you gonna " brick"  the Starbook if the connection is not 100% reliable when doing the update...  Eyecrazy.gif
(So maybe better borrow a windows pc)
A tip out of the field, if your guiding sometimes behaves strange in PHD2, using the ascom/puls-guide option,
even if your calibration is good, then try to switch over to st4 guiding, it can make a big difference.
Don' t know if this has something to do with some area' s of the sky or the 2x sidereal guide speed in the Ascom driver.
#7 amys
amys
  • Loc: Groton, CT
Posted 13 October 2017 - 02:21 PM
Yeah, I'm going to borrow a friend's PC.
#8 GlenM
GlenM
  • Loc: Lancashire England
Posted 15 October 2017 - 08:17 AM
Glen.
#9 amys
amys
  • Loc: Groton, CT
Posted 15 October 2017 - 07:57 PM
