Curved Spider Vanes for imaging?
astrophotography
12 replies to this topic
#1 Ivandn
Ivandn
  • Loc: Arizona
Posted 12 October 2017 - 12:46 PM
I just started serious imaging having recently acquired a real mount Orion Atlas, and a guide setup. So far its been pretty good but still a lot to learn in the way of fine-tuning the setup.
I am pretty happy with the first few images out of my 6" reflector but I'm really not feeling the diffraction spikes. I know the recommendations are to use refractors but I can't afford a good APO right now.
I'm (cautiously) intrigued by the concept of curved spider vanes and having round stars. It seems like the popular (and only?) choice is 1800Destiny.com but I've not seen many images on Astrobin or otherwise that are using curved spiders.
So I'm wondering a few things and would greatly any input and especially if you do use curved spider vanes:
1) Is there a good reason why they aren't as common? (do people prefer diffraction spikes?)
2) Do they significantly compromise rigidity to a point where imaging is not recommended?
3) Does anyone have images or found images online from on reflectors with curved vanes? I'd love to see them!
~Ivan
Equipment:
Celestron 6" Omni XLT
Orion Atlas EQ-G
Sony Nex5
ZWO120mms + ZWO 60mm F/4.6 guidescope
#2 Jeff Struve
Jeff Struve
  • Loc: Iowa, USA
Posted 12 October 2017 - 12:51 PM
I'll be interested in seeing responses...
  • I think they may not be as common because most folks process their pics, and there is a way to remove the spikes (I can't stand them!)
  • I don't think that there is a compromise...
  • Not I!
Thanx!
#3 ChrisWhite
ChrisWhite
  • Loc: Colchester, VT
Posted 12 October 2017 - 12:57 PM
I like the spikes, but i image with an 8" need so I might be in denial. Lol!
Best way to produce images with less intrusive spikes is to increase your integration times so that you don't have to stretch as aggressively. I'm talking 10, 20 or more hours on an image.
You'll enjoy the benefits of strong data signal as a side effect. Hahah
#4 Ivandn
Ivandn
  • Loc: Arizona
Posted 12 October 2017 - 01:06 PM
That's good to know and it definitely makes sense. When combining images from multiple nights, do you avoid changing anything in the rotation so the spikes match up? I don't have a way to tether my camera so plate solving is tricky at best.
If the spikes don't match up, can they be processed out when stacking images from 2 nights, if say integration time is more or less equal? ( I do realize framing will be messed up doing that)
#5 calypsob
calypsob
  • Loc: Roanoke, Virginia
Posted 12 October 2017 - 01:19 PM
This is the best method for removing spikes, no need to go curved http://serge.bertore...r/antiaigr.html   This will almost completely eliminate the spikes, I think that by dithering aggressively you could really end up with round stars.  If you additionally mask the mirror clips then you can have a diffraction free light path with nice round stars.  You can download and print mask aigrettes here https://www.thingive...m/thing:1260926 They could be rescaled for a larger scope in a slicer like cura though I would recommend redesigning them completely to fit your application using the geometry provided on Serge's website.  Design Spark Mechanical is a free 3d non parametric extrusion program and you could whip one of these up in 2 seconds specifically for your scope.
Edited by calypsob, 12 October 2017 - 01:20 PM.
  • pfile likes this
#6 ChrisWhite
ChrisWhite
Posted 12 October 2017 - 01:35 PM
It doesn't matter if your camera rotates, as long as your scope doesn't rotate. You want to get your camera close simply so you have maximum overlap of field of view from night to night. Since your newt is mounted on a dovetail and doesn't rotate, no problem.
If your mount is not perfectly relatively level between sessions then the spiders might change position relatively with the sky, which can result in double spikes or spikes that don't lineup perfectly, so just make sure you get your mount precisely positioned from night to night.
I move my mount in and out each day. I just never touch the leg extensions and mark exactly where in my lawn each leg goes. It's precise enough to make sure the spikes line up from night to night.
#7 pfile
pfile
Posted 12 October 2017 - 01:36 PM
spikes are weird, while you might think that they are related to the camera angle, they are not... they are related to the angle between the sky and the vanes themselves. so if you rotate the camera and then register the rotated frames, the spikes will still line up.
the only situation where the spikes will change is if you rotate the OTA itself, or rotate the vane holder, either of which would change the angular relationship between the sky and the vanes. when your telescope is on a rail, you can't really change the OTA rotation, but i suppose it is possible if you are using rings.
rob
#8 Ivandn
Ivandn
  • Loc: Arizona
Posted 12 October 2017 - 02:21 PM
rob
Ahh that makes sense, I had to stop and think about that one for a bit.
What if I move my scope to a different location , but kept the scope in the same rotation on the rings, should it all still match up?
Thats brilliant! I'm definitely looking into this, thanks!! I fear it may be a little too much obstruction for a small 6" but it is cool!
#9 leveye
leveye
  • Loc: Central Oregon Coast
Posted 12 October 2017 - 04:26 PM
They work pretty well but still leave a crazy pattern. You may or may not like it. Here is a test using a destiny 3 vane curved spider. I loved the quality of it and still use it.
  • ram812 likes this
#10 Ivandn
Ivandn
  • Loc: Arizona
Posted 12 October 2017 - 06:28 PM
Thats exactly what I was looking for, thanks leveye! I'm sufficiently impressed at the roundness of the stars, the bloat and diffraction.
When you said it will leave a crazy pattern are you referring to the link (http://serge.bertore...r/antiaigr.html) shared by calypsob?
Calypsob - Do you have any images with the vane mask? I'd be curious to compare them to the curved vane image
If not, I might even cut some out on cardboard and do some star tests on them
#11 pfile
pfile
Posted 12 October 2017 - 06:40 PM
it should all still match up... but another strategy for dealing with this would be to deliberately change the spike orientation such that they can be rejected as outliers during integration. it would probably be kind of a pain to do this though.
rob
Edited by pfile, 12 October 2017 - 06:40 PM.
#12 ram812
ram812
  • Loc: Grants Pass, Oregon
Posted 12 October 2017 - 08:52 PM
I'd also be curious about the effect of any dew control wires on a curved vane.By the way, I like the effect on leveye's shot, that looks pretty clean to me!grin.gif
#13 Ivandn
Ivandn
  • Loc: Arizona
Posted 29 November 2017 - 02:30 PM
Many thanks to all that replied, I pulled the trigger on a 1800 Destiny curved spider vane. Below are 2 test shots of a bright star before and after.
I didn't realize I had changed the ISO and the stars are different so they are definitely not equal comparisons in terms of the amount of exposure and diffraction. While I upgraded the spider I also flocked the tube but I doubt that made much difference in the tests.
The stars appear more hexagonal than round and brighter stars tend to have 6 short stubby spikes that make them look more star-of-david like.
I also added an image i did of M45 as I figured this would be a good subject to test diffraction spikes. C&C welcome!
Straight Vanes.
Camera: Sony Nex 5 (modified)
ISO: 800
Exposure: 120s
Star: Vega
Telescope: Celestron Omni XLT 150
Curved Vanes.
ISO: 400
Exposure: 120s
Star: Capella
M45 Pleiades
Camera: Sony Nex5
Lights: 98 x 120s
Darks: 23 x 120s
Bias: 30
Flats: 30
Processing in Pixinsight
Also tagged with one or more of these keywords: astrophotography
