Unofficial SharpCap Quick Start Guide
92 replies to this topic
#76 goldtr8
goldtr8
Posted 08 August 2019 - 07:42 PM
Thanks for the updated document.   I really like the trouble shooting section for stacking.   I have only used my system 6 times now with great success but stacking was my Achilles and your write up makes sense to me.
Cheers & Beers.
  • Astrojedi and Lee L like this
#77 donstim
donstim
  • Loc: Seattle Area, WA USA
Posted 09 August 2019 - 03:24 AM
My point to you was if you want to post process don't save with adjustments as you lose data & dynamic range by stretching and then saving the stretched image.
True, but I don't really do much more processing post live stacking/stretching with SharpCap.  Mainly just cleanup and labeling and maybe some slight additional stretches.  I've tried discarding the SharpCap-stretched images and started with the unstretched FITS files, but I have a hard time just duplicating what I can do fairly quickly in SharpCap let alone substantially improving it. Mind you, I am just using GIMP (and either DSS or PIPP for debayering if starting with an unstretched FITS file).  I don't want to spend hours either imaging or post-processing.  It's EAA, but then includes some further cleanup (which may include some additional stretching), which then takes it out of the realm of EAA, but nowhere near astrophotographic imaging.
As for where the debayering is done, I assume the camera driver just uses simple nearest neighbor interpolation for debayering, which is quick and simple, but which can leave a lot of color aberrations, especially at edges.  I don't know what SharpCap uses, but I assume it uses at least bilinear interpolation.  (Maybe I should make these assumptions!)  When I did work with the SharpCap FITS files, I used much higher order interpolation methods available in DSS or PIPP for debayering.
I continue to be amazed at what one can do with SharpCap live stacking in a suburban backyard.
#78 39.1N84.5W
39.1N84.5W
    He asked for it
  • Loc: cincinnati
Posted 09 August 2019 - 06:58 AM
Very nice updates! Thank you
In step 6 you discuss the histogram... but the illustration doesn't really help. Could you use an illustration that has the sliders surrounding the peak? It's a bit confusing.
#79 Astrojedi
Astrojedi
  • Loc: SoCal
Posted 09 August 2019 - 09:32 AM
Thanks for pointing that out. I will update that section.
#80 Astrojedi
Astrojedi
  • Loc: SoCal
Posted 09 August 2019 - 09:48 AM
Fair points. For touch up it’s fine.
I have not noticed much of a difference between the driver and SharpCap wrt debayering.  Bilinear is the most common algorithm used in Astro software so it is possible the driver also uses that. But either way to me it is irrelevant for EAA.
#81 biomedchad
biomedchad
  • Loc: Galion, Ohio
Posted 10 August 2019 - 05:47 PM
I don’t see a gamma setting anymore to use with a 224 camera? Is it hidden somewhere ?
#82 mikenoname
mikenoname
  • Loc: Death Valley Region (Bortle 2 - SQM 21.9+)
Posted 14 August 2019 - 02:53 AM
Thanks again Hiten for this great manual!
  • octobass and Astrojedi like this
#83 Astrojedi
Astrojedi
  • Loc: SoCal
Posted 14 August 2019 - 05:11 PM
Good catch. I found a number of errors. Will update and repost shortly.
#84 Astrojedi
Astrojedi
  • Loc: SoCal
Posted 14 August 2019 - 05:24 PM
Updated the guide to fix a few errors. Thank you all for the feedback. There are still some gremlins that I need to fix. Will post another update in 1-2 weeks.
New version here: https://liveastronom...g/SharpCap.html
Edited by Astrojedi, 14 August 2019 - 07:11 PM.
  • DuaneS, eros312 and StubbornRunner like this
#85 mikenoname
mikenoname
Posted 14 August 2019 - 06:33 PM
Hiten,
Link is coming up broken for me.
#86 OleCuss
OleCuss
Posted 14 August 2019 - 06:42 PM
Hiten,
It is broken for me as well, but if you go back to the link he posted on (IIRC) the 8th:  https://liveastronom...g/SharpCap.html that link works for me and it appears to be the most recent version.
#87 Astrojedi
Astrojedi
  • Loc: SoCal
Posted 14 August 2019 - 07:12 PM
Strange. Just updated my post. Please try it now. Thx.
#88 mikenoname
mikenoname
Posted 15 August 2019 - 02:02 AM
#89 Muleskinner115
Muleskinner115
Posted 16 August 2019 - 09:21 AM
First of all, this guide has kept me going with Sharpcap!!!  It is invaluable!
I would suggest that you somehow highlight, perhaps with a shaded color, changes for each update. It would help people to quickly scan the document to see what is new or changed.
Fantastic help!!!
Tim
  • Stargazer3236 likes this
#90 Astrojedi
Astrojedi
  • Loc: SoCal
Posted 18 August 2019 - 04:23 PM
Tim,
Thanks for the suggestion. I think a change log may make sense.
  • BJS likes this
#91 Astrojedi
Astrojedi
  • Loc: SoCal
Posted 07 November 2019 - 07:32 PM
Just a quick update. I am in the process of moving / setting up my website. The SharpCap Guide can now be found here: https://raniobservat...cap-quickstart/
Note that the old links will not work anymore.
  • OleCuss, nicknacknock, roelb and 1 other like this
#92 arrowspace90
arrowspace90
  • Loc: United States
Posted 17 January 2020 - 02:17 PM
Here is the first very early draft release of the Unofficial SharpCap quick start guide. It is still pretty rough but I wanted to get it out there for comments and feedback rather than write it in a vacuum.
I intend to keep this guide very simple and easy to read and is primarily targeted at new(er) users with some additional topics for existing users based on typical issues faced.
I remember the first time I used SharpCap and was quite intimidated by the interface (I was used to Starlight Live and Infinity prior to switching). If you are having that feeling or have had that feeling this guide is for you.
There are many paths through the SharpCap interface but I have picked one that is easy to start with and explain. But once you get comfortable don't be limited by this guide.
I hope you find it useful and would really appreciate your comments, feedback and suggestions on how to develop the content.
EDIT: Made some minor corrections today (Oct 30) AM. Please re-download.
Download here: https://www.amazon.c...zbBa3qVWiYDIgVS
This looks helpful!
#93 elrico
elrico
  • Loc: West Yorkshire UK
Posted 10 February 2020 - 12:18 PM
Thank you Hiten for doing all this work, much appreciated, especially by us old timers.
eric
  • BJS likes this
