Microlensing visuell! Observe it NOW!
20 replies to this topic
#1 Uwe Pilz
Uwe Pilz
  • Loc: Leipzig, Germany
Posted 03 November 2017 - 05:19 PM
At October 25th  T. Kojima detected an increasing brightness of a 14 mag star in Taurus. The star showed no variability since 2014, so it is thought to be a microlensing event. The event has the number TCP J05074264+2447555, which contains the coordinates of the star.
The maximum brightness was around 11.2 mag. It is expected decreasing now.
The full moon is around 40 degrees away from that region, and comes closer ever hour. At first, I thought I could observe it with my 4 inch refractor. But the bright moonlight washed out the fainter stars. So I brought my 12 inch Dob outside. It was not cooled down yet. Nevertheless I was able to see the star. I measured it to have around 11.9 mag. It is decreasing in fact.
If possible observe it in the next hours with the moon away a few dozens of degrees. The next chance is waiting for the moon eastward of Taurus, which is not before Monday. Because the star is decreasing it may be a less conspicuous.
Of course, I have really "seen" the microlensing, if I observe the region a few days later and see a further decreasing. May be there is enough time to measure some kind of light curve.
The bright star in the sketch is SAO 76967 (8.8 mag). The remarkable triangle southwest of the SAO star helps to estimate the angular distances.
  • Mel Bartels, Astrojensen, azure1961p and 12 others like this
#2 Augustus
Augustus
    Fly Me To The Moon
  • Loc: Stamford, Connecticut
Posted 03 November 2017 - 06:42 PM
I wish I could. It's cloudy here and won't clear up until the Moon is well within Taurus.
#3 mariosi
mariosi
  • Loc: Cyprus
Posted 04 November 2017 - 04:13 AM
Thank you for sharing
Marios
#4 Jef De Wit
Jef De Wit
  • Loc: Hove, Belgium (51°N 4°E)
Posted 04 November 2017 - 06:26 AM
Interesting observation waytogo.gif  I hope to observe it soon.
#5 azure1961p
azure1961p
  • Loc: Triton
Posted 04 November 2017 - 10:26 AM
Uwe,
What an esoteric find!!!!! Thanks for the heads up. The magnitude range as well, though faint is still within the envelope of many amateur instruments.
Pete
#6 niteskystargazer
Posted 04 November 2017 - 01:19 PM
Uwe,
Thanks for the info (Microlensing visuell! Observe it NOW!) smile.gif .
thanx.gif ,
#7 Aquarellia
Aquarellia
  • Loc: Artignosc, Provence, France
Posted 04 November 2017 - 11:37 PM
That’s a great catch Uwe, another strange object after CTA102.
Thank you for this info,
Michel
#8 Jef De Wit
Jef De Wit
Posted 06 November 2017 - 03:23 AM
Here's my sketch of this strange object. With the 96% moon only 10° away, it wasn't an easy observation: moonlight was shining on the mirror! But the starhop is easy. Brightness is decreasing: my estimation was 12.4 (based on an AAVSO-chart).
  • David Gray, Aquarellia, cloudbuster and 1 other like this
#9 Uwe Pilz
Uwe Pilz
Posted 06 November 2017 - 04:52 AM
WOW!
> estimation was 12.4
It seams that it decreases rather fast. It looks like I get a clear night and will look again.
#10 David Gray
David Gray
  • Loc: Ower Yonder 01.5ºW. 55ºN (UK)
Posted 06 November 2017 - 05:54 AM
Good efforts Uwe and Jef.
I have been following this event and posted on Observational Astrophysics (posts #8 & #14)
https://www.cloudyni...vent-in-taurus/
I plan to post a sequence of renderings on this Forum as it fades to normal.
Dave.
Edited by David Gray, 06 November 2017 - 05:55 AM.
#11 Aquarellia
Aquarellia
Posted 06 November 2017 - 05:55 AM
Well done Jef !
Tonight I still have the same magn. estimation than yours : +12.4 between +12.0 and +12.6 on the AAVSO chart. As stated by Uwe the moonlight was not very helpfull !
Here my own sketch :
Michel
  • Jef De Wit, David Gray and k.s.min like this
#12 k.s.min
k.s.min
Posted 06 November 2017 - 08:47 AM
What  is  the  reason  to  say  it  is  a  microlensing  ?
what  is  the  maker  of  this  microlensing?
Are  there  any  other  possibility  or  explanation  for  this  event.....such  as  star  bang ?
#13 Uwe Pilz
Uwe Pilz
Posted 06 November 2017 - 09:17 AM
The star is observed for some years with no brightness variation. Microlensing is just the most plausible explanation. A strong argument for that would be if the spectrum remains constant during the change. This excludes all of the explosive changes, and therewith a star bang.
#14 Uwe Pilz
Uwe Pilz
Posted 06 November 2017 - 03:15 PM
I had a hard time detecting the star with the moon only 7.5 degs away. Nevertheless I found it. If you compare my sketch with the one form Friday:
- I could not detect the double star just eastward of SAO 76967 anymore. I saw it as single star, the aggregated mag is 12.8 mag. I did not see the star southeast of the triangle, which has 12.9 mag.
- I saw, however, all stars of the triangle, but with more trouble. Finally, I could hold the weakest of the stars with direct viewing.
- I could see the microlensing with indirect view securely.
I did not seee enough stars for an more exact brightness measurement, but I guess the micro lens star to have 12m4...12m5 now.
  • Jef De Wit and Aquarellia like this
#15 Sheliak_sp
Sheliak_sp
Posted 09 November 2017 - 12:53 AM
The night of 07/11/17 I stimated it about 12.8, it was so exciting to see that little point!
https://elnidodelast...espacio-tiempo/
microlente-2017.png?w=404
Clear skies!
Migue
#16 frank5817
  • Loc: Mesa, Arizona
Posted 09 November 2017 - 09:32 AM
Uwe et. al.,
Nice captures of this star.
 Frank :)
#17 Uwe Pilz
Uwe Pilz
Posted 14 November 2017 - 02:15 PM
Yesterday we had a changing between fast moving clouds and clear sky. After a rainy weekend, the sky was very clear if without clouds. I observed the microlens star again. I estimated it to have 13.4 mag. Please compare the sketch with the one of November third (first sketch in that thread). It is very dimmer now. It was as bright as the dimmest star of the small triangle, and now it is the weakest star in the sketch at all.
This is the last observation for me, I am ready with that object now. I can say for sure: I have seen a gravitational lens!
#18 Aquarellia
Aquarellia
Posted 14 November 2017 - 02:46 PM
Yes, and thanks to you we did it too
Michel
Edited by Aquarellia, 14 November 2017 - 02:52 PM.
#19 Jef De Wit
Jef De Wit
Posted 15 November 2017 - 11:02 AM
#20 Aquarellia
Aquarellia
Posted 17 November 2017 - 07:07 AM
My goodbye kiss was this morning (2017-11-17 4h LT)
The estimated magnitude was close to the magnitude of the star without the lens effect : 13.8
Tonight the sky was much more dark that the one with the moonlight, we can compare.
Another interesting information about this object is that "The low component mass ratio makes the microlensing event as possibly due to a binary lens hosting an Earth-sized object."  A earth-sized object detected in a distance of +/- 6000 light years,... this is just wow !
This statment is acted here : http://www.astronome...org/?read=10934
Michel
Edited by Aquarellia, 17 November 2017 - 07:16 AM.
  • Jef De Wit and rerun like this
#21 Jef De Wit
Jef De Wit
Posted 23 November 2017 - 08:42 AM
Goodbye kiss at 22 november. He's getting pritty dim. Estimation with AAVSO-chart: 13,8 mag.
