2018 Lunar X Predictions
moon observing
19 replies to this topic
#1 67champ
67champ
  • Loc: Ohio, USA
Posted 17 November 2017 - 09:33 AM
2018 Lunar X Predictions (approx "start times"):
Using Werner (1.2 Sun Alt) with coordinates of:
LAT      -28.0
LON     3.3
Date                Time           Sun Angle at the X at this time
01/24/2018    0442UT          -.975 @ X
02/22/2018    1807UT          -1.025 @ X
03/24/2018    0657UT          -1.064 @ X
04/22/2018    1913UT          -1.082 @ X
05/22/2018    0702UT          -1.079 @ X
06/20/2018    1837UT          -1.054 @ X
07/20/2018    0614UT          -1.010 @ X
08/18/2018    1809UT          -0.956 @ X
09/17/2018    0632UT          -0.920 @ X
10/16/2018    1930UT          -0.901 @ X
11/15/2018    0859UT          -0.903 @ X
12/14/2018    2246UT          -0.935 @ X
Average = -.0.992 @ X
Someday, when I have time, I will use Sun angle at the X of -1.000 to predict the start of event.  Either way, the times are very close as the start of the event which is somewhat subjectional...
Dana T
Edited by 67champ, 17 November 2017 - 02:44 PM.
  • Dave Mitsky, David Castillo, Pinbout and 3 others like this
#2 John_Moore
John_Moore
    Author: Craters of the Nearside Moon
Posted 17 November 2017 - 09:43 AM
Thanks, Dana...the Lunar X
John Moore
  • 67champ and David Castillo like this
#3 beggarly
beggarly
  • Loc: Belgium
Posted 17 November 2017 - 10:59 AM
Lunar X and Lunar V 2018. Calculated with LTVT version 0.21.5x6.
https://ltvt.wikispaces.com/LTVT          https://holdfenyarny.../ltvt-setup.pdf
Edited by beggarly, 17 November 2017 - 05:05 PM.
#4 Muddman97
Muddman97
  • Loc: NE Oklahoma
Posted 22 November 2017 - 02:12 PM
I caught both the X and the V one evening this past Summer.
I didn't even know what I had until a fellow astronomer pointed them out to me.
I had no idea I had imaged a highly sought after lunar artifact.
Lunar X and V
  • 67champ, silv and paulymo like this
#5 Tom Hoffelder
Tom Hoffelder
Posted 13 January 2018 - 02:15 PM
Approximately 3 hrs difference between the two lists.  First list says "start times."  Maybe the second is the middle of the event?
#6 67champ
67champ
  • Loc: Ohio, USA
Posted 13 January 2018 - 05:02 PM
Tom,
I would probably interpret beggarly's two lists as approx. start times and then approx. end times...  waiting for beggarly to respond....
dana t
#7 AUricle
AUricle
  • Loc: Frankfort, IL
Posted 22 February 2018 - 04:50 PM
Downloaded the files from the above linked wordpress. The final file "Clementine V2 texture map" does not appear downloadable at all........am I missing something there?
#8 beggarly
beggarly
  • Loc: Belgium
Posted 25 February 2018 - 04:56 AM
I downloaded the Clementine V2 file without a problem 5 minutes ago.
I also downloaded this file after changing the image size. Height to 1060 and width to 2160 to get better resolution.
(Right click - Save image as).
https://www.mapaplan...on&center_lat=0
If you want even better resolution download from http://wms.lroc.asu...._E000N0000_064P the *.TIF - (253.21 MB) and convert to JPG (http://www.irfanview.com/). I think I had to reduce the size of the JPG file to prevent LTVT from crashing. The size of the file I use is 95573010 bytes.
Hope this helps.
Edited by beggarly, 25 February 2018 - 04:58 AM.
#9 Duke2k
Duke2k
  • Loc: Kent UK
Posted 22 April 2018 - 06:57 PM
I have followed the right hand link and downloaded the files but the LDEM_64.LBL file is just text.
How do I download it and in what format should it be saved?
Any help would be very much appreciated.
#10 Star Geezer
Star Geezer
  • Loc: Lat. N 40º 56' Long. W 87º 8'
Posted 22 April 2018 - 08:44 PM
New member, initiating contact. This an amazing forum. I started observing the moon today from my location at approx. 2:00 PM. The werner X was clearly highlighted nicely. Knowing I only had maybe a couple hours. I watched till it became obscure. So, I was curious when would be a more favorable time to observe it.
67champ; Thank you for your predictions.
Edited by Star Geezer, 22 April 2018 - 08:51 PM.
  • 67champ likes this
#11 beggarly
beggarly
  • Loc: Belgium
Posted 23 April 2018 - 03:03 AM
Right click and choose 'Save as' LDEM_64.LBL
#12 beggarly
beggarly
  • Loc: Belgium
Posted 23 April 2018 - 03:31 AM
Welcome to Cloudy Nights.
I think that in June, August, October and December the Lunar X will be visible again from your location. The pictures show the sub lunar point at the time of First Quarter.
Edited by beggarly, 23 April 2018 - 10:02 AM.
#13 Tom Hoffelder
Tom Hoffelder
Posted 23 April 2018 - 08:08 AM
I don't see an obvious answer to my question back in January about the three hour difference in the two lists, but I can now report when I saw what yesterday.  I had hoped to have our 8 inch f/6 Newtonian set up before the earlier time listed, 19:13 UT, but did not get my first view until 19:45 UT, when the X was fully formed although not as large and bright as it was later.  My last and best view was at 22:00 UT, with the X showing its best definition.  Part of that could have been because the sun was lower, the moon higher and the seeing better.  I have never observed an X to the end so don't know how long it lasts, but maybe it is about three hours? This was taken at 21:10 UT by holding my cellphone to the eyepiece.
  • silv likes this
#14 beggarly
beggarly
  • Loc: Belgium
Posted 23 April 2018 - 09:40 AM
... answer to my question back in January about the three hour difference in the two lists,
The first list shows the times when the altitude of the Sun at Lunar X is -1.0°. The PDF file starts with an altitude of 0.5°, 3 hours later.
At the time of your best observation (22:00 UT), the altitude of the Sun was 0.25°. I'll include that angle in the list for next year.
#15 Tom Hoffelder
Tom Hoffelder
Posted 23 April 2018 - 04:59 PM
Aha, the images are what I needed; the sun angle didn't mean anything to me!  Thank you!  It all makes sense now!
#16 silv
silv
Posted 07 December 2018 - 06:50 AM
Hi There,
judging from the earth diagrams, almost no people are in a position to observe Lunar X this December cycle, correct? Would somebody be so kind and knowledgable as to compute next year's list of time frames?
#17 John_Moore
John_Moore
Posted 07 December 2018 - 09:17 AM
Ad nauseum...an animated view (YouTube link) of the Lunar X's development.
Edited by Jayem, 07 December 2018 - 09:18 AM.
  • Dave Mitsky likes this
#18 67champ
67champ
  • Loc: Ohio, USA
Posted 08 December 2018 - 11:42 AM
silv, search this message board for "2019 Lunar X predictions".  I posted this information months ago...
I would think eastern North America would be able to observe the later stages of the Dec 14th, 2018 illumination....
dana t
#19 John_Moore
John_Moore
Posted 09 December 2018 - 12:51 PM
I know 67champ won't mind me posting his message - but just to save time with others looking them up his 2019 predictions are here.
John Moore
Edited by Jayem, 09 December 2018 - 12:52 PM.
  • 67champ and silv like this
#20 67champ
67champ
  • Loc: Ohio, USA
Posted 12 December 2018 - 08:41 PM
Sorry silv, I meant 2018....
Also tagged with one or more of these keywords: moon, observing
