Wouldn't a star test show if the mirror is spherical?
Yes but in my 40 years of making optics and testing hundreds of them, unfortunately I have seen first hand that many don't know how to do the test correctly and fool themselves they have great optics. My own RV-6 that I purchased new in 1976 came with a mirror was very much undercorrected with turned edge. I refigured it.
To do the star test correctly you need to use an eyepiece that a has a focal length that is equal to close to the F-ratio of the telescope. So for an F/8 telescope you use an 8mm eyepiece or one close to it.
Next you need to focus on a medium bright star like a 2 mag one and then de-focus very slightly inward as in around 1/16 of turn focuser and observe the size of defocused image and the size of the shadow of the secondary in the center of the defocused image. Next you go back to focus and defocus outward by exactly the same amount you defocused inward. Again your only defocusing a very slight amount and observing the size of shadow of the secondary.
If you see that the size of the shadow is larger on the inside then the outside, or there no shadow at all on the outside the optics are undercorrected.
The opposite is true, if the optics are over corrected ie you see a larger shadow on the outside then the inside of focus or no shadow at all on the inside.
Again it is very critical to use the correct magnification and also defocus only very slightly and by the exact same amount on each side of focus. If not it is very easy to make the defocused image look very similar by defocusing by different amounts or by defocusing too much and then coming to the wrong conclusion you have great optics when in fact they poorly corrected.
Using the defocused image on a star and comparing the views on each side of focus is FAR more sensitive that looking at a star that is at focus. See diffraction rings at focus is not an direct indication of well figured optics. Having spherical aberration will actually make the diffraction rings easier to see.
- Dave
Edited by DAVIDG, 15 November 2024 - 08:52 AM.
