Photo Contest - Category: Corona
18 replies to this topic
#1 nmoushon
nmoushon
  • Loc: Wenatchee Valley, WA
Posted 05 December 2017 - 11:56 PM
The Rules will remain pretty simple:
Your Equipment
Your Data, 2017 Solar Eclipse Only
Your Processing
One Entry Per Member Per Category
An Image Can Only Be Used ONCE For The Contest
Please display an image in your post, not just a link!!
Let the contest begin!(Contest ends on Jan 5, 2018)
#2 StarmanDan
StarmanDan
  • Loc: Where the stars at night are big and bright...
Posted 12 December 2017 - 12:37 PM
C80ED+Canon T2i
Layered in Paint.net from 4 exposures ranging from 1/8 sec to 4 sec.
  • FXM, ed_turco, halx and 3 others like this
#3 ilikeit
ilikeit
  • Loc: Southeast Washington
Posted 12 December 2017 - 04:53 PM
Equipment:
Canon T5 camera, WO GT71 scope, AVX mount, Solomark F50 guidescope w/ altered generic webcam using LuSol Guide Software, Camera controlled by 'Eclipse Orchestrator' software.
Data:
44°25'46.60"N, 117°35'45.58"W, 4870ft ele. (approx 25mi west of Huntington Oregon). Twelve image stack at prime focus, ISO 100, f/5.9, 1-400 to 2.5 sec
Processing:
All processing including stack in Photoshop CC 2017, no darks or flats.
(63mb png file reduced to 500kb to meet attachment size restrictions. 10mb file can be viewed in my gallery)
  • ed_turco, dan_hm, emh52 and 1 other like this
#4 Ejohn88
Ejohn88
Posted 16 December 2017 - 10:33 AM
Equipment:
Nikon D750 with 420 mm f/5.6 (Nikkor 300 mm + 1.4x teleconverter)
Skytee-II altazimuth mount
Data:
Farewell Bend State Recreation Area near Huntington, OR
69 exposures (1/4000, 1/1000, 1/250, 1/60, 1/15 sec) at iso 400
Processing:
Raw conversion using Photoshop.  Images registered, stacked, processed (contrast, sharpening, color adjustments etc) in IDL. Final tweaks in Photoshop
Edited by Ejohn88, 16 December 2017 - 05:10 PM.
  • CCD-Freak, Chris Boar, ed_turco and 4 others like this
#5 emh52
emh52
  • Loc: Arizona
Posted 16 December 2017 - 03:41 PM
This photo is attempt to capture the Sun and its Corona in situ restoring the Solar disk to the Corona in its starry setting with Regulus glowing the lower left.
Your Equipment: Vixen VSD Astrograph (380 mm F3.8) mounted on an iOptron Alt AZ with a Nikon D500 camera. Equiv FL 520 mm
Your Data:Location a farm in Idaho 43 51 05.80 N 111 26 53.94 W that had 2 min 11 sec TSE
Your Processing: This is a total of 10 images, One white Light image captured just before C1 to capture Sunspots and Solar disk and 9 images captured as an HDR at ISO 200. The resulting images (NEF) were converted to TIF with Photoshop, the white light image optimized and the solar disk cut out to place over a HDR (Photomatrix Pro) of the Corona/Sun/surrounding space also processed to TIF and adjusted with Photoshop. The combined composite then flattened and adjusted for posting.
full resolution of the thumbnail: https://flic.kr/p/XmShFE
  • nmoushon, dan_hm, Thundermoon1994 and 1 other like this
#6 Thundermoon1994
Thundermoon1994
  • Loc: Akron, OH, USA
Posted 18 December 2017 - 01:08 PM
Equipment:
Orion ED80T CF at f/6, Orion field flattener, Canon Rebel T6, Celestron Evolution mount (chosen for simplicity over polar aligning an equatorial mount during the day).  I controlled the camera via Backyard EOS.
Processing:
This is a blend of 14 exposures, ranging from 1/4000 of a second at ISO 100 to a half-second at ISO 200.  Pre-processed each frame in Adobe Lightroom, and then blended together in Photoshop CC as a Smart Object.  I think I used "Mean" mode for the blending.  Then I tweaked the stack further with the Camera RAW filter to taste.
Land Between the Lakes National Recreation Area in southern Kentucky (about 20 miles as the crow flies from the point of greatest eclise), 2 minutes, 18 seconds of totality
Attached File  Great American Eclipse Final 2 Bright CN.jpg   403.01KB   2 downloads
  • StarmanDan, ed_turco, nmoushon and 4 others like this
#7 FXM
FXM
  • Loc: Southeastern, PA
Posted 20 December 2017 - 08:23 PM
Equipment:
Nikon D7000 Nikon 600mm F/4 AIS
Atlas EQ-G Mount
Data:
Nikon RAW 14-bit lossless NEF
Speed from .5 seconds to 1/250 second
F/8
Processing:
Stacking method from Russel Brown
Lightroom 5
Photoshop CC 2017
  • StarmanDan, dan_hm and charotarguy like this
#8 Robin
Robin
Posted 21 December 2017 - 11:14 AM
Equipment:
Canon EOS 70D at TS Photoline 60 mm f/5.5 - FPL-53 apochromatic refractor with flattener
Tracked by Skywatcher StarAdventurer mount on carbon tripod, no filter
Controlled by Eclipse Orchestrator software via laptop
Data:
Location: Total Eclipse Camping, between Mitchell and Service Creek, Oregon
Exposure: Composite of 39 images with exposure times from 1/3200 seconds to 4 seconds, ISO 200
Processing:
At first, I calibrated the single frames (dark frames, flat frames for images with exposure times longer than 1/30 sec exposure time. Then I applied the Pellett method (with a radial blur filter, amount: 10, method: spin, quality: best) as described by Jerry Lodriguss on his website, by using Adobe Photoshop. And then I additionally applied the Larson-Sekanina-Filter with Fitswork (5 different versions with radius 0.5 pixels and rotation 1, 2, 3, 4, and 5 degrees, respectively). I multiplied each of these filtered results with the original stacks. Then I removed artifacts (2 dark spots next to each brighter star) with the clone stamp tool in PS and stacked the 5 images together.
Then I created another composite of 2 images with 1/2 sec and 1/15 sec exposure time, extracted the moon's "disk" from that exposure, enlarged it slightly, and pasted it onto the TSE composite image.
The whole procedure with several intermediate steps (and a few alternative versions not included in this contest) is documented here:
https://www.cloudyni...eclipse-images/
Summary of software used: Fitswork, Adobe Photoshop
Clear skies
Robin
Attached File  TSE_composite Robin.jpg   70.81KB   2 downloads
  • FXM, dawsonian2000, ed_turco and 3 others like this
#9 BigSteve72
BigSteve72
  • Loc: Roseville, Ca.
Posted 26 December 2017 - 05:09 PM
Equipment: Canon 60D, ES102 Essentials, Celestron AVX, Solar Eclipse Maestro.
Processing: ISO 200 1/30s Minor adjustments in Photoshop.
Location: About 20mi outside of Madras, OR 44.831519, -120.902749
Attached File  Corona.jpg   447.67KB   3 downloads
  • dan_hm likes this
#10 PI_CO100
PI_CO100
Posted 27 December 2017 - 02:40 AM
Your Equipment: Takahashi FC-100DF, Avalon M-Zero, Canon 6D
Your Data: 30 exposures from 1/125 sec to 4 sec., 21/08/2017 - Cedar Hills Vineyard, Ravenna, NE.
Your Processing: Processed in Pixinsight: Dynamic Alignment, HDR composition, Masked Stretch, Larson Sekanina, HistogramTransformation. Minor blemishes corrected in Photoshop.
There were high clouds which washed out all the detail from the Moon surface and made general image processing quite hard! I have used a black mask in Photoshop to cover the Moon.
#11 APshooter
APshooter
  • Loc: Camby, In.
Posted 03 January 2018 - 01:17 PM
Taken with a AstroPhysics 130mm Starfire with Canon 80D MkIII on MYT mount
Multiple exposures from 1/8000 sec to 1 sec
Location was in Buder Park near Fenton, Missouri
Process in Photoshop CC
  • dan_hm likes this
#12 dawsonian2000
dawsonian2000
  • Loc: Riverview, FL, USA
Posted 04 January 2018 - 05:43 PM
Event: Total Solar Eclipse of August 21, 2017 (CORONA)
Location: Columbia, NC (Columbiana Centre Mall Parking Lot)
Date: 08/21/2017
Time: 14:42 EDT
Telescope: Stellarvue SV80 80mm F/7 ED Refractor
Telescope Mount: Sky-Watcher CG-4 (motorized)
Camera: Canon EOS Rebel T4i
ISO: 200
Exposure: 1/30 sec.
Processing: Cropped only
Mel
  • Thundermoon1994 likes this
#13 pfile
pfile
Posted 05 January 2018 - 07:16 PM
glendo state park
glendo, wy
17:47UTC
canon 200L+2xTC + canon 5d3mk2
solar eclipse maestro
processing entirely in pixinsight
Edited by pfile, 05 January 2018 - 07:19 PM.
  • ariesangel and dan_hm like this
#14 dan_hm
dan_hm
  • Loc: New Jersey
Posted 05 January 2018 - 09:13 PM
Taken in Sweetwater, Tennessee
Nikon D5100
200mm Nikkor lens
1/500s to 1/4s exposures
Processing in Photoshop CS5 and Pixinsight
  • pfile, ariesangel and Ejohn88 like this
#15 kyle1234
kyle1234
Posted 06 January 2018 - 12:31 AM
Equipment:  Canon 7D & Canon 100-400mm f/4.5-5.6L, mounted on Celestron CGEM DX
Processing:  Pixinsight, Photomatix, Capture One Pro, Photoshop
  • dan_hm likes this
#16 noisejammer
noisejammer
    Fish Slapper
  • Loc: The Uncanny Valley
Posted 06 January 2018 - 08:45 PM
My humble offering - click on it for higher res.
I was able to record polarisation in the corona by shooting two back-to-back sequences, short to long, flip polarisation then long to short. The sequences were processed individually then false coloured and superimposed.
Polarisation V5
Images shot from Lost Springs, WY.
APM 115/805 with Tak TOA130R reducer and a Canon 5D Mk II. Everything carried by my AP 900GTO. The scope was fitted with a home-made adapter and a polariser from my camera so that the effective aperture was about f/6 and T/8. The trip and my processing were covered in a special edition of Nightfall.
  • Robin, dan_hm and Ejohn88 like this
#17 nmoushon
nmoushon
Posted 15 January 2018 - 12:42 PM
Sorry for the late response on getting the winners posted. Was a busy weekend for me.
The winner is Robin! Congratulations! You did a great job balancing the corona as well as getting both the neighbors in on this shot :)
#18 dawsonian2000
dawsonian2000
Posted 15 January 2018 - 09:40 PM
The winner is Robin! Congratulations! You did a great job balancing the corona as well as getting both the neighbors in on this shot smile.gif
Great job, Robin! Love the striations of the corona radiating from the sun's magnetic pole in your shot! I actually saw this with my own eyes through my telescope, but could not capture it as well as you did through my camera. It was my first total eclipse and I learned a great deal. With lessons learned and if the Lord agrees, I will do much better for the 2024 event.
Congrats!
Mel
#19 Robin
Robin
Posted 18 January 2018 - 12:57 PM
Thank you very much for the nice feedback! :-)
I spent a lot of time on the preparation for the eclipse trip last summer. Many hours for an event that only lasted for approximately 2 minutes... And I really must say that I learned a lot about eclipse photography and image processing on this forum.
Clear skies
Robin
