Anyone Have Two Scopes On One Mount?
equipment Maksutov mount observing reflector refractor SCT tripod
33 replies to this topic
#1 Aperture Mask
Aperture Mask
Posted 12 December 2017 - 01:46 PM
Anyone have two scopes on one mount? What are the advantages of a two scope on one mount setup? Would you be so kind as to show me/us an image of your two scope setup? Thanks to you all.
#2 junomike
junomike
  • Loc: Ontario
Posted 12 December 2017 - 02:02 PM
Two scopes (for visual) allow you to view two different type targets without having to swap out OTA's.
Examples could be Planets/Luna, Wide Field DSO's, smaller and/or fainter DSO's.  Also, using two OTA's can give a different view of the same target.
Some people prefer the views of Stars through a refractor instead of a Mirror. Others prefer the mirror.  Some (like me) enjoy both.
Various ways to mount two scopes
Piggyback (on a Forkmount)
  • havasman, kellyvictoria and wrnchhead like this
#3 junomike
junomike
  • Loc: Ontario
Side by side configuration using a Dual Saddle set up.
  • hersey0308, havasman and kellyvictoria like this
#4 junomike
junomike
  • Loc: Ontario
Posted 12 December 2017 - 02:03 PM
Dual mount
  • hersey0308 and kellyvictoria like this
#5 clearwaterdave
clearwaterdave
  • Loc: Western Maine
Posted 12 December 2017 - 02:18 PM
I like to compare scope views.,With this set-up I use the 127 as a finder and then see if I can spot the target with the 80mm..,Or I can have a wide view .,,or a wider view.,:).,
  • dtran1968, vtornado, cosmo823 and 2 others like this
#6 havasman
havasman
  • Loc: Dallas, Texas
Posted 12 December 2017 - 02:22 PM
Two solar scopes, one white light and the other much more narrowband, can make for some fascinating observing.
  • cosmo823 likes this
#7 vtornado
vtornado
  • Loc: Northern Illinois
A little lower on the food chain ...
It is nice to have the ST80 wide field and a 6" f/8 on the same mount.
The ST80 is like a super finder.  You can use a digital angle meter to match the AZ of each scope.
This also helps with "shoot outs, between two scopes"
  • zjc26138, havasman, clearwaterdave and 3 others like this
#8 cosmo823
cosmo823
Posted 12 December 2017 - 02:23 PM
Crutches?
That's brilliant! Love seeing your set up, Dave.
#9 Garyth64
Garyth64
  • Loc: SE Michigan
Posted 12 December 2017 - 02:30 PM
This past summer at Astronomy on the Beach at Island Lake Metropark.  I took my Sears 6339a, and mounted a Sears 6309 on it.  My plan was to show how an object looked at different magnifications.  A viewer could look thru one, and then the other.
-on old CG5 mount and homemade tripod
Did the same thing a few years ago.  6" Meade with a 90mm Meade.
-on homemade mount and pier
Edited by Garyth64, 12 December 2017 - 05:04 PM.
  • kellyvictoria likes this
#10 JamesMStephens
JamesMStephens
  • Loc: Hattiesburg, Mississippi
Posted 12 December 2017 - 02:43 PM
You might like this
https://www.cloudyni...-pro/?p=7857612
#11 Bonham
Bonham
Posted 12 December 2017 - 02:46 PM
thank you  so much for asking this good question!!!!  thank all of you folks who sent those wonderful pictures of your set ups! i am very fond of the pipe fitting creations!!!!   all of you have given to me some good ideas to work with this winter  on this topic.   thank you again for asking and responding.
#12 baron555
baron555
  • Loc: Lockport, IL
Posted 12 December 2017 - 02:59 PM
I can do close-up and wide-field imaging of DSOs simultaneously.  It's great to be able to capture hours worth of images during one night.  (Just don't have autofocus on the 80mm, yet!)
#13 Kunama
Kunama
    Aussie at large
  • Loc: Canberra, Australia
Posted 12 December 2017 - 03:19 PM
My left eye was always complaining mad.gif  about being bored fingertap.gif  while my right eye was seeing the beautiful sights wink.gif   of the heavens above me so I decided to give my left eye a scope all its own waytogo.gif  :
( and there is still room next to the counterweight for another scope for a friend )
Edit:  OK, so probably not what the OP meant but still two scopes on one mount flowerred.gif
Edited by Kunama, 12 December 2017 - 03:21 PM.
  • psandelle, FiremanDan and JamesMStephens like this
#14 Kunama
Kunama
    Aussie at large
Posted 12 December 2017 - 03:29 PM
Another take on twin scopes:
#15 NMBob
NMBob
  • Loc: New Mexico
Posted 12 December 2017 - 04:58 PM
Two, then a different two, then three for solar observing at different wavelengths.
Originally it was a Lunt Ha scope and a Sky-Watcher Esprit 80 for white light.
Then a Lunt Calcium-K scope and a Lunt Ha.
Then a Lunt Ha, William Optics Zenithstar 61 for white light, and a Lunt CaK scope.
I've never used two for dark time observing, but I guess it would be something like my SW80 for wide field, and my C6 or C8 for zooming in.
  • Philip Levine, psandelle, Kunama and 1 other like this
#16 Jeffmar
Jeffmar
  • Loc: salt lake city, utah
Posted 12 December 2017 - 05:39 PM
Two Takahashi scopes as a binocular. That has to be a dream setup!!!!
  • Kunama likes this
#17 DaveJ
DaveJ
  • Loc: NE Ohio
Posted 13 December 2017 - 11:55 AM
Someone mentioned dual solar scopes: one for Hydrogen-alpha and another for white-light viewing. Here's a photo of my wife and me at the August 21 solar eclipse event. Incidentally, We had 1000 people attend which was a huge surprise for us! On the left is a double-stacked Solarmax 90 and on the right is a SkyWatcher Pro ED100 with a Baader Herschel Wedge. I (wisely) left the binoviewers at home, but they are normally both used with Baader Mark V binoviewers.
Edited by DaveJ, 13 December 2017 - 11:55 AM.
  • zjc26138, Philip Levine, psandelle and 3 others like this
#18 Philip Levine
Philip Levine
  • Loc: near Boston, MA
Posted 13 December 2017 - 01:42 PM
Dual scope setup on an iOptron AZMP/with Mini-pier.  William Optics 80mm Zenithstar II with a white light Baader ASTF filter, TeleVue 70mm Pronto with a Coronado Solarmax II hydrogen-alpha filter.
Phil
  • NMBob likes this
#19 EFT
EFT
    Vendor - Deep Space Products
  • Loc: Phoenix, AZ
Posted 17 December 2017 - 02:08 AM
Dual scope setups can be useful for different purposes but they can also be difficult to work with to get the best setup possible.  Alt/Az dual scope setups can be great for being able to see two different views of the same object or part of the sky without having to change the mounted scopes, eyepieces, etc.  In a more permanent setup, it can be used simply to allow the use of one scope for one purpose and another scope for a different purpose again without having to change equipment.  The difficulty comes in getting the two scopes aligned so that they are both aimed at the same point in the sky if the goal is to be able to use both scopes at the "same time".  This is easiest done with some type of separate aiming device that allows for the precise adjustment of one of the two scopes (most mounts do not have a means to do this built-in).  Below is an example of an Alt/Az configuration with two different solar scopes (H-Alpha and white-light) set up to view the eclipse this year.  Other Alt/Az configurations may use scopes on either side the mount head, but in any case, you want to have a way to aim both scopes together, be it an aiming device or shimming.
Another common dual scope mounting is the side-by-side or piggyback (i.e., over-and-under) setup on a German equatorial mount.  While sometimes used for visual, this type of setup is more often used for imaging purposes.  It can allow you to shoot images at different scales at the same time with different scopes/cameras, or different wavelengths at the same time with different filters on identical scopes.  It can also allow you to use each scope individually for different purposes (e.g., wide-field or deep-sky imaging).  The difficulty with dual-scope setups on a GEM is two fold, aiming just like the Alt/Az mounts, and balancing.  Parallel aiming can be taken care of in the same fashion as the Alt/Az mounts (i.e., aiming devices or shimming).  Balance can be a problem because you may have two completely different optical/imaging trains next to each other that have different, possibly significantly different, weights and lengths.  This complicates balancing in both axes since the weight balanced on top of the mount is far less equal and centered and is more dynamic when moving.  It may not only be necessary to significantly offset the different scopes from the center of the axis, but to even have to add additional counterweight to one side of the SBS setup.
Piggybacked mounting can be difficult depending on the size and weight of the scopes used.  The higher the stack of scopes get, the more counterweight is needed and the greater likelihood that flexure may become a problem.  Small scopes are often used for guiding on top of larger scopes, but just like SBS setups, they may be used for the same purposes like simultaneous imaging.
Below is an example of a small 70mm scope for wide-field imaging mounted next to a large (C14HD) scope for photometry.  Balancing this setup in all directions is a challenge but allows the setup to be used for different purposes at different times.  This is necessary in a remote observatory where access to change things is very limited and size is not sufficient to have two different mounts (not to mention the expense)..
Beyond dual-scope mounting, there are good examples of people using three, four or most scopes on the same mount for both visual observation and imaging.
Edited by EFT, 17 December 2017 - 11:29 PM.
  • Doug D., psandelle and FiremanDan like this
#20 42 degrees north
42 degrees north
  • Loc: Iowa
Posted 17 December 2017 - 02:26 PM
I have three on my mount.....a Stellarvue SV70, a Stellarvue SV105T, and a Celestron Edge 8HD.  They are mounted in a Losmandy side-by-side saddle on a Paramount MX+.
9FDF4F6C-EBCA-45FC-9849-72D9B84DB582_zps
Matt
  • psandelle, kellyvictoria and milehighap like this
#21 Tonk
Tonk
  • Loc: Leeds, UK, 54N
Posted 17 December 2017 - 04:55 PM
My two OTT OTAs
get.jpg?insecure
  • psandelle likes this
#22 Christopher Erickson
  • Loc: Waikoloa Village, Hawaii
Posted 17 December 2017 - 06:24 PM
Here is a triple setup.
#23 Christopher Erickson
Posted 17 December 2017 - 06:59 PM
Another setup.
  • psandelle, NMBob and mr.otswons like this
#24 Christopher Erickson
Posted 17 December 2017 - 07:00 PM
Another.
#25 Christopher Erickson
Posted 17 December 2017 - 07:04 PM
More.
Also tagged with one or more of these keywords: equipment, Maksutov, mount, observing, reflector, refractor, SCT, tripod
