This image is part of a mosaic I am building of M42. I have all the Ha data, but still need the OIII and SII for the 2nd an 3rd panels. This is M42 - Great Orion Nebula in LHaSIIOIII. It is really my first serious image processing attempt with all PixInsight. I will be posting my work flow later but here it is:
OTA: Orion EON 115mm APO with WO Flattener IV - 1.19 microns/pixel - 680mm FL
Mount: Orion HDX-110 EQ-G with ASI190MM-mini and ORION 70mm Guide scope with PHD2
ASI1600MM-C/EFW with 16mm ZWO 7nm Ha, OIII, SII filters
T= -15C, Gain 200, Offset 40, USB 60
Ha: 30 X 10s, 30 X 180s
OIII: 30 X 10s, 30 X 180s
SII: 30 X 10s, 30 X 180s
40 flats, 40 dark flats, 60 darks
Exposures for each filter were calibrated, registered, and stacked with PixInsight. I combined the 10s and 180s exposure with HDR composite. I used a super Luminance with the combined data from all three filters but still need more time to process. However, for this image, I was able to process out the remaining edge artifacts from the filters for the first time. The full NB data does not do the star color well, but the resolution looks good to me. The ZWO filters show a lot of star halos, but I am OK with that. I have been looking at a lot of published images for major observatories and even the Hubble and they show halos around bright stars as often as not.
I did just receive my set of Astrodon 36mm filters and will likely repeat the data to see how the ADs perform compared to the ZWO filters.
