Why would you want a 6 inch Achromat?
287 replies to this topic
#26 Gofr
Gofr
  • Loc: Canada
Posted 07 January 2018 - 11:15 AM
I was looking at the Starwave 152mm myself and seems excellent. I would love one, but new the run a cool $1200 CAD. I can get a new 6 inch F8 at $700 CAD new. Not sure I'd be willing to spend an extra $500 on it. Then ofc there's the used market.
#27 russell23
russell23
  • Loc: Upstate NY
Posted 07 January 2018 - 11:16 AM
I think a 6" achromat makes a lot of sense for someone that prefers refractors and also wants enough aperture for deep sky.  You can clean up the views of a 6" achromat significantly with a filter and you will have the sharp images a refractor provides at a significantly lower cost than a 6" APO.
  • stevew, Dave Ponder, Sarkikos and 6 others like this
#28 VNA
VNA
  • Loc: Northern California
Posted 07 January 2018 - 01:00 PM
A 6" achromat such as my CR6 is hard to beat for performance and particularly for its price.
Using a fringe filter helps a great deal and if not enough there is an aperture  reducer.
The CG5 mount is somewhat wobbly unfortunately.
With 2" eyepiece it gives really nice and sharp views.
Could not spend 10 times for an APO because it does not give a 10 times better image! (not even close)
  • jgroub, Gabby76, clusterbuster and 1 other like this
#29 Crow Haven
Crow Haven
  • Loc: S.Oregon Coast USA
Posted 07 January 2018 - 01:28 PM
I have the Celestron Omni XLT 6" f/5 (and also the CR6 f/8 currently stored away) and love it for the wide-field low mag. views.  At 16 lbs.+whatever accessories you choose it's not a big deal to mount.  I prefer using it on my Twilight II alt/az mt. either alone with a counterweight on the other saddle or use another ota -- even a 6 to 7" Mak for planetary or other apo refractor at the same observing session.  Works for me! grin.gif  YMMV.
If you don't mind me asking, have you ever mounted or run the 6" f/8 on your Twilight II?  If so, how well does the mount perform on high power planetary viewing, and also on changing eyepieces from heavy to light?  I've often considered moving my 6" to a Twilight II and mounting an Orion 180 Mak-Cass on the other side for planetary viewing.
No, I haven't tried it on the Twilight II so I can't say if it works.  Because of its length I would think the Twilight II (I have the pier extension already on it) would benefit from the pier extension...but maybe sitting close to the ground would work even without it.  I just can't say, so I'm sorry this isn't helpful to you.  I do use the 180 Mak as well as other otas and it works well up to your ability to track manually at whatever high mag. you can.  For planetary sketching and longer study/higher mag. sessions I'll use a tracking mt. as it's more convenient.  While the Twilight II mt. by itself isn't super- light weight for grab-n-go it's still pretty easy, in my case, to carry it outside plop it down and then go get the scopes to put on it = a quick setup -- the 6" f/5 and the 180 Mak are fun partners of similar wts. allowing for casual sessions of whatever the seeing allows.  I start out on the wide-field views and try out the Mak later if conditions are good for it.  I also have smaller Maks and apos which can quickly be switched out on the Twilight II.
  • Steve Cox likes this
#30 junomike
junomike
  • Loc: Ontario
Posted 07 January 2018 - 05:00 PM
Why?  Best bang for you buck on a "Yard Canon".  Also, there's a ton of DSO's that look real nice through it despite it's poor color correction.
  • Sarkikos, Crow Haven, gene 4181 and 2 others like this
#31 ValeryD
ValeryD
    Vendor (Aries)
  • Loc: Kherson, Ukraine.
Posted 08 January 2018 - 12:35 AM
A 5x priced car is not necessary 5x faster and 5x more comfortable. But you takes this easily.
Why not take the same logic with achromats and apochromats?
Edited by ValeryD, 08 January 2018 - 12:36 AM.
  • Jon Isaacs, zjc26138, doctordub and 2 others like this
#32 Ziggy943
Ziggy943
    In Memoriam
  • In Memoriam
  • Loc: Utah
Posted 08 January 2018 - 11:53 AM
In their long version they make an awesome telescope.
  • jrbarnett, stevew, Jim Davenport and 19 others like this
#33 Peter Besenbruch
Peter Besenbruch
  • Loc: Oahu
Posted 08 January 2018 - 12:55 PM
Longest 6", f8 I've ever seen. ;)
  • Ziggy943 and James Stanski like this
#34 Dave Ponder
Dave Ponder
  • Loc: Greenville, SC
Posted 08 January 2018 - 01:19 PM
Thanks guys for the comments, much appreciated.  I just ordered the ES AR152 version and an extra 12lb counterweight for the AVX.  Will let you know how it goes!
Clear Skies!
Dave
  • Jeff B, belgrade, Crow Haven and 6 others like this
#35 gustavo_sanchez
gustavo_sanchez
  • Loc: Puerto Rico, US
Posted 10 January 2018 - 03:09 PM
I do have my AR152 mounted in a Twilight II and use it occasionally for lunar viewing. Mount is stable enough for it when I use a CW on the other saddle. At least I didn't notice major vibrations while observing, just when I touch the focuser but they die off rather quickly, less than two seconds.
#36 tomwall
tomwall
  • Loc: Arizona, USA
Posted 10 January 2018 - 03:35 PM
Hi Dave,
How are the views?
The views are very good.
However... The set up and tear down for the AVX mount takes some time. The 152 doesn't get to see as much sky is time as it deserves because it is just SO much faster to use my c102mm (f9.8) or my c8/SE. It's a trade off. One of those T-mount adaptors might be fun and simple.
#37 lulz
lulz
  • Loc: Østfold, Norway
Posted 11 January 2018 - 05:25 AM
I'd want one for DSOs and/or building a solar scope
  • rogeriomagellan likes this
#38 tomwall
tomwall
  • Loc: Arizona, USA
Posted 11 January 2018 - 09:32 AM
Just for background, I built a Badar solar filter for my 152 at my local club. It works quite well. However, I get as good an image from my c102 (f9.8) and ETX90 (f13.5) when I use the same filter. Thanks to my wife for holding the filter so I didn't go blind. :-)
Edited by tomwall, 11 January 2018 - 10:16 AM.
  • lulz likes this
#39 rogeriomagellan
rogeriomagellan
Posted 11 January 2018 - 11:50 AM
Hi, everyone.
It is hard to believe that the ES AR152 is not among the best achromats available out there. However, there are two other options that appeal to me as well. The TS 6" f/5.9 with a fine 2.5" rack-and-pinion focuser and the red Starwave with the same specifications from Altairastro are two of them:
https://www.teleskop...-Objective.html
https://www.altairas...rd-focuser.html
Bresser has a 6" achromat but it is f/5. However, it is not a simple doublet. It is a 4-lens telescope. For more info, click on the link below:
https://www.teleskop...60-mm--OTA.html
For those interested in a 6" f/7.9 achromatic refractor, the Bresser Messier below may fit the bill:
https://www.teleskop...00-mm--OTA.html
I hope that my comments were of some help.
Clear skies.
Edited by rogeriomagellan, 11 January 2018 - 11:52 AM.
#40 Mikefp
Mikefp
  • Loc: The Bak
Posted 12 January 2018 - 10:25 AM
Thumbs up on the Jaegers 6" f15 yard canon. I do enjoy when I use it for planetary viewing. I set up at public viewing and enjoy peoples comments about the scope.
  • stevew, neo, george tatsis and 11 others like this
#41 daquad
daquad
Posted 12 January 2018 - 11:20 AM
Hi, everyone.
Clear skies.
Looks like the Starwave and TS do have the 2.5" R&P focusers, an excellent upgrade from the Crayford, IMO and both look like Kunming beauties.
#42 Phillip Creed
Phillip Creed
    Idiot Seeking Village
  • Loc: Canal Fulton, OH
Posted 12 January 2018 - 03:40 PM
I've heard good things about the 152 Starwave and other 6" f/5.9 Kunmings, but I'm still quite skeptical about its performance due to being screaming-fast for an achro.  But I've never looked through one.
One thing I'd like to see (translation--it'll never happen) is a 6" f/6 ED doublet.  "But...but...it'll have false color!!"  Duly noted.  Don't care.  I'm a visual observer, and I found a non-SDF Genesis (more or less same CA as a 4" f/12 FH doublet) more than good enough.  Even a 6" f/6 FPL-51 would have way, WAY better color correction than any 6" f/6-f/8 FH doublet out there.
But I can't fathom any commercial firm making one; imaging nowadays is the acid test.
Clear Skies,
Phil
  • stevew and John O'Hara like this
#43 Gofr
Gofr
  • Loc: Canada
Posted 12 January 2018 - 05:42 PM
Clear Skies,
Phil
Well, they do make 'em at F8, but that seems to be the best we'll get.
#44 Planethunter80
Planethunter80
  • Loc: NC
Posted 12 January 2018 - 07:44 PM
#45 stevew
stevew
    Now I've done it
  • Loc: British Columbia Canada
Posted 13 January 2018 - 02:51 PM
As long as the lens has a good figure and is well corrected for c/a and s/a, a well made six inch achromat can be a lifetime scope.
Steve
  • belgrade, george tatsis, Rusted and 13 others like this
#46 John O'Hara
John O'Hara
  • Loc: Oil City, PA
Posted 13 January 2018 - 05:55 PM
Clear Skies,
Phil
I'd think that a 6" f/6 ED doublet would be at least as well corrected for chroma as my 1986 6" f/8 Astro-Physics refractor, which was a "standard" glass triplet corrected for visual use.  That scope is a killer visual instrument, even though the chroma correction is not as good as today's triplets with exotic glass.
Edited by John O'Hara, 13 January 2018 - 05:56 PM.
  • BarrySimon615 likes this
#47 CHASLX200
CHASLX200
  • Loc: Tampa area Florida
Posted 13 January 2018 - 06:23 PM
I know the older CG5 is way too small for a 6" F/8.  I would say a G11 would be much better.
#48 Planethunter80
Planethunter80
  • Loc: NC
Posted 13 January 2018 - 06:26 PM
There is just something about long focal length refractors that make me smile. If I had the space and the funds a scope like this would be my ultimate instrument of choice.
  • stevew, Mikefp and clusterbuster like this
#49 Planethunter80
Planethunter80
  • Loc: NC
Posted 13 January 2018 - 06:28 PM
Steve
Steve is that a Losmandy mount your long and luscious refractor is riding on?
#50 Steve Cox
Steve Cox
Posted 13 January 2018 - 06:33 PM
If you're talking the older mounts prior to the CG-5A with the upgraded 2" stainless steel legs and upgraded ball bearing axes I agree.  But the CG-5A and ASGT (same mount just different electronics) handle the 6" f/8 just fine for visual, especially if you add the Orion 16" pier extension.
