Beehive cluster GSO 6" RC
6 replies to this topic
#1 zxx
zxx
Posted 10 January 2018 - 01:09 AM
Had a chance tonight to try the new 6" RC.... I,m vary happy with this scope after getting it tuned .This is 8x4 min exposures ,iso 800  ,no FF or FR
Edited by zxx, 10 January 2018 - 01:17 AM.
  • mikewayne3, PeteM, darkstar3d and 5 others like this
#2 Jim Waters
Jim Waters
  • Loc: Phoenix, AZ USA
Posted 10 January 2018 - 01:29 AM
Real nice image.  Was it hard to align?  Did you use the ZWO for imaging?
#3 zxx
zxx
Posted 10 January 2018 - 01:35 AM
Thanks ,Pentax k50 was used for the image , I found a site for a easy way to tune these up,my primary was out a tad and I had a lot of tilt between the focuser and the primary  ,easy fix with a laser ,also the primary was vary loose
Edited by zxx, 10 January 2018 - 02:03 PM.
#4 proteus5
proteus5
  • Loc: Southern New Jersey
Posted 12 January 2018 - 07:39 AM
Nice image!  Care to share the site for "easy way to tune" the scope? I have an at8rc thanks
#5 zxx
zxx
Posted 12 January 2018 - 09:40 AM
www.hnsky.org/RC-collimation.htm       Note  ,when I removed the secondary I did not remove the 3 adjustment screws ,just backed them off a tad so the center screw would break free .This will keep the distance about  the same when you reinstall it .Also when rotating the focuser to align it with the primary I had the drawl tube to where my camera was in focus and had the tension adjustment screw fairly snug  ....
Remember ,once you rotate the focuser and have it lined up it needs to stay there ,you will need to rotate the camera instead
Edited by zxx, 12 January 2018 - 12:49 PM.
  • proteus5 likes this
#6 proteus5
proteus5
Posted 13 January 2018 - 07:12 PM
Thanks very much for the link and the tips!   Note The link should have an underscore instead of a dash after rc
http://www.hnsky.org...collimation.htm
Edited by proteus5, 13 January 2018 - 07:16 PM.
  • zxx likes this
#7 jrsm
jrsm
  • Loc: Fraser Valley BC
Posted 13 January 2018 - 10:22 PM
I had to do some work on the focuser in mine.  The focus tube was canted in the focuser so if you rotated the focuser, the laser would form a circle on the wall in front of the scope.  Only after I added some more shims and screws on the focuser, I was then able to align the laser in the centre of the secondary.  After that the hnsky procedure works quite well.
  • zxx likes this
