Data, Data, Data... [FITS Provided, Lots of them!]
283 replies to this topic
#226 TareqPhoto
TareqPhoto
  • Loc: Ajman - UAE
Posted 15 March 2019 - 09:13 PM
At the risk of sounding stupid, I'll ask this.... How are you getting color images from this data? Everything I fiddle around with in Pixinsight still results in these being gray...
Each channel will be gray or mono anyway, until you combine them all together then they will create the colors, each color represent a color or if they are NB filters/channel then you can set each for a certain color then combine them by one of the settings, one channel won't give you colors unless you colorize it but it will be like only one color anyway.
#227 Regis83
Regis83
  • Loc: French Riviera, France
Posted 10 April 2019 - 02:37 AM
Hi.
Here is my attempt for Ic1805.
Very nice data.
Thanks for sharing.
Régis
  • Vaagstrom, rockstarbill, artem2 and 5 others like this
#228 Kkiixx
Kkiixx
  • Loc: Kansas City, MO
Posted 14 April 2019 - 01:26 AM
removed the stars from OIII and SII and stretched them.  Stacked them on top of HA with a small bit of opacity to create a luminance layer.
Flattened that down
copied it twice as an overlay and a soft light layer
added a small pixel high pass to the overlay
added a huge pixel high pass to the soft light
masked them both off and brought out the parts i liked
added the three files to RGB channels in another layer
dilly dally with the RGB levels
Spend 3 1/2 more hours of things and stuff.
  • elmiko, Vaagstrom, rockstarbill and 2 others like this
#229 AdrianoMS
AdrianoMS
  • Loc: Volta Redonda, Brazil
Posted 15 April 2019 - 07:51 AM
rockstarbill's M101 data processed in Fitswork.
Excellent data.
Thanks for sharing.
  • Vaagstrom and rockstarbill like this
#230 kyle528
kyle528
  • Loc: SE Ohio
Posted 21 April 2019 - 05:48 PM
All of these links are showing me "This item might not exist or is no longer available".
#231 rockstarbill
rockstarbill
  • Loc: Snohomish, WA
Posted 21 April 2019 - 05:50 PM
The storage for them is expired, sadly. :( If I am able to host the data elsewhere I will update this thread.
  • RossW and kyle528 like this
#232 Sp0nG3Bo8
Sp0nG3Bo8
Posted 28 April 2019 - 12:28 AM
The storage for them is expired, sadly. frown.gif If I am able to host the data elsewhere I will update this thread.
you could try google drive , drop box ( you can make stuff public)  one-drive . how big is all that data ?
#233 TareqPhoto
TareqPhoto
  • Loc: Ajman - UAE
Posted 28 April 2019 - 05:43 PM
The problem is, i download them at different computer at different times, so i can't remember i downloaded so far in the past and i didn't, you can always try to put those files folders into one folder, or keep them in original folders and compress them all into one file, so that file is smaller, but if it is still very large size then simply compress them but split the compressed file into smaller files then we can de-compress it later, anything so you keep your file available for download for those who didn't download yet, or even like us who forgot, your data is very inspirational and great reference to learn and practice.
  • rockstarbill likes this
#234 rockstarbill
rockstarbill
Posted 29 April 2019 - 04:30 PM
I'll see if I can work something out later this week.
#235 Regis83
Regis83
Posted 30 April 2019 - 11:25 AM
Hi.
Here is my attempt for Messier 33.
Very nice data.
Thanks for sharing.
Régis
  • rockstarbill, AdrianoMS and RossW like this
#236 rockstarbill
rockstarbill
Posted 01 May 2019 - 10:10 PM
Hello all,
The data has been uploaded to a new share on OneDrive.
https://1drv.ms/f/s!...8Yx3HQzPBVDwung
Note that now only a single link is needed to get to all of the shared data. Also, there are only master FITS files now, as uploading entire integrations proved to use way too much space on my share (~100GB then, now only 5GB).
Data is still in the process of uploading. If you dont see something you wanted to poke at, check again later. If something doesnt work right, just holler at me.
Edit: I am going to add one folder for "Full HA Narrowband Set" that is a 2 hour HA integration that will not have any masters (except for darks and bias), but will have the flats, darks, and bias, along with the HA lights so people that want to try out a full integration can. That will be the only data in there that is roll-your-own. Use the 900s master dark for the lights, and the 90 second master dark for the flats. Both master darks are Bias subtracted. The HA flats are not all exactly 90 seconds (but none are over 90 seconds) so you may want to scale the darks when you make those.
Edited by rockstarbill, 01 May 2019 - 10:29 PM.
  • sebas7777 and RossW like this
#237 Kkiixx
Kkiixx
Posted 02 May 2019 - 08:44 PM
Working with such great data is nice.
Want to try some low budget data?  Here is a data set from the m63 contest last month.  There are 17 dark frames and 37 lights (IR filter).   A 6" newt with a Meade DSI Pro.  60 second subs.
Out of the 37 lights I only stacked 14 to get the following image.
Here is the data 54mb zip: https://drive.google...7PEvp1JQyiz3d9/
#238 Kkiixx
Kkiixx
Posted 02 May 2019 - 09:36 PM
to stay on track: m33
#239 TareqPhoto
TareqPhoto
  • Loc: Ajman - UAE
Posted 03 May 2019 - 10:26 AM
Hello all,
What happened? i couldn't download the data you uploaded, i hate OneDrive site.
#240 rockstarbill
rockstarbill
Posted 03 May 2019 - 10:30 AM
Not sure, what occurs when you try and download the data?
  • bmhjr and Kotus2017 like this
#241 TareqPhoto
TareqPhoto
  • Loc: Ajman - UAE
Posted 03 May 2019 - 10:57 AM
Hold on, i think now it is working, maybe it was the error of signing in, that is why i hate this site, will see if the download complete or not, thanks again and sorry for this problem occurred.
#242 bmhjr
bmhjr
  • Loc: Colorado
Posted 08 August 2019 - 01:27 PM
Is this data still available?  For some reason the OneDrive links are no longer working.
#243 rockstarbill
rockstarbill
Posted 08 August 2019 - 01:43 PM
Yes, see this post:
https://www.cloudyni...them/?p=9335007
  • bmhjr likes this
#244 bmhjr
bmhjr
  • Loc: Colorado
Posted 08 August 2019 - 01:59 PM
#245 rockstarbill
rockstarbill
Posted 08 August 2019 - 10:30 PM
Hi there! Stumbled acorss this thread and I can't have access to your links (It says something about requiring your permission to get these files)
My email is wong_yehwoe@yahoo.com if it hepls! Thanks so much!
Look up two posts.
#246 Ethanwyh
Ethanwyh
  • Loc: Singapore
Posted 08 August 2019 - 11:31 PM
Just checked it, my bad!
Thanks for the amazing data, will post if I am able to finish one image today :)
#247 Ethanwyh
Ethanwyh
  • Loc: Singapore
Posted 09 August 2019 - 10:15 PM
Here's my go at processing the data for the Heart Nebula, any feedback is welcomed!
Processing steps: Combined the SHO data into one RGB layer > Increase exposure and offset gamma (by a very small amount; purpose was to make the colours 'show') > Medium HLVG (2x) > Hues and Saturation to get the overall colour > Shadows and highlights > Dfine to remove some of the noise from stretching (0% colour noise, 15% contrast noise)
Link to better quality image :)
https://flic.kr/p/2gTNhYU
Edited by Ethanwyh, 09 August 2019 - 10:25 PM.
#248 Blender
Blender
Posted 25 August 2019 - 08:38 PM
Here's my very first attempt processing multi-channel files - thanks so much Bill for providing great source material. I registered them w/ DSS to get offsets and rotations, then the rest was all done in GIMP, so a 100% free workflow!
#249 rockstarbill
rockstarbill
Posted 28 September 2019 - 08:42 PM
Poking in here to check if folks would be interested in trying some Mosaic panel data out? I've got a 4 panel SHO Mosaic of NA + Pelican I'll be able to share shortly.
Edited by rockstarbill, 28 September 2019 - 08:43 PM.
#250 Bretw01
Bretw01
  • Loc: IL USA
Posted 29 September 2019 - 03:07 AM
Never have attempted a mosiac. Was just thinking about how in the future I will want to...bring it on!
