C11 on Evolution mount
42 replies to this topic
#26 beachamd
beachamd
  • Loc: Eugene, Oregon
Posted 15 May 2018 - 05:32 PM
..pics or it didn't happen!
Last note, 2 inch optics, of course.
You can all point and laugh, but seasoned professionals in my local astro club all agree- the views are steady and excellent.
Clear Skies, DB
  • Castor, eros312 and treadmarks like this
#27 Jim4321
Jim4321
  • Loc: Asheville
Posted 15 May 2018 - 05:54 PM
Beachamd, Bravo, dude!
But what's that...you _aren't_ using the stock red dot finder?  shocked.gif  After all, it's such an excellent piece of gear....  (jk)grin.gif
Looks like your mount might be a candidate for a 'rear handle delete' conversion once the warranty is up.  It'll probably improve your balance, or your ability to go to zenith, maybe both.   Just pop up the rubber EP holder, take out 4 Allen head screws, and spend a minimal amount of time with a hacksaw or Dremel.   Or tape up _all_ seams and openings to keep swarf out, and cut it in place.
Jim H.
  • beachamd likes this
#28 beachamd
beachamd
Posted 15 May 2018 - 07:19 PM
...way ahead of you! I achieved Zenith with the help of a rasp and black magic marker 😂 but was within a few degrees even without the mod.
Seriously, I love the Evolution platform and my 9.25 but I got this OTA new in the box for a great deal and there was just no way I wasn’t going to give it a try. To be honest, I’m not terribly surprised at how well it works for observing- Well worth the “risk” in my book.
#29 tonyt
tonyt
  • Loc: Australia
Posted 15 May 2018 - 07:37 PM
If you can entertain the troops while pushing the limits all the better smile.gif
Perhaps I can return the favour with this pic:
  • eros312, Thundermoon1994 and beachamd like this
#30 beachamd
beachamd
Posted 15 May 2018 - 08:38 PM
Now you’re talking!
#31 tonyt
tonyt
  • Loc: Australia
Posted 15 May 2018 - 09:44 PM
Dan, I notice you're using the visual back reduction piece with a SCT clicklock. You might gain a bit more clearance using the clicklock which threads directly to the larger rear cell thread?
Also I'd like to see the saddle arrangement if you have a pic of that?
#32 chuckscap
chuckscap
  • Loc: Colorado Springs, CO USA
Posted 15 May 2018 - 10:12 PM
Nice!
#33 Chris Johnson
Chris Johnson
  • Loc: Stockholm, NJ
Posted 17 May 2018 - 02:24 PM
beachamd, did you have modify the evolution mount to accept the CGE dovetail?
#34 Exnihilo
Exnihilo
  • Loc: Phoenix, AZ
Posted 17 May 2018 - 03:12 PM
I know that the general consensus is going to be a big NO-NO. But bear with me, please...
I own a 9.25 Evolution. I seem to enjoy good skies and would like to get a bit more resolution for planets and a bit more light gathering for DSO and to compensate for Binoviewer light loss. I am just not keen on GEM’s at all.
I love my Evolution mount. I think it’s a fantastic package. I have consistently driven my mount with my C925 OTA AND the following add-ons:
- Starsense auto-align kit
- 9x50 RACI
- Binoviewer with widefield eyepieces
- Baader dovetail 1kg counterweight clamp (for compensating and balancing)
All the above accounts for nearly 3kg, and not only are my gotos still very accurate, the system appears to function well and without stress. Indeed, vibrations are a bit more noticeable, but all in all the system works like a charm.
The C11 is (if I’m not mistaken) only 3 or 4 cm longer than the C9.25, and 3 kilos heavier, so that leads me to believe that, at least in theory, it should be possible to drive a C11 with 1.25 diagonal and eyepieces on the Evolution mount.
I wonder if anybody has tried this combination and what would be your thoughts on this, even if just for fun...
You never know, you might be able to find a used deal on a C11 CPC for not that much more than for a C11 OTA.  Peruse the used ads often.
#35 Exnihilo
Exnihilo
  • Loc: Phoenix, AZ
Posted 17 May 2018 - 03:14 PM
Clear Skies, DB
The Baader clicklock back is a little shorter than the standard Celestron back, I believe.  May be worth checking into.
#36 beachamd
beachamd
Posted 22 May 2018 - 09:44 AM
Heresy number two: it’s on a CG5 dovetail
  • eros312 likes this
#37 beachamd
beachamd
Posted 22 May 2018 - 09:46 AM
Ordered! Great tip. It’s on the 2” Baader clicklock now, but I found the one you mean, threaded for integrated 3” visual back.
Thanks! Dan B
#38 Daniele
Daniele
  • Loc: Tuscany, Italy.
Posted 14 May 2020 - 08:53 AM
Clear Skies, DB
Hello! Is this a C11 on the Nexstar Evo Mount? How is it? Can this mount do that?
#39 Don W
Don W
    Founding Member
  • Loc: Wisconsin, USA
Posted 14 May 2020 - 10:01 AM
Yes, you can do it! Is it a good idea? Time will tell.
#40 Neptune
Neptune
  • Loc: Georgia, USA
Posted 22 July 2021 - 08:02 PM
Are there any updates on this 11" riding an Evolution mount?
#41 rmollise
  • Loc: US
Posted 23 July 2021 - 03:58 PM
- 9x50 RACI
In my opinion (and you know what they say about that), big uh-uh. Not so much because of the length (though the 9.25 is really at the edge of being too long for the mount when it is properly balanced), but because of the weight and focal length.  A considerably heftier tripod could help, but I don't think enough. The 9.25 is undeniably shaky on the mount. Not unusable, but not as steady as I'd like.
  • Gregg Carter likes this
#42 maroubra_boy
maroubra_boy
  • Loc: Sydney, Australia
Posted 24 July 2021 - 04:48 PM
I have also done the single arm mod to a CPC1100. I use a 9" Santel Mak with it which is as heavy if not just a tick heavier than a C11. Whether it is or not, the Santel weighs 13kg naked. You can add up to another couple of kilos when decked out for a session. An Evo mount cannot take Maks 7" or larger as the arm is not long enough - the COG of Maks is closer to the geometric centre of the OTA, so requires a longer arm for the diagonal to clear the mount when pointed at zenith. I had looked very carefully at Evo mounts to see if it would take the 7" Intes Mak I had at the time. Not enough clearance, and this was without a dewshield hanging off the front. Only a modified CPC 1100 has the necessary arm length. The CPC925 makes use of the exact same fork as that of the 1100 - it just makes use of a spacer on the alt bearing to accommodate the smaller diameter OTA.
A friend of mine has a 10" Mak which surprisingly is 1kg lighter than my 9". He uses it on an AZEQ6. I've hence been able to compare the performance of both mounts very often with the AZEQ6 in AZ mode.
So, guess which mount is more stable, less shaky? It is the single arm modded CPC1100!
Both scopes have very good focusers that require the slightest of a touch to move the fine focus knob, but the 10" shakes a lot more when touching the focuser, both shakes more & the dampening time is considerably longer than the modified CPC.
The AZEQ6 is much quieter, that's the only advantage it has in AZ mode...  No, not really.  The AZEQ6 is lovely mount, and I am only splitting hairs here comparing the two mounts.  The vibration and dampening is good in both, though the CPC does have the edge.
Would I use the single arm CPC on a wedge with such heavy OTA?  Not a chance.  It is not designed to work this way, and it would blow out the dampening time.
Remember, the best thing for any of these mounts (Evo, CPC, AZEQ6, etc) is to have a balanced OTA hanging off the alt bearing.
The modified CPC1100 is very easy to set up & take down, just like the Evo, though considerably heavier - I have also used an Evo mount. It had a C8 on it & the lighter tripod that comes with the smaller OTAs. The shakes it showed were so much more. So much more sensitive to the touch. Disappointingly so. Just look at the thing & it shook. All because of a pissy tripod
Alex.
Edited by maroubra_boy, 24 July 2021 - 07:00 PM.
#43 maroubra_boy
maroubra_boy
Posted 24 July 2021 - 06:49 PM
Here's a pic of my 9" Santel on the single arm CPC 1100 beside my friend's 10" on the AZEQ6.  And yes, there is a 6" Intes Mak piggybacked on to that 10"! bounce.gif
  • Castor likes this
