Or rather, the little ones that could.
Ever since the beginning of my foray into this hobby I have been fascinated about how much you can do with as little as possible. This included minimizing both money and size, as I have always been on a budget and my trips to dark skies have always meant backpacking or camping in out of the way places. Oh, and also, I want to take astro photos as well.
So, this is for you who are interested in both fairly low cost and fairly lightweight mounts to be used not only for visual but ap also. I started out with a nexstar gt, then nexstar slt, then in the past 5 years or so I have progressed to three other mounts. My intent is not to review the mounts, but rather compare them side to side and also give you an idea of each one's strengths and weaknesses.
In the attached pic you can see the size differences between the Cube Pro, Skyguider Pro and Smarteq Pro. To make a fair comparison as far as imaging, I also included the accessories you would end up using for say, a fairly long telephoto lens or a small refractor. Counterweights actually play a big part in the overall weight and size.
You can tell that by size alone, the Skyguider pro is really the smallest and the Smarteq Pro the largest, although if you set them up with counterweights and all the size differences become much smaller. The skyguider pro does pack the most compact though.
Next, I weighed them, without counterweights and shafts (except the Smarteq pro, which has a non easily removable one) and also full kit (but without a tripod).
Here are the results:
Mount wo/cw with cw
Cube Pro 5.6 9.2
SkyGuide Pro 4.8 8.8
Smarteq Pro 7.0 9.0
Surprisingly the weight differences are not huge. If you go to the trouble of removing the shaft from the smarteq you can shave off at least 0.5lb. The winner is still the skyguider pro, but really only by a nose.
However, here's a twist. One trick I learned years ago is tilting the tripod by adjusting the legs to eliminate the need of a wedge. To make it stable, I used a length of rope/chain/wire connected to the tripod weight hook in the center and the other end firmly screwed into the ground with one of those corkscrew things that you can tie your pets' leash to in the yard. This cuts a surprising amount of weight in the case of the cube and skyguider, with the skyguider now weighing, without the wedge, a mere 3lb! It is really lighter than I imagined it to be honest.
So now, strengths and weaknesses. Bear in mind I just got the skyguider, so no outdoor testing as of yet.
Cube pro
Pros
- pretty cheap if you buy the mount only, just $369. I recommend this option, save the money and buy a good photo tripod to sit it on instead.
- Has goto
- can be guided with an iOptron st4 adapter (I heard the new ones can't?)
Cons
- Clutch is rather weak. Can be fixed but it's a dyi project
- Worm block springs also weak. Fairly simple fix but the mount must be opened up.
- Since most of the weight leans at an angle, it can be a bit unstable
- Can carry long telephotos with careful balancing. A small refractor like the at65edq is pushing it past its limit... and you must do the clutch and worm block mods before even attempting long lenses or refractors.
- No polar scope. I used SGP to polar align, so this was not so much of an issue.
Skyuider pro:
Pros:
- Smallest of the lot
- Second cheapest, at $428 for the full kit
- Extremely versatile, can be a very small barebones setup or full with counterweight.
- Can be guided, built in st4 port
- can trigger most dslrs, especially those with a 2.5mm cable.
- Carrying capacity? No idea yet, but I put the at65edq on it inside and there is no "give" in the RA axis. Feels better than the cube in that respect so I am hopeful.
- Can use a hand controller to do most functions on the mount.
Cons
- No goto. Not an issue usually, but when reaching the longer focal lengths framing becomes more difficult, especially if the target is really faint.
- Must have the hand controller to use the intervalometer. It's not cheap at an extra $150
- Tracking/guiding accuracy? Hard to say yet, but from reading other posts it seems to be close to the smarteq pro. We'll see if it's as good.
Smarteq Pro
Pros
- Probably the most accurate of the three as far as tracking/guiding. Even fully loaded with my setup which weighs right at 10lb it tracks and guides pretty well.
- Probably the highest payload (even though it's listed the same as the skyguider)
- Has pretty much all the bells and whistles of a full mount. Definitely the most accurate goto between it and the cube pro
Cons
- Heaviest and largest of the three
- No camera control like the skyguider
- The most expensive, at $499
So, to summarize.
If you want the most inexpensive mount that can do widefield and some medium telephoto with a camera, and has goto, the cube pro is your best bang for the buck.
If you want the lightest, most versatile setup for backpacking for example, with the option to add the functionality of a "full" mount (minus goto, the skyguider pro would be the one I'd recommend.
If you want a "full" mount, with goto, guiding, etc that can handle up to a small refractor, then the smarteq pro is the way to go.
There are other worthy mounts out there to be sure, both withing the size/weight and price. for example, I was really torn between the skyguider pro and the skywatcher star adventurer, which is actually cheaper and seems as versatile (or even more since it supports some timelapse functions as well), but I liked the idea of using the smarteq pro hand controller with the skyguider pro. Trying to remember button pushes and dial settings in the dark without a manual is too much for me lol.
Hope this helps someone.
