large file sizes from raw photos
18 replies to this topic
#1 Jeffmar
Jeffmar
  • Loc: salt lake city, utah
Posted 13 February 2018 - 06:14 PM
Most of my imaging is done with a Sony a7ll camera. In my light polluted neighborhood I often take anywhere from 40 to a few hundred short exposure photos.
I run them through either Lynkeos or Photomatics pro. If I am doing 3 to 10 second exposures I use Lynkeos. I use Photomatics pro for longer exposures. My
problem is the files sizes. My camera has 50 mb's of data per photo in raw. Put a hundred of those in a program and things either go very slowly or my software
crashes. I have 16 mb's of ram and a flash hard drive on my mac. I don't know whether it is a hardware problem or a software problem. I am wondering if I should
not use raw all the time on my camera. Any Ideas would be appreciated.
#2 Michael Covington
Michael Covington
    Author
  • Loc: Athens, Georgia, USA
Posted 13 February 2018 - 06:18 PM
I don't know what Lynkeos or Photomatics are.  PixInsight stores the intermediate results on disk rather than in RAM when processing and stacking pictures.  I presume you've checked that your hard disk isn't full.
#3 CableGuy
CableGuy
Posted 13 February 2018 - 06:34 PM
Upgrade the memory, or is it maxed on your MAC already?
I was having issues running intensive programs on an I7 laptop , it wasnt crashing but seriously lagging. I maxed out my system memory and installed a 2nd SS hard drive. I keep system files / progs running on one drive (the solid state drive) while keeping everything else on the 2nd drive, including scratch disks (space used for temp files) that programs like DSS, Photoshop and Pixinsight use while processing your photos.
#4 gralydolphin
gralydolphin
  • Loc: Windsor, Ontario, Canada
Posted 13 February 2018 - 07:40 PM
Why not try using JPEG files instead of raw?
#5 Michael Covington
Michael Covington
    Author
Posted 13 February 2018 - 08:42 PM
Astronomical image processing (dark frame subtraction, etc.) cannot be done with JPEGs.
#6 Jeffmar
Jeffmar
Posted 13 February 2018 - 11:01 PM
The ram I put in my mac is now 8 times as much as it was when new. I think that is the max. I also put in a 500 gig SS hard drive. Before the upgrade I could barely process one raw photo without having to get up and do something else while waiting for it to finish. Did you say you installed a second SS hard drive? How do you do that?
#7 Jeffmar
Jeffmar
Posted 13 February 2018 - 11:03 PM
Hard drive is 60% empty. Does PixInsight work on macs?
Edited by Jeffmar, 13 February 2018 - 11:43 PM.
#8 Michael Covington
Michael Covington
    Author
Posted 14 February 2018 - 12:08 AM
I believe so.  It is specifically for astronomy.  Learning to use it is non-trivial but worth it.
#9 bobzeq25
bobzeq25
Posted 14 February 2018 - 03:46 AM
PixInsight works on Macs.  I found this book to be the easiest way to learn it.
https://www.amazon.c...y/dp/3319256807
jpgs have been brought up.  jpg files are small because the data has been approximated.  That simply won't work for astrophotography, where you're sometimes dealing with extremely small signals.
  • Michael Covington likes this
#10 CableGuy
CableGuy
Posted 14 February 2018 - 07:14 AM
There is also a chance your computer is effected my some system robbing trojan, mail-ware, spy-ware. I am fairly sure Mac are not immune these things.
What are the specs of your MAC
#11 AbPho
AbPho
Posted 14 February 2018 - 07:28 AM
Photomatrix PRO is for editing HDR images.  Not sure how this is used for your astro images.
I run an iMac.  I was using a 2009 entry level model with 16GB of RAM.  I was running Photoshop and PixInsight on it.  No crashing.  Reinstall the OS and start fresh.  If that doesn't work then maybe your system is too old and it's time to upgrade.
  • Jeffmar likes this
#12 Jeffmar
Jeffmar
Posted 14 February 2018 - 07:20 PM
My Macbook pro is a 2011 model. I think I said 16MB of ram but I believe I should have said 16GB. I will try reloading the OS. I have also heard older machines do better with older operating systems. I might try reloading an older OS if I can.
#13 ismosi
ismosi
  • Loc: New London, Pennsylvania, USA
Posted 14 February 2018 - 09:03 PM
PixInsight is not supported on versions of OS X older than 10.10. It *may* run on 10.9 or 10.8 and will not run on 10.7 or older.
https://pixinsight.c...sreq/index.html
#14 AbPho
AbPho
Posted 14 February 2018 - 09:35 PM
I had a 2009 running OS X 10.12 (Sierra).  Jeffmar's 2011 Macbook Pro would be fine in that regard.
#15 KLWalsh
KLWalsh
  • Loc: North Georgia, USA
Posted 15 February 2018 - 10:00 PM
I'm pretty sure that Deep Sky Stacker will accept jpg files for flats, darks and bias frames. It seems to work when I've used it that way.
You lose some gray scale resolution with jpgs vs raw; and you can dig a signal out of a raw file that might be lost in a jpg; but if the goal is to post the image on a social media site, it's going to have to be converted to jpg anyway.
#16 Jeffmar
Jeffmar
Posted 16 February 2018 - 01:12 PM
Thanks everybody for your ideas. Occasionally I wonder why I keep doing the astrophotography thing. Nothing is particularly easy about this hobby. Constraints of time, technical issues, freezing cold, light polluted neighborhoods, and atmospheric conditions to name a few problems make astrophotography challenging to say the least. Oh, I forgot the steep learning curve of this activity.undecided.gif
Now and then I get some really nice photos I can be proud of. It is a bit like the lure of slot machines. That intermittent reward really pulls us in.grin.gif
#17 AbPho
AbPho
Posted 16 February 2018 - 01:25 PM
Depressing isn't it
#18 CableGuy
CableGuy
Posted 16 February 2018 - 06:04 PM
You can ship all of the following equipment to me;
C11 edge and a vintage C11
C8 edge and an Orion 80mm ED refractor
CGEM and a CGX mount on a CGE pro tripod
Some Pentax, Teleview, and various plossl eyepieces with a few barlows
Orion binoviewer with 20mm 66 degree eyepieces
Two Alpen 8x42 binoculars
Sony A7m2 camera which is a pretty decent astrophotography camera
Adjustable astronomy chair from Orion
and you will not have to worry about being down anymore.
#19 Jeffmar
Jeffmar
Posted 18 February 2018 - 01:18 PM
