DeBayerization: VNG or AHD?
7 replies to this topic
#1 MCovington
MCovington
  • Loc: Michael Covington - Athens, Georgia
Posted 13 February 2018 - 11:57 PM
Particularly in PixInsight, which do people prefer?
#2 Jim Waters
Jim Waters
  • Loc: Phoenix, AZ USA
Posted 14 February 2018 - 12:25 AM
I have the same question.  Is there a good review of each and the pro's / con's?
You may want to post this in the PixInsight Forum.
  • cobestluc likes this
#3 whwang
whwang
Posted 14 February 2018 - 12:46 AM
It will be the best if someone can stack a bunch of raw images of reasonable quality with VNG and AHD, and compare them.
I had compared DSS Bayer drizzle, DSS AHD, Nebulosity VNG, PI VNG, and PI Bayer drizzle.  For image sharpness and noise correlation between pixels, for a scale from 0 to 10, 0 being bilinear, and 10 being the best I have seen, I would rate as following:
DSS Bayer drizzle: 10
PI Bayer drizzle: 9.5
PI VNG: 9.0
Nebulosity VNG: 8.0
DSS AHD: 6.5
bilinear: 0
All of them are substantially better than bilinear.  PI's VNG does remarkably well and can give results almost as good as Bayer drizzle, at least in my cases.
However, I have a feeling that PI's VNG is somewhat better than Nebulosity's VNG.  So probably even with the same algorithm (VNG), different implementations can give you different results.  Because of this, there is a possibility that PI's AHD is better than DSS's AHD.  I can't tell since I have never tried AHD in PI.
Personally I use PI's VNG as default, and only switch to PI's Bayer drizzle when the images are taken under exceptionally good conditions and when I absolutely want the highest resolution.  PI's VNG is much faster than its Bayer drizzle, and can give very good results.
Wei-Hao
Edited by whwang, 14 February 2018 - 12:46 AM.
  • AbPho likes this
#4 MCovington
MCovington
Posted 14 February 2018 - 05:39 PM
The background is that I have my own version of the PixInsight BatchPreprocessing script with a few functions added.  I am wondering if I should put AHD on the menu (for some reason it is not there; VNG is the default).
#5 whwang
whwang
Posted 14 February 2018 - 09:07 PM
Interesting.  I had the impression that AHD is there, but when I open my PixInsight BPP, I do not see it either.
  • MCovington likes this
#6 sharkmelley
sharkmelley
Posted 15 February 2018 - 01:55 AM
It's definitely worth making AHD available.
However, I use bayer drizzle - it avoids artifacts in regions of high contrast - especially around stars.
Also, take a look at Juan's recent comments on the demosaicing in the libraw replacement for dcraw:
https://pixinsight.c...g74359#msg74359
By the way, demosaicing is the word that PixInsight will using in future instead of debayer (which now has connotations of physically stripping the CFA layer off a sensor to make it monochrome).
Mark
Edited by sharkmelley, 15 February 2018 - 01:56 AM.
#7 xiga
xiga
  • Loc: Northern Ireland
Posted 15 February 2018 - 03:48 AM
You should download the trial version of Astro Pixel Processor. It has a special demosaicing algorithm called Adaptive Airy Disc (AAD). The author swears that it gives superior results to any other algorithm out there.
https://www.astropix...nique-features/
#8 17.5Dob
17.5Dob
  • Loc: Colorado,USA
Posted 15 February 2018 - 08:22 PM
Another vote for Bayer Drizzle in PI
