Coming Soon: nFRAME camera rotator
22 replies to this topic
#1 rigelsys
rigelsys
    Vendor (Rigel Systems)
Posted 16 February 2018 - 11:36 PM
For light imaging systems.  Design is coaxial and square with the focuser eyepiece tube.  Target price <  $250.   Attaches to most focusers with eyepiece lock ring flange.  nFRAME controller (sold separately) uses same electronics as our usb-nSTEP with a "framing" firmware load.  Uses same stepper as our usb-nSTEP which means stepper can be swapped between focusing and framing with a simple change of the gear.   Interested?  Please drop me a e-line at rigelsys@cox.net
Here's a link to a short quicktime video of the nFRAME in motion.
http://rigel.datacor...ys/nFRAMEm2.mov
  • Ricky, ChrisMoses and nathmath like this
#2 psandelle
psandelle
  • Loc: Los Angeles
Posted 18 February 2018 - 10:37 PM
Will you be able to control focus and rotator motors with one controller? I seem to recall that at one point you added two focuser capabilities to the controller.
looks very cool!
Paul
#3 rigelsys
rigelsys
Posted 20 February 2018 - 04:44 PM
We have a
looks very cool!
Paul
We have a controller in the works that will be able to control both a focuser and the rotator :-), or alternatively two focusers, or two rotators (think about that one).  Will also have handbox with pushbuttons and wifi.  Once we have a measure of interest.
Edited by rigelsys, 20 February 2018 - 06:15 PM.
  • psandelle and ChrisMoses like this
#4 darkstar3d
darkstar3d
  • Loc: Metro Atlanta
Posted 20 February 2018 - 04:50 PM
Nice! I’m interested!
Sent from my iPad using Tapatalk
  • Denimsky likes this
#5 rigelsys
rigelsys
Posted 20 February 2018 - 06:26 PM
The heart of the mechanics is the gear attached to a 2 "T-adapter" with 42mm thread for direct attachment to a DSLR T-ring or direct to a 42mm T2 compatible filterwheel or imager.  The T-Adapter provides coaxiality within the eyepiece draw tube and keeps the camera square-on with the focuser.  Pretty simple solution.  Beyond that the screws on the back tighten the teflon ring for tension on the gear for drag as as well as supporting the camera weight.  To attach to the focuser, assumes focuser has set-screw flange (most do) and thumbscrews capture the flange on the outside, with the T-adapter on the inside, provide very rugged attachment.  So in terms of components, its simple, durable and cost effective.  We use the same stepper as on the nSTEP focuser kits so that's interchangable.
Edited by rigelsys, 20 February 2018 - 06:26 PM.
  • darkstar3d likes this
#6 darkstar3d
darkstar3d
Posted 20 February 2018 - 07:33 PM
Both of my Focusers are Moonlites so I hope that I’m covered. Lol
Sent from my iPhone using Tapatalk
#7 Dunkstar
Dunkstar
  • Loc: Brisbane, Australia
Posted 21 February 2018 - 07:50 AM
Any option for the scope side connection to be M48? Many flatteners and coma correctors for imaging present this connection towards the filter wheel/camera.
  • psandelle, darkstar3d and ChrisMoses like this
#8 rigelsys
rigelsys
Posted 21 February 2018 - 01:02 PM
M42 female to m48 male adapters are readily available, such as this one.
http://www.scopestuff.com/ss_4248.htm
#9 Dunkstar
Dunkstar
Posted 22 February 2018 - 05:22 PM
Thanks for your reply.
M42 is OK, so long as both sides of the rotator use M42. My field flattened presents M48 male which I can reduce to M42 male.
#10 rigelsys
rigelsys
Posted 22 February 2018 - 05:57 PM
photo shows my Canon T-adaptor on it, remove that and its m42 male underneath :-)
  • psandelle likes this
#11 Dunkstar
Dunkstar
Posted 22 February 2018 - 07:26 PM
Cool! How about the other side? How is it connected to the Baader focuser?
#12 Stelios
Stelios
  • Loc: West Hills, CA
Posted 24 February 2018 - 02:06 AM
I’d be interested depending on price, weight capacity (must handle asiI1600+EFW8+OAG) and features.
#13 rigelsys
rigelsys
Posted 28 February 2018 - 07:12 PM
4 thumb screws catch the lip of the flange on the outside, T-adapter tube captures the inside.  Firm attachment.
  • Dunkstar likes this
#14 rigelsys
rigelsys
Posted 15 August 2018 - 11:23 PM
Modified hardware, moved cable socket on stepper to reduce length,  attached to a 2" Celestron visual back I found that has a flange,  prototyped the nFRAME electronics -- box uses one usb port, incorporates both nSTEP focus control and nFRAME rotation control.  Now have rotator under software control :-)
  • Stelios and OleCuss like this
#15 ChrisMoses
ChrisMoses
  • Loc: Fort Wayne, IN, USA
Posted 21 August 2018 - 10:49 AM
I'm very interested. Keep us posted.
#16 rigelsys
rigelsys
Posted 07 September 2018 - 04:56 PM
production version completed. Machined out of Delrin (slick surface and easy to machine). This one shows fittings to accommodate a 2" tele compressor, also will have one that supports 2" m48 attachments. Software is moving along, already ASCOM compatible, working with SGP.  Some more polishing to be done on the functions.  Should be out for testing in a few weeks!
Edited by rigelsys, 07 September 2018 - 04:57 PM.
#17 rigelsys
rigelsys
Posted 12 September 2018 - 01:47 PM
SW is ready for testing (I have two volunteers to send out test sets to :-)  Here's what it looks like, running in parallel with an nSTEP app.  Displays position in degrees, 5 stored goto positions available,  can goto an entered position,  use in/out buttons to move 1 deg,  use Cin/Cout buttons to move until unpressed.  Rotary deg position dial display. ASCOM complaint, checked out with SGP.
#18 tjay
tjay
  • Loc: just outside of Toronto
Posted 12 September 2018 - 05:55 PM
Would this be able to be used as a derogatory for alt-az setups?
Sent from my SM-T713 using Tapatalk
#19 rigelsys
rigelsys
Posted 18 September 2018 - 12:04 PM
Hi Tom,
Haven't worked the software for that yet ... its a thought.
#20 tjay
tjay
Posted 18 September 2018 - 06:01 PM
Autocorrect on my tablet change derotator to derogatory. :(
#21 rigelsys
rigelsys
Posted 20 October 2018 - 09:47 PM
Our field tester has it running under SGP getting great results as described in his lectures at the IAS show in UK earlier this month.
https://www.cloudyni...-was-a-success/
for a look at his slides.
#22 Carl N
Carl N
  • Loc: San Diego, CA
Posted 16 November 2018 - 09:26 PM
How much backfocus will this take up? For a CCD/FW/OAG setup I am already tight. Putting this after the Field Flattener will probably not work.
#23 rigelsys
rigelsys
Posted 21 January 2019 - 06:39 PM
In production :-)  See attached photos.  Introductory price for the usb-nFRAME + Frame rotation hardware and stepper is $599.95.  Note the usb-nFRAME will run both the framing stepper AND a focus stepper (either ours, or any robofocus/moonlite compatible unipolar stepper).  So you can have both focusing and framing in one package.
Special offer, if you have a usb-nSTEP basic (PC only), you can send it in and we'll apply the full purchase price against the usb-nFRAME ($599.95 - $147.95 = $452)  as we'll pull the circuitry out of your usb-nSTEP basic and incorporate it into your  usb-nFRAME.
The nFRAME hardware comes native with an SCT (Celestron or Meade) compatible nosepiece for direct mounting to an SCT.  We also include a 2" to SCT male adapter that threads into the nosepiece for use with standard 2" focusers.
On the backside the nFRAME accepts the M54 thread common for many field flatteners. But to expand the universe we include an M54 to M48 male adapter for field flatteners that can be unscrewed from their nosepieces,  and/or direct connect to your camera stack.
The nFRAME adds about 53mm length to your imaging stack.
For more info, drop me an e-mail at rigelsys@cox.net
thank you for your support!
