8" mirror cell
20 replies to this topic
#1 airbleeder
airbleeder
  • Loc: Powder Springs, Georgia
Posted 23 February 2018 - 12:25 AM
   Does anybody have a drawing for a primary cell they wouldn't mind sharing? I have an 8"f6 sonotube dob, 9"ID. If I use a 1" bottom plate mounted to the 4 existing holes on the ota and an 3/4" top plate, I can keep focus where it is and should help with balance. A shop will cut it from aluminum, but I will do the rest. I will appreciate any help I can get. Thanks.
Edit: It's a full thickness mirror.
Edited by airbleeder, 23 February 2018 - 02:56 AM.
#2 Dale Eason
Dale Eason
  • Loc: Roseville,Mn.
Posted 23 February 2018 - 12:29 AM
Look for the program called PLOP on the net.  It will design the parts for you based on your input.  It runs on windows machines.  If you can not run it or don't understand it then someone could do the design for you.
Dale
  • airbleeder and Augustus like this
#3 airbleeder
airbleeder
Posted 23 February 2018 - 03:06 AM
   Thanks, I have played around with it some, but it was just play. I will see what I can do with it.
#4 John O'Hara
John O'Hara
  • Loc: Oil City, PA
Posted 23 February 2018 - 05:54 AM
Here's a simple one from Gary Seronik,  a well known telescope maker and long time columnist for Sky and Telescope:
http://garyseronik.c..._making/page/3/
#5 Pinbout
Pinbout
  • Loc: Montclair, NJ
Posted 23 February 2018 - 07:49 AM
https://www.youtube....xUKvZWWOhqaMXFT
  • airbleeder likes this
#6 airbleeder
airbleeder
Posted 23 February 2018 - 08:13 AM
   Thanks Danny. Great video. I couldn't sleep last night, so I will watch it more tomorrow after I've slept tonight. I'm dumb enough with a good night's sleep.
#7 calypsob
calypsob
  • Loc: Lynchburg, Virginia
Posted 23 February 2018 - 03:36 PM
is Garys mirror cell suitable for an imaging newtonian?  Ive wondered if it creates a stresspoint in the middle
#8 John O'Hara
John O'Hara
  • Loc: Oil City, PA
Posted 23 February 2018 - 07:05 PM
I'd thought that visual use is even more demanding.  I'm not knowledgeable concerning imaging requirements as I'm strictly a visual observer, so I could be wrong.
  • calypsob likes this
#9 John O'Hara
John O'Hara
  • Loc: Oil City, PA
Posted 23 February 2018 - 07:09 PM
Giving it some thought, where imaging may be more demanding is in the need to maintain focus for a prolonged period while CCD exposures are being made.  A wooden cell may be more subject to expansion and contraction than a metal cell, causing focus shift.  This would not be important visually.  As far as stress on the mirror, I'm not sure why imaging would be more affected by stress induced aberrations than would the visual image.
Maybe someone with imaging experience can chime in.
Edited by John O'Hara, 23 February 2018 - 07:25 PM.
#10 Pinbout
Pinbout
Posted 23 February 2018 - 07:13 PM
here's my 8in cell for my f.35
https://www.youtube....8rBwA&index=100
  • calypsob and airbleeder like this
#11 calypsob
calypsob
Posted 23 February 2018 - 07:18 PM
Giving it some thought, where imaging may be more demanding is in the need to maintain focus for a prolonged period while CCD exposures are being made.  A wooden cell may be more subject to expansion and contraction than a metal cell, causing focus shift.  This would not be important visually.  As far as stress on the mirror, I'm not sure why imaging would be more affected by such inducted aberrations than would the visual image.
The star field has to be flat and round for a camera sensor, aberration correction is extremely critical with astrophotography if you are sampling the pixels properly.  If undersampling, there is a small amount of leway.  Focus shift could be an issue, it depends on how lucidly it occurs.  With short exposures it may not be a problem at all.   I have been wanting to try Garys design on a small astrograph which is why I wanted to ask.  I am thinking that I might be able to use a larger sphere on the back and create a less localized point of pressure.
Edited by calypsob, 23 February 2018 - 07:20 PM.
  • John O'Hara likes this
#12 John O'Hara
John O'Hara
  • Loc: Oil City, PA
Posted 23 February 2018 - 07:25 PM
Makes sense.
#13 airbleeder
airbleeder
Posted 24 February 2018 - 09:57 AM
   I like that cell. I could probably have it cut from aluminum stock. Would it need to be 6point or would a 3point be sufficient for an 8" f6? Do you allow any clearance between the back plate and inside of OTA or is a snug fit best? Thanks. That's very helpful.
Edited by airbleeder, 24 February 2018 - 10:00 AM.
#14 Pinbout
Pinbout
Posted 24 February 2018 - 10:30 AM
imagine this with 1/4" alum plate instead of 1/2" ply
6 is always way better than 3, but oddly enough its also better than 9.
my 6in cell up close an personal
https://www.youtube....h?v=NT525eWG-ek
Edited by Pinbout, 24 February 2018 - 10:32 AM.
  • plyscope, John O'Hara and airbleeder like this
#15 airbleeder
airbleeder
Posted 24 February 2018 - 12:07 PM
    You have a point there. I was planning to use thicker stock for added weight to lower the eyepiece height, so I can observe seated if possible, but using 1/4 would allow me some room for cell location since I will need to drill a couple more holes into the OTA anyhow (4 to 3).
   Should my edge supports work out well on the angles I use for the clips? Maybe use nylon screws to attach the clips and also serve as edge supports?
   In your picture, I'm also guessing those are nylon capheads you used for pads? I believe that cell is perfect if I can get all the dimensions straight in my head so I can get it drawn for cutting and do my part correctly. You always do some fine work. It must be nice.
   Once I get the plans to my man it will probably take him a while to cut, so I will try to build a ply mounting plate for use while I wait on him.
   Edit: Don't know what I was thinking in that second sentence.
Edited by airbleeder, 24 February 2018 - 11:11 PM.
#16 Pinbout
Pinbout
Posted 24 February 2018 - 12:12 PM
si
si
#17 NHRob
NHRob
  • Loc: Southern Cloud-Hampshire
Posted 24 February 2018 - 07:07 PM
1/4"is pretty thin stock.  Do you find it is thick enough to avoid any flexure?
#18 Pinbout
Pinbout
Posted 24 February 2018 - 09:47 PM
1/4" looks pretty thick to me. how much does the mirror weigh? not that much and the 3 bars are out of 1/8"
but if you have to 3/8" would be better than 1/2". 1/2" is where I'd start using tube.
http://www.aurorap.c... sheet rev4.pdf
the brackets are drawn ~ same as the plate...those brackets are 1/4" thk
#19 airbleeder
airbleeder
Posted 24 February 2018 - 11:49 PM
   I don't know what weighs, no scale but it's 1.25" thick. I'll probably go with the 1/4" stock then. No doubt you know more than I do.
   I hope I can get the drawings to him this week, but there's no telling when he will cut it because he only does bigger contract work. Doing me a favor so I'll just take it to him and get it whenever.
#20 Pinbout
Pinbout
Posted 25 February 2018 - 09:41 AM
just cut it with a jig saw, the only real critical parts of a cell are the hole locations and even then only the mirror supports are critical...kind of.
print it out and spray mount the drawing to the alum. leave center marks for the holes and center punch them before you drill them.
you don't even need a drill press. but a bandsaw helps.
#21 airbleeder
airbleeder
Posted 25 February 2018 - 10:32 AM
    Wouldn't hurt to try it. I have a jig saw and drill press I picked up at yard sales. They aren't the best, but they operate ok. Do a practice run with some ply and existing back plate, see how that goes.
  • Pinbout likes this
