Affordable "Finder" EP
20 replies to this topic
#1 ksmokratur
ksmokratur
Posted 23 February 2018 - 02:02 AM
I am looking for an EP with a max true FOV at a reasonable price; it is expected to be mostly a slightly wider "finder" EP since I already have a 35 Pan that I enjoy.  A secondary use will be for a youngster to have a wide EP to play around with without risking destroying Daddy's $400 Panoptic.
Two "cheap" candidates I've found are the ES 40mm 68 and the Orion 38mm Q70.  I note Tele Vue offers a 55mm Plossl, and I have a lot of TV product, but I'm hoping to save a few dollars here if I can.  Thank you all for any advice.
#2 Shneor
Shneor
  • Loc: Northern California
Posted 23 February 2018 - 02:15 AM
If I read you correctly, you are talking a 2" eyepiece. There are a number of Widescan II/III clones out there - 30mm with a 70* apparent field, usually around $50-70 used. A number of dealers carry them. Since you don't mention the telescope you intend the eyepiece for, I should warn you that depending on the telescope, you might notice moderate distortion toward the edge of the field.
#3 Redbetter
Redbetter
  • Loc: Central Valley, CA
Posted 23 February 2018 - 02:31 AM
What scope will it go into?   An f/10 is a whole different matter than f/5, and whether or not it is a reflector, SCT/MCT, or refractor is also relevant.
For long ratios the 56mm Meade Plossl would be the widest true field with a well corrected eyepiece at reasonable cost.  I don't believe the functionality will be as good as the 55 TV because the housing doesn't appear as well engineered for adjustable eye placement.  I haven't used one though so I don't know if that is true.
Edited by Redbetter, 23 February 2018 - 04:57 AM.
  • jallbery likes this
#4 starbase25
starbase25
Posted 23 February 2018 - 04:03 AM
If you want a bit more field than your 35mm Panoptic, the 40mm ES 68 fits the bill nicely. Mind you, it is a bit of a HEAVY beastie.
  • Jon Isaacs and Piero DP like this
#5 izar187
izar187
  • Loc: 43N
Posted 23 February 2018 - 05:48 AM
http://www.russell-o...m/two_inch.html
  • OneGear likes this
#6 Adun
Adun
Posted 23 February 2018 - 05:49 AM
You mention the TV 55.
What about the Meade 56mm Super Plössl?
#7 russell23
russell23
  • Loc: Upstate NY
Posted 23 February 2018 - 06:31 AM
A lighter and less expensive option is the 40mm ES62.
#8 Jon Isaacs
Posted 23 February 2018 - 07:10 AM
If you consider the ES 40mm 68 degree as "cheap", then I say go for it.  It's about as close to the 41mm Panoptic as you'll get.  I see that High Point has it listed for $248.
https://www.highpoin...0hoC0awQAvD_BwE
Otherwise, as others have asked, what scope will this finder eyepiece be used with it?
  • faackanders2 likes this
#9 junomike
junomike
  • Loc: Ontario
Posted 23 February 2018 - 07:29 AM
If used in a faster OTA than F7 I'd opt for the ES 40 68, however in an F8 OTA or SCT you can get away with the Orion 38mm Q70 or a 40mm SWAN.
#10 Jim Davis
Jim Davis
  • Loc: Lewisberry, PA
Posted 23 February 2018 - 08:39 AM
I use the William Optics 40mm SWAN. Nice eyepiece for the price. Also much lighter than an ES 40mm.
#11 drneilmb
drneilmb
  • Loc: Decorah, IA, USA
Posted 23 February 2018 - 11:22 AM
If you wear both a belt and suspenders, then maybe you can carry the ES68 40mm in your pocket after you get a screaming deal on a refurbished one: https://www.ebay.com/itm/362224484712
#12 Jon Isaacs
Posted 23 February 2018 - 11:44 AM
Scopehed1 is the EBay store for Bill Vorce who runs the Telescope-warehouse.  Bill's been around forever and he's now an authorized Explore Scientific dealer and handles their refurbished eyepieces.
That is a screaming deal.
  • Jaimo! and Sarkikos like this
#13 Sarkikos
Sarkikos
  • Loc: Per sylvam ad astra
Posted 23 February 2018 - 01:40 PM
That's a great price.  I was thinking about snagging it if I didn't already have a 41 Pan, and especially if the ES were lighter.  But according to the specs I see, the ES is actually about the same weight, if not a couple ounces heavier.
#14 Jaimo!
Jaimo!
  • Loc: Exit 135 / 40° North
Posted 23 February 2018 - 02:29 PM
Not to go off course, but elaborate on Jon's advise...  I have recently picked up an refurbished 8.8mm Explore Scientific 82° from Bill at Telescope-warehouse.  I cannot tell any difference between the refurbished eyepiece and those I paid full price, except some of the serial numbers have been removed.
There has been a recent active thread on the refurbs.
He also offers the older style 30mm ES82 for $125...
Jaimo!
  • Jon Isaacs and Sarkikos like this
#15 Sarkikos
Sarkikos
Posted 23 February 2018 - 02:44 PM
Great deals on ES ... if I didn't already have the equivalent TV.
#16 ksmokratur
ksmokratur
Posted 23 February 2018 - 09:44 PM
Thanks for the food for thought, everybody. I should have said "cheapER" now that I look back.  I don't currently have a 'scope faster than f/7 so it seems like any of these work.  I do really like those Pans and it sounds like the consensus, all weight being equal, is that the ES comes the closest.  I'm still open to more thoughts, though.
#17 Mark9473
Mark9473
  • Loc: 51°N 4°E
Posted 25 February 2018 - 11:51 AM
An f/7 focal ratio doesn't sound critical.
In my 80 mm f/7 apo, I absolutely love my TS 26mm Erfle eyepiece, which I believe is a clone of the Q70.
In a slower scope like my Mewlon, my favourite is the 35 mm Paragon that TS still sells new (I think Astronomics discontinued them).
You still haven't said which scope(s) so I think it's hard for most posters to give more specific advice.
#18 lylver
lylver
  • Loc: near Geneva but in France
Posted 25 February 2018 - 11:54 AM
As I just bought it : Ostara 38mm 70° : it is an erfle II similar to any 70° 2-1-2 modern EP (500g)
#19 Mark9473
Mark9473
  • Loc: 51°N 4°E
Posted 25 February 2018 - 01:09 PM
That looks like another Q70 clone.
#20 gezak22
gezak22
  • Loc: On far side of moon. Send help.
Posted 25 February 2018 - 03:55 PM
I was pretty happy with my 40mm tmb paragon.
  • Sarkikos and junomike like this
#21 CollinofAlabama
CollinofAlabama
  • Loc: Lubbock, Texas, USA
Posted 01 March 2018 - 01:00 PM
I really like my ES 28mm 68* eyepiece.  This one is great, but at greater than F/7, you can certainly get a longer F/L eyepiece.  For me, I've settled on the GSO 42mm SuperView.  I'm not entirely happy with it.  Although they claim it is 65*, it's really more like 57*, and acts more like a plossl.  However, weight is a a stickler for me, and I don't want anything heavier than about a pound in my refractor diagonals, so ...  The GSO SV 42mm is über cheap, and weighs less than the ES 28mm 68*.  Still, the image doesn't really grab me like the ES 28mm.  It's just kind of plain-plossl-looking.  Still, if you just want to see as much sky as can fit in your scope, the GSO 42mm SV is hard to beat.  I find it fairly well corrected, certainly to 55*, and that's the vast majority of its field.  Just don't expect a lively view.  Your Pan 35 will beat it, and probably somebody's ES 34mm 68*, too.  That one would be worth considering, but it, too, is quite a bit heavier, like the Pan 35, so it's the SV for me.  Good luck
