First light with ZWO ASI-183
10 replies to this topic
#1 andysea
andysea
  • Loc: Seattle, WA
Posted 23 February 2018 - 10:14 AM
Here is my first attempt at using this camera.
104x120s L, 30x120s RGB. All done at gain 53.
The luminance was done during a very hazy night hence the halos around the bright stars.
I will experiment with different gain settings as there is some banding, even tho I dithered every 4th frame.
Please note that the image is reduced by 40%. I usually don't post full resolution files.
https://www.flickr.c...341865/sizes/o/
Edited by andysea, 23 February 2018 - 10:15 AM.
  • Stelios, rwstanley, DaveB and 13 others like this
#2 BenKolt
BenKolt
Posted 23 February 2018 - 11:30 AM
Great first light, Andy, and congratulations!
Could you please remind me what scope you are using with that camera?  Thanks!
Best Regards,
Ben
#3 andysea
andysea
  • Loc: Seattle, WA
Posted 23 February 2018 - 11:52 AM
Best Regards,
Ben
Thank you Ben.
I used the Vixen R200SS with the Vixen corrector PH. I'm waiting for some parts to arrive, in order to make a few improvements to the mirror cell. I think it's a good scope but it probably needs a more rigid tube.
#4 rockstarbill
rockstarbill
  • Loc: Snohomish, WA
Posted 23 February 2018 - 09:52 PM
Any tilt issues?
#5 andysea
andysea
  • Loc: Seattle, WA
Posted 23 February 2018 - 11:36 PM
Any tilt issues?
No I don't think it's tilt but I would have to test it with the Canon 6D. I think I see some difference in the star shape after a meridian flip.
The mirror is held in place by three rubber clips along the front edge and there are also three set screws on the side that I think are used for centering it.
There are actually six threaded holes in the mirror cell to hold the mirror along the edge. I have ordered six new set screws with a nylon tip, in order to distribute the pressure more evenly along the edge.
With respect to addressing the potential flex in the tube, I might have to order a carbon fiber tube from Germany. I haven't decide if that is really necessary tho.
#6 Peter in Reno
Peter in Reno
  • Loc: Reno, NV
Posted 23 February 2018 - 11:46 PM
What is the OTA tube made of? Aluminum? Steel? Fiberglass?
What is the back focus requirement for Vixen corrector PH?
Peter
#7 andysea
andysea
  • Loc: Seattle, WA
Posted 23 February 2018 - 11:49 PM
Peter the tube should be aluminum. The back focus for the corrector PH is 56.5mm.
#8 Peter in Reno
Peter in Reno
  • Loc: Reno, NV
Posted 24 February 2018 - 12:56 AM
Thanks Andy. That back focus is pretty tight for an imaging train containing filter wheel, OAG and camera.
I would start working on the mirror cell before upgrading the tube. Either way, so far your images have looked great. Your NGC 2903 looks much better than mine.
Peter
#9 andysea
andysea
  • Loc: Seattle, WA
Posted 24 February 2018 - 01:15 AM
The backfocus is fine. What I notice is that the stars, right after the meridian flip have a slightly different shape than before. That leads me to believe that there is something that is shifting or flexing.
#10 Kirek
Kirek
    Deerlick Astronomy Village
Posted 25 February 2018 - 04:54 PM
Nice shot. What LRGB filters did you use? Looking at  this camera, and also  new larger filters. Don’t think my 1 1/4 filters will cut it :-)
#11 andysea
andysea
  • Loc: Seattle, WA
Posted 25 February 2018 - 09:57 PM
I think that 1.25” should work. The sensor is pretty small. I used 31mm unmounted astrodon because I already had them.
  • AstroCatinfo likes this
