Post a pic. of your observatory!
1529 replies to this topic
#1426 Sketcher
Sketcher
  • Loc: Under Earth's Sky
Posted 31 March 2019 - 05:22 PM
Here's a picture of my (old) roll-off-roof observatory.  This is a recent photo, taken in March 2019; but this observatory hasn't been used in a while.  My wife says I haven't used it in 10 years.  She could be right!  Before making it a two-story structure, Halley's Comet was observed from within the same (though lower) walls.
Before building (or more precisely, remodeling) it, my wife wanted a storage shed.  I wanted an observatory.  A compromise was reached.  The lower floor is a storage shed (my snow plow, among other things, live there).  The upper level is an observatory -- built with low-magnification comet-hunting in mind, so there was no need for a firmly-rooted pier.
The name, "Rattlesnake Observatory", was earned one night when I disturbed a rattlesnake as I ran from the observatory to the house to grab a few items -- a small price to pay for a dark sky. smile.gif
Sketchers Roll Off Roof Observatory 2
This next picture is the structure I refer to as "The Colosseum".  It's a versatile, open-air observatory.  I keep it clear of snow and ice, so it's open for use on any clear night  -- with any telescope I care to make use of.
Sketchers Colosseum Open Air Observatory 2
Both photos were taken on the same date; but I don't recall just how old either structure is.  We've lived here a while! smile.gif
  • R Botero, elmiko, niteskystargazer and 4 others like this
#1427 Ettu
Ettu
  • Loc: 45N90W Wisconsin USA
Posted 02 April 2019 - 11:36 AM
I recently posted the following elsewhere in a different topic, but it seems more appropriate here with everyone else's, So, Posted here with better explanations and eliminated unnecessary pictures
I built this for visual, for under $2,000. Including the PV. But I had to provide all the labor.
It was originally intended for a 16" dob with the possibility of a  20", but as you'll notice I ended up with a 14" SCT. Which it also works well for.
I specifically wanted to address several problems that I saw with my friends ROR
1: It got too hot inside - especially the big Dob mirror. So this is more open to natural air flow than usual, The two main features being a gap slated floor and an unusually overhung roof to protect a full length under eve's gap, well recessed and screened, that is resistant to even driven rain and snow.
2:Seemed like wasted space where the ROR went. So I added the "extra" structure. Much appreciated storage, and a dew protected area..
3: With a traditional 4' wall to the south, I couldn't see many important objects, such as the Trifid or Lagoon, or anything else below Dec -15. That had to change, or it wasn't worth it, hence the doors instead of a wall to the south, Strategically placed to afford minimum visual interference when in use.
4: I couldn't afford to get power to it at a reasonable cost, PV was cheaper, so had to be figured in. Later, I did bring electric to it, but it was added convenience not necessity
5: Ground thermals are often a problem with Dobs, causing self inflicted poor seeing, so I wanted above avg height from the ground. The open doors and slated floor drain and eliminate all thermals.
6: Many traditional ROR's have part or all of the south end triangle as a necessary structural component, which means it shears off anything inside that sticks up much beyond wall height. that had to change. Latter needed for the SCT anyway. Also with clear span head room, I could lower the side walls on which the ROR rode, making more sky available for a floor mounted dob.
7: I also put part of the side wall as part of the roll off roof, again helping lower the side walls for more available sky E & W
8: I wanted tracks that would be impervious to ice or snow, so shielded, underslung, "barn door" tracks, which I'm familiar with, were a necessity.
  • tim53, CounterWeight, elmiko and 4 others like this
#1428 Ettu
Ettu
Posted 02 April 2019 - 12:11 PM
This is my photographic observatory,
It cost me less than $1000 for the wood, siding, anchorage, and hardware. I built it myself. Quite simple, pretty self explanatory, easy to do.
It cost a little more than another $1000 for trenching in 250' of electric supply,  internal wiring, breakers, outlets, grounding, and lights. It's open enough that I did much of my Astronomy League Binocular and other open sky programs from here while photo's accumulated.
It's an 8'x8' "observatory" area. If I had it to do over again I Might go 9x9. In either case, for best utilization, offset the pier toward the front as far as reasonable.
The storage room is 8x4. It's okay but If I did it again, I'd make it 8x6, maybe more. I originally intended to use that area as a warm room, but it is just easier and more practical to set up a table directly in the 8x8 area, (there's room) and if I want to be warm, remote operate from the house, with a web cam to keep an eye on things.
Keeps the wind off amazingly well, accept from the south, no problem cooling, plenty of open sky... more than the vertical wall config picture might appear to give. If it's calm out, then I can open the sides beyond vertical and have all the sky that's practical to photograph. When the walls are upright it helps surprisingly well against dew too (a problem here).
I keep my whole rig out here year round. I do put a small tarp over the rig and another over the  pc table when not in use, because hard wind driven rain or snow can get in.
I recently added some linear actuators for the 2 walls and end piece. So now I can remotely open and close it too.
It has and continues to serve me well. If anyone wants more detail feel free to msg me.
  • CounterWeight, elmiko, JonH and 4 others like this
#1429 PABresler
PABresler
  • Loc: Los Osos, Ca
Posted 07 April 2019 - 01:56 AM
I have a roll off shed in progress. It will be on a concrete slab with C channel tracks. I ordered a 7' x 7' Suncast plastic shed for about $700.00. The rest of the construction costs could hit $2000.00. I am getting too old to do the heavy work myself, just the design. Although not really essential, I am devising an electric cabling system to move the shed. I already modified a Harborfreight winch which cost me $50.00. I had to add a center wheel to separate the two cables. The concrete pier is done. I will use a Starizona adapter for a CGEM mount. I probably will use this mostly with a Bresser 152 mm. No cold or snow on central coast CA. although it can get foggy in summer. I was thinking of getting an electric blanket for the scope?
Peter
  • R Botero, elmiko, BKBrown and 3 others like this
#1430 kellyvictoria
kellyvictoria
Posted 07 April 2019 - 02:21 PM
That is quite a beautiful vista you have there. Breathtaking, enjoy ...
Edited by kellyvictoria, 07 April 2019 - 02:22 PM.
#1431 Lord Beowulf
Lord Beowulf
    Vendor - Orion Ranch Observatory
  • Loc: Cedar Park, TX
Posted 08 April 2019 - 05:31 PM
Hi Kelly,
Like your user pic.  I actually picked up a framed copy of that print about a month ago.  Still haven't gotten around to hanging it, but it's a great piece!  Also matches your comment!  =)
Beo
  • kellyvictoria likes this
#1432 kellyvictoria
kellyvictoria
Posted 08 April 2019 - 09:39 PM
Well, you have good taste.
Peter Taylor Quidley, born 1945, on Boston's Beacon Hill
American Portraitist, he is largely self taught.
vk
#1433 glencoe91
glencoe91
  • Loc: Long Island
Posted 15 April 2019 - 12:42 PM
observatory
Meade LX200 ACF 14"
Not my personal observatory or scope, but I am responsible for it now.  I have become very protective and attached to it this year.  Built in 1987 and ignored for a long time, the scope was replaced 6 years ago and sat unused till this past Sept.  Rebirth is a beautiful thing!
  • Cyrano, drprovi57, R Botero and 4 others like this
#1434 Stevegeo
Stevegeo
  • Loc: Otisco ny.
Posted 14 May 2019 - 07:24 PM
Added a couple of signs I picked up in Roswell NM  UFO museum for the door of my observatory named
Area 3751. ( The address of the observatory).
  • numchuck likes this
#1435 rgsalinger
rgsalinger
  • Loc: Carlsbad Ca
Posted 26 May 2019 - 06:36 PM
I wanted my own remote imaging observatory for about 20 years but I just moved around too much or was too busy to ever get it going. This year an old observatory came up for sale less than 100 miles from my house. The warming room roof had leaked and the contents were destroyed and full of mold. So, the renovation was too big a job for me at age 73 and I needed a contractor. You can see in the before image what this was like with the contractor working on clearing everything out. before.jpg
Here we are three months later getting the roof finally put on. The rain this winter was endless and the roof couldn't go on until the back room dried out. Observatory March 9.jpg
And here's resulting warm room about a month ago. Dog belongs to my partner. warm_room.jpg
Here are our two systems up and running for the first night together! This was just two weeks ago. That's an AP900 and a CEM120EC2.  two_scopes.jpg
We have room for more 2 more systems as well. This past weekend we automated the roof and got our weather system up and running.
Our last phase is to go off the grid with a solar powered battery system but already if there is power then I can image from home. I love it. The wife loves it.
Rgrds-Ross
  • R Botero, BKBrown, niteskystargazer and 3 others like this
#1436 Lord Beowulf
Lord Beowulf
Posted 30 May 2019 - 07:15 AM
Nice restoration.  Always good to see something put back to what it was for.  Looks like the warm room is larger than the observatory.  Kind of like a cabin for extended stays?
Beo
#1437 BuildsByBaz
BuildsByBaz
Posted 17 June 2019 - 05:25 AM
https://www.youtube....h?v=3JUhNFDsrWk
Johanna Griggs from Better Homes and Gardens doing a show on the new dome.
Edited by BuildsByBaz, 17 June 2019 - 05:27 AM.
  • Christopher Erickson, drprovi57, starbob1 and 10 others like this
#1438 GraySkies
GraySkies
  • Loc: Ontario, Canada
Posted 01 July 2019 - 07:04 PM
You can learn more about it here and check out some of my astroimaing now that I have a permanent base of operations!
http://www.emberskym...mporary-set-up/
  • BKBrown, KennFromTX and Cosmo Geezer like this
#1439 rgpalmer
rgpalmer
  • Loc: Pepin, Wisconsin
Posted 05 July 2019 - 07:41 AM
Very nice details. Where in Wisconsin are you.  I'm in Pepin.
#1440 ChrisWhite
ChrisWhite
  • Loc: Colchester, VT
Posted 13 July 2019 - 08:06 PM
Hey, I guess I can finally post mine here since it's complete!
Just built a small backyard obsy with a slide-of roof.  The build is here:  https://www.cloudyni...oof-obsy-build/
  • starbob1, jim kuhns, CCD-Freak and 8 others like this
#1441 jtsenghas
jtsenghas
  • Loc: The flatlands of Northwest Ohio 41.11N --Bloomdale
Posted 13 July 2019 - 11:19 PM
Neat! I see that having it slide perpendicular to the ridge that gives you a slightly lower available altitude angle in the roof direction than if the gable were closer. Good job!
  • ChrisWhite likes this
#1442 jshortt
jshortt
  • Loc: Eganville, Ontario
Posted 20 July 2019 - 01:29 PM
Here's the build thread for my observatory.
And here's a photo of what it looks like:
  • R Botero and Scott123 like this
#1443 TOMDEY
TOMDEY
  • Loc: Springwater, NY
Posted 22 July 2019 - 06:54 PM
DRONE CAM VIEDO OF MY DOME
Can be found here >>>
Many thanks to Matt Draper for deftly flying the drone, collecting the imagery, and compiling/editing the show!
https://www.youtube....h?v=9DUMPgsY0dw
I designed and built my 24-foot Geodesic Dome over several years circa 1990
>buy 16-acre ~Upstate New York~ remote rural hill land.... dark sky
>burn down old house and build new
>run 1200 feet 240 VAC to selected site, behind the house, up the hill
>observatory foundation
>deck
>walls
>dome
>clear several acres of woods from around dome
>turn into a grassy field
>build, install and enjoy 29-inch scope for 25 years
>commission and build 36-inch scope (New Moon Telescopes Structure, Ryan Goodson, with Normand Fullum Technofusion Mirror)
>successfully installed in 2018; spectacularly successful first light; works great!
DISCUSSION:
As you guys already know, that synopsis condenses a tremendous amount of effort, expense and dedication to successfully pull off. I had built myriad scopes and several observatories prior to and subsequent to the 24-foot dome / 36-inch scope. And that's my one prime recommendation to the ambitious builders among us --- start modestly and increment up to the bigger scopes and observatories. There's just no substitute for experience.
Anyway, the dome and scope are fully-operational and the views are indeed spectacular!
PS: Most people are startled that there would be any dark sky or decent observing in New York. But, as the video shows, New York is more than just NYC. "Upstate NY" comprises some sparsely-populated, decently dark hills... And the vegetation, with air flow under the elevated, ventilated domes... frequently delivers good sub arc-sec seeing. Just what you need to pounce on those Little Fuzzies!
Be sure to watch the video!    Tom
  • tim53, dmdouglass, niteskystargazer and 7 others like this
#1444 SeaLevelStarGazer
SeaLevelStarGazer
Posted 09 August 2019 - 03:16 PM
59747312_10213338169118542_5133052927417516032_n.jpg Still needs paint and SO many other things. But, it is operational. Broke ground on 1-20-19 and the dome was on the base on 4-20-19 !
I have many pics of my build on the FB page.
It was a great project. I have the templates for the dome sections if anyone is interested. The dome is 104 inches....
The metal tanks were here on the property when i bought it. a perfect base for the dome.....
If you have any questions, I will try to splain it...
  • Vesper818, R Botero, brave_ulysses and 5 others like this
#1445 Geo31
Geo31
  • Loc: Willis, TX
Posted 10 August 2019 - 04:48 AM
Very nice.  A link to your FB page would help.
  • SeaLevelStarGazer likes this
#1446 SeaLevelStarGazer
SeaLevelStarGazer
Posted 10 August 2019 - 10:46 AM
didn't think about it.
always looking for new members.
https://www.facebook...40629463331493/
Edited by SeaLevelStarGazer, 10 August 2019 - 10:47 AM.
  • dmdouglass likes this
#1447 TheRyanRanch
TheRyanRanch
Posted 20 August 2019 - 03:32 AM
In the process of building our Observatory as I'm typing ...
also, need to know where the pier gets mounted, is it in the middle of the nexdome ? Or offset ? Going to cut the concrete floor and isolate the pier concrete, from the main slab.
have a CGX-L, I own a CNC mill and will build and weld an aluminum adapter plate to 8” aluminum 1/4” wall tube. This will be my pier, but haven’t figured out the height yet
Edited by TheRyanRanch, 20 August 2019 - 03:55 AM.
  • tim53, R Botero, BKBrown and 6 others like this
#1448 trish.c.hamlin
trish.c.hamlin
Posted 25 September 2019 - 12:40 PM
Pretty cool roll off …
 https://www.icloud.c...MOV&sz=78916399
#1449 dmdouglass
dmdouglass
  • Loc: Tempe, AZ
Posted 25 September 2019 - 01:18 PM
Indeed. And well worth watching !
#1450 lesleyrgreen
lesleyrgreen
Posted 05 October 2019 - 12:14 AM
Just got the Sandhills SkyShed finished up this summer. Not nearly as impressive as those in this thread but still a permanent setup. Was able to take some pictures in 35mph winds the other day, which is about normal for western Nebraska.
More about it here https://lesleyrgreen.com
  • Cyrano, R Botero, BKBrown and 3 others like this
