Post a pic. of your observatory!
1707 replies to this topic
#1601 Rac19
Rac19
Posted 11 January 2021 - 10:13 PM
This is my cheap, mini observatory. It allows me to leave everything in place and preserve alignment between sessions. A major improvement over using a tripod.
Edited by Rac19, 12 January 2021 - 09:05 PM.
  • tim53, drprovi57, mikehager and 14 others like this
#1602 Scott123
Scott123
  • Loc: Maine
Posted 12 January 2021 - 06:03 PM
Put up in 2003 used until 2005
I took the Dome Down last year.
Did you build a new observatory? Sounds like there is a story here.
Scott
Edited by Scott123, 12 January 2021 - 06:03 PM.
  • John Rogers and LU1AR like this
#1603 NoDarkSkies
NoDarkSkies
  • Loc: Colorado City Colorado
Posted 12 January 2021 - 08:19 PM
Not really, I have to redo the Roof so I took the Dome off.
Also the more I think about it I will not put it back up at this location because of the Trains that go by.
So I hope to have it but back in operations by the end of this Summer at my new home it that all works out this spring.
#1604 tjay
tjay
  • Loc: just outside of Toronto
Posted 13 January 2021 - 01:28 PM
It occured to me that I didn't post a picture of my completed build, even though I posted a bunch in a dedicated thread.
Here's my completed observatory.  Now if I could just get some clear skies to use it.  We've only had a few clear nights since mid Nov when I got the scope setup in there :(
Complete!
Scope moved in!
  • John Rogers, R Botero, BKBrown and 6 others like this
#1605 Rac19
Rac19
Posted 15 January 2021 - 09:18 PM
Sone basic design info for anyone who may interested.
The dimensions are 600 mm wide x 800 mm high x 1000 mm long, fabricated from 6 mm (5 ply) marine plywood. I think that 4 mm (3 ply) could be used. I am a concerned about large hail (sometimes very large) in our area, hence the 6 mm thickness. I used 30 mm x 30 mm pine glued and screwed in all corners to join the plywood sheets. The glue was Liquid Nails. To total weight is about 20 kg, 10 Kg when lifting one end.
The cover is hinged at one end with a number of handles to hang on to as it is lifted and turned over. It is not too difficult to handle, although some physical strength required, to maintain control while upending the cover. It is important that the height of the platform and the cover are the same.
  • Turf likes this
#1606 NoDarkSkies
NoDarkSkies
Posted 16 January 2021 - 12:00 AM
Here's my completed observatory.  Now if I could just get some clear skies to use it.  We've only had a few clear nights since mid Nov when I got the scope setup in there frown.gif
How many inches higher is the Wall above the top of your Telescope?
#1607 Ddaniel84
Ddaniel84
  • Loc: Carpentras (France)
Posted 16 January 2021 - 12:18 AM
hello Richard, very ingenious .. but in the open position, does the box not interfere with observations?
Dominique
#1608 Rac19
Rac19
Posted 16 January 2021 - 02:56 AM
Dominique
Hi Dominique, there is no impact on observations, the platform is 800 mm above ground and the box is 800 mm high so the box is below platform level when open (180 degrees from closed position).
The hinges are "split" that the box can be moved away, but I don't usually bother.
Edited by Rac19, 16 January 2021 - 02:58 AM.
  • tjay, happylimpet, jcj380 and 5 others like this
#1609 Ddaniel84
Ddaniel84
Posted 16 January 2021 - 03:08 AM
Well seen!
#1610 RFtinkerer
RFtinkerer
Posted 19 January 2021 - 07:00 PM
Iteration 1.0 of my "observatory", if you can call it that.
I had a used Celestron CG-5 mount I got for $300 in 2015 starting my astrophotography hobby after a simple star tracker.  It had numerous problems; I added an autoguider setup to try to improve tracking but the DEC could not be successfully used and RA was so-so at best.  Eventually it broke in 2018 and I did not replace it as I knew I would want a much better and more expensive mount.  Finally last month I "justified" it...cause I really wanted to...and bought a new Skywatcher EQ6-r pro.  I like to setup about 80-90 yards away from my house...the CG-5 with everything was bad enough, the EQ6-r makes it much harder to walk out from the basement.  Thus, I bought a glidetop shed for economy intending to keep it placed permanently.  Although I didn't know it before, I see some others here bought these too so I wasn't completely insane.  However, investigating space issues before I got the shed in, I realized there was not enough room to maneuver around the setup for what I wanted.  I built an 8x10 wooden platform and set the shed on the back right.  I cut holes in the platform and placed castle stones where I would set the legs of the tripod. I use my computer inside of the shed, sitting on the floor, and have a propane heater to keep me warm.
Equipment:
1) Orion 6" f4 astrograph
2) Orion SSAG, 50 mm autoguider setup.
3) Skywatcher EQ6-r pro.
4) Canon 70D (to upgrade next to a cooled camera soon hopefully).
Edited by RFtinkerer, 19 January 2021 - 07:01 PM.
  • R Botero, Dhellis59, happylimpet and 3 others like this
#1611 Cfreerksen
Cfreerksen
  • Loc: Tooele, Ut
Posted 20 January 2021 - 11:52 PM
Equipment:
I just keep mine in the shed. No setup required.
Chris
  • R Botero, Dhellis59 and jcj380 like this
#1612 Am33r
Am33r
Posted 23 January 2021 - 02:58 AM
Observatory X
San Joaquin County, CA. USA
January 1, 2021
3 Meter Observa-Dome with Matching Cylinder Base & Motorized Rotation
  • MHamburg, CCD-Freak, niteskystargazer and 7 others like this
#1613 Am33r
Am33r
Posted 23 January 2021 - 03:05 AM
I have a dome and a matching cylinder base, but want to build a similar additional room like yours, can I use your picture on my website for reference of how we build our structure? Thank you
Edited by Am33r, 23 January 2021 - 11:43 AM.
  • LU1AR likes this
#1614 MHamburg
MHamburg
  • Loc: Brooklyn, NY/Berkshires, MA
Posted 23 January 2021 - 11:10 AM
I have a dome and a matching cylinder base, but want to build a similar additional room like yours, can I use your picture on my website for reverence of how we build our structure? Thank you
I think you meant reference but your choice is a nice compliment.
  • Am33r likes this
#1615 Am33r
Am33r
Posted 23 January 2021 - 11:44 AM
(: thanks, just corrected it
#1616 kathyastro
kathyastro
  • Loc: Nova Scotia
Posted 24 January 2021 - 07:46 AM
I just couldn't resist this.
  • Cyrano, tim53, drprovi57 and 34 others like this
#1617 outofdark
outofdark
  • Loc: SLC
Posted 24 January 2021 - 08:58 AM
What a nice setting, how are your skys?
#1618 kathyastro
kathyastro
  • Loc: Nova Scotia
Posted 24 January 2021 - 09:28 AM
This time of year, horrible.  We are lucky to get one clear night a month, and that is usually on the full moon.  We are 1 km from the ocean (Bay of Fundy), so lots of fog.
When it is clear, the skies are pretty good.  About Bortle 2 on very transparent nights, and Bortle 3 when the transparency is less.
  • happylimpet and Scott123 like this
#1619 NoDarkSkies
NoDarkSkies
Posted 25 January 2021 - 09:13 AM
Thank you and Yes Indeed you can.
I hope to have it back up in a new location by the end of the summer.
I will post updates as they happen.
Edited by NoDarkSkies, 25 January 2021 - 09:16 AM.
  • Am33r likes this
#1620 Ryker1
Ryker1
  • Loc: Edmonton/Alberta/Canada
Posted 25 January 2021 - 09:43 PM
My observatory is located at 54 degrees north just south of Edmonton Alberta. It houses a 14 inch LX600 with Starlock along with an 80 mm APO refractor.
  • Cyrano, MHamburg, tjay and 20 others like this
#1621 Umasscrew39
Umasscrew39
  • Loc: Central Florida
Posted 02 February 2021 - 05:07 AM
This is hilarious!  Best laugh I have had in a long time!!
#1622 jerahian
jerahian
  • Loc: Maine
Posted 02 February 2021 - 11:25 AM
Here's my new observatory I built in Aug-Oct., 2020.  I had several stipulations from my wife I needed to address in the design, and all were accounted for smile.gif  Also, finished it off with full AC power and dual redundant ethernet.  Not shown here, but now it also has an AllSky camera mounted onto the side of it.
09 06 G
10 10 E
Dedicated thread here: https://www.cloudyni...grows-in-maine/
An animation of the roof rolling off is here:  https://www.astrobin.com/jhn2vm/G/
CS, Ara
  • tjay, CCD-Freak, mikehager and 9 others like this
#1623 mutairy
mutairy
Posted 03 February 2021 - 06:28 AM
my simple Nexdome observatory in Abudhabi, UAE
this is under a bortle 9 sky
Gear:
Nexdome pod
Ioptron cem70g
Celestron edge hd 8
custom made pier
  • Cyrano, drprovi57, MHamburg and 17 others like this
#1624 DaveB
DaveB
  • Loc: Maryland
Posted 04 February 2021 - 12:11 AM
Yikes! I'm guessing that you image in narrowband wink.gif .
I happened to be in Abu Dhabi on National Day a few years ago. Quite an interesting experience (in a good way). It took us over an hour to get across town at 1:00 am. It's a fond memory that I won't forget.
Edited by DaveB, 04 February 2021 - 12:12 AM.
#1625 colroo1
colroo1
  • Loc: Adelaide. South Australia
Posted 04 February 2021 - 06:21 PM
Hello everyone. Hope you are all doing well.
Started building my observatory in June 2020.
Made the mistake of installing the equipment
I had finished the final fit out
It's working and now I can't be bothered doing
All the fiddly bits.
I am about to install the roof automation just
trying to work out where to out the motor
Most likely outside might be the best bet.
Here are some photos
IMG_20210205_080242_copy_298x398.jpg IMG_20210205_080739_copy_392x294.jpg IMG_20210205_080418_copy_300x400.jpg IMG_20210205_080433_copy_287x383.jpg IMG_20210205_080933_copy_384x287.jpg
Edited by colroo1, 04 February 2021 - 06:25 PM.
  • drprovi57, CCD-Freak, R Botero and 6 others like this
