Paramount/WiSky iOS Connection Issues
accessories equipment mount
2 replies to this topic
#1 Steve Yerby
Steve Yerby
Posted 25 February 2018 - 03:59 PM
Issue: Can not Connect iOS iPhone with WiSky.
  Connection of MacBook/Wisky works fine, meaning Wisky is set up properly
I have gone thru the iOS directions multiple times... when I get to the "Configure your iOS device’s network" section, I am not seeing what the Software Bisque Directions are suggesting. The PDF was updated in Dec 2017. I did have an iOS update in the last few days.
I have no option to "tap the Static pane" in the iOS Wifi settings. (IPV4 Address - Configure IP)
    Can anyone advise?
Notes from iOS/Wisky set up below:
Configure your iOS device’s network to use the static IP address: 169.253.1.2 After joining SWBisqueMKS5###, tap the information button, tap the Static pane and type 169.253.1.2 for the IP Address and 255.255.0.0 for the Subnet Mask.
Steve
#2 Steve Yerby
Steve Yerby
Posted 26 February 2018 - 11:40 AM
RESOLVED!
The Software Bisque WiSky directions left out a 255 from the Subnet Mask line in iOS.
Incorrect - 255.255.0.0
CORRECT - 255.255.255.0.0
Hope this helps someone in the future.
Steve
  • GooglyEyes likes this
#3 photoracer18
photoracer18
  • Loc: Martinsburg, WV
Posted 28 February 2018 - 03:51 PM
Drop the last .0, network addresses only have 4 hexadecimal groups, 255.255.255.0 is correct. I see its using 169.253.1.x as the range.
Edited by photoracer18, 28 February 2018 - 03:54 PM.
Also tagged with one or more of these keywords: accessories, equipment, mount
