Strategy for shooting in severe moonlight?
11 replies to this topic
#1 Rudy Pohl
Rudy Pohl
  • Loc: Ottawa, Ontario Canada
Posted 25 February 2018 - 04:11 PM
We've had almost no clear nights here in Ottawa and tonight is going to be one, however the moon is going to be out nice and bright and right up there among my targets. I'm going out because I need to practice a few shooting techniques to get ready for when we do have some good nights, one being using the Bahtinov mask properly.
Since I'm going to be out anyway, I thought I would shoot the Orion Nebula for a while... why not? Anyways, is there any strategy I can use to try to maximize the quality of the image I will get under such severe moonlight, such using very low ISO, short shutter speed, etc., or is it still just the old standard of 1/4 to 1/3 of histogram from the left edge?
Rudy
#2 leveye
leveye
  • Loc: Central Oregon Coast
Posted 25 February 2018 - 04:38 PM
Go mono and use filters.
#3 Aaron_tragle
Aaron_tragle
  • Loc: Richmond, Virginia
Posted 25 February 2018 - 04:46 PM
I just image star clusters during full moon or I test new equipment. Here is an example of what I got friday night under a 50% moon
25x30s ISO 400
Beehive Cluster
This night was my first-night guiding and I tried my homemade star-spike mask I made with cardstock and tooth floss
  • okiestarman56 likes this
#4 Gipht
Gipht
  • Loc: Prescott Valley, AZ.
Posted 25 February 2018 - 04:47 PM
Last night I  shot Orion with my 10" reflector using short subs, ISO  of 3200, and ended up with about 200 subs which I reduced down to 157 for 18 minutes integration.  The short subs seemed to handle the moonlight pretty well.   Your set up is quite different, but I would try a exposure time  which would  have the running man barely visible in the sub.  With  my setup that was 7 seconds.  The results are:  https://www.cloudyni...en-second-subs/
  • Jim Waters likes this
#5 PETER DREW
PETER DREW
Posted 25 February 2018 - 04:58 PM
Narrowband Ha filter?
#6 17.5Dob
17.5Dob
  • Loc: Colorado,USA
Posted 25 February 2018 - 05:01 PM
I wouldn't even try to image any nebula during bright moonlight. If you "have" to get out and test gear, shooting open clusters or globular clusters are the way to go. Also try to image as far away from the moon as possible.
#7 MalVeauX
MalVeauX
  • Loc: Florida
Posted 25 February 2018 - 05:09 PM
Heya,
I too woulndn't bother with DSO on a moon lit sky.
Instead, just image the moon. Or a planet if available.
The only way to really image DSO realistically with the moon in the sky is in narrow band.
Very best,
#8 Jim Waters
Jim Waters
  • Loc: Phoenix, AZ USA
Posted 25 February 2018 - 05:10 PM
Shoot Ha.
#9 Rudy Pohl
Rudy Pohl
Posted 25 February 2018 - 05:17 PM
25x30s ISO 400
Beehive Cluster
25x30s ISO 400
Beehive Cluster
Great suggestion Aaron, thanks!  I just gave it a quick study in Stellarium and it's location in relation to some other stars and that's what I''ll aim for. I'm new at DSO stuff to so I, like you need to practice my polar alignment and general techniques... taking every available opportrunit.
Have fun,
Rudy
#10 ImNewHere
ImNewHere
  • Loc: Nashville, IN
Posted 25 February 2018 - 08:51 PM
I wonder how well a CLS filter would work with the moon in the sky.
#11 17.5Dob
17.5Dob
  • Loc: Colorado,USA
Posted 25 February 2018 - 09:23 PM
It won't matter at all. Moonlight is broadband light and fills every spectral niche. Even Ha imagining suffers from it.
Edited by 17.5Dob, 25 February 2018 - 09:27 PM.
#12 AKHalea
AKHalea
  • Loc: Houston, Texas, USA
Posted 26 February 2018 - 09:52 AM
Rudy : Have you tried imaging M45, the seven sisters (The Pleiades)? It is a bright star cluster visible to the naked eye and has some nebulosity around a couple of the stars. If you have not tried that yet, it will be a great target to practice on. It is a bit away from the bright moon and you might be able to get the reflection nebulae with lots of short exposures.
A couple of other target worth trying might be the galaxy pair M81/82 and the Double Cluster NGC 886 & NGC 889. M81/82 is also called the Bode's nebula, but is really a pair of galaxies and they will fit nicely in the 200 to 300mm lens FOV. Both are bright enough that you can get something even with the bright moon. NGC 886 & 889 together fit nicely in the 200-300mm FOV. They are both open clusters of bright stars, so less hampered by the bright moon.
Hope that helps. Cheers ..... Anil
