Showcase your PixInsight Workflows
astrophotography
20 replies to this topic
#1 ribuck
ribuck
  • Loc: Newcastle, England
Posted 04 March 2018 - 04:08 AM
Hi All,
I want to do a poll of peoples work flows for both Narrowband(SII, Ha, OIII) and broadband (LRGB).
So why am i interested in doing this ? Simply put, on the internet there are many different processing workflows which all differ, so i want to see if there are any common themes that would allow me to take all of the best bits and combine them into a super workflow as it were.
Please keep it high level and in a numbered format
E.g.
1. DBE
2. Linear Fit
3. Etc etc
Thanks in advance,
Rich
  • Akwilliams and liquidrum like this
#2 Akwilliams
Akwilliams
Posted 04 March 2018 - 09:22 AM
I’ll certainly be following this.   I’m still fumbling around in PI with no set workflow!   But for a start here’s mine
Dynamic crop
DBE on each Frame
Deconvolutiom on Ha or LUM
combine
DBE again
Stretch
Photometic
Range Mask & alter curves on fore/background
Curves & Saturation
Shrink Stars
#3 ribuck
ribuck
Posted 04 March 2018 - 09:59 AM
Thanks AKWilliams,
Were off to a start and hopefull this is the start of my more to come.
#4 biedie
biedie
  • Loc: Overijse, Belgium
Posted 04 March 2018 - 10:24 AM
On the last picture of M51 which I posted a few days ago, I was asked to give an overview of my Pixinsight workflow. You can find it here (post #14)
Bart
#5 Salacious B Crumb
Salacious B Crumb
  • Loc: Greater Atlanta Area, GA
Posted 04 March 2018 - 11:05 AM
I probably forgot a lot so this will be edited as needed bases;
For all masters separately;
  • DynamicCrop
  • ABE or DBE or Both
  • Mask (which is slightly Convoluted)
  • CurvesTransformation or HistogramTransformation to adjust the lightens and to boost the contrast (separately to areas I try to protect and for the background)
  • MultiScaleLinearTransformation for noise reduction (separately to areas I try to protect and for the background)
  • StarMask + DeConvolution (if I get ringing, I'll skip this)
Make Masters nonlinear and combine them;
  • SCNR
  • BackgroundNeutralization (if it works)
  • Curves Transformation or HistogramTransformation to adjust the lightens and to boost the contrast (separately to areas I try to protect and for the background)
  • MultiScaleLinearTransformation for Noise reduction (separately to areas I try to protect and for the background)
  • StarMask + MorphologicalTransformation to reduce the Star sizes
  • CurvesTransformation to boost the colors
  • ColorSaturation to boost the colors
  • HDRMultiscaleTransformation for the core
  • MultiScaleLinearTransformation or UnsharpMask for sharpening
  • Rotation and DynamicCrop if needed
I think my process has so far been pretty much the same for the NB and LRGB.
- Sal
Edited by Salacious B Crumb, 04 March 2018 - 02:46 PM.
#6 ribuck
ribuck
Posted 04 March 2018 - 02:22 PM
Thanks guys this is a great start. Keep them coming.
#7 G. Hatfield
G. Hatfield
  • Loc: Tucson, Arizona
Posted 04 March 2018 - 03:11 PM
RGB
I use Local Normalization and Drizzle Integration (scale = 1) in my preprocessing.
1.  Combine without linear fit
2.  Dynamic crop
3.  DBE or ABE (I try them both)
4.  Photometric color calibration
5.  If noisy, Multiscale MedianTransform noise reduction with a luminance mask
6.  Usually, use Masked Stretch, but I often give ArcsinhStetch a try too
7.  If noisy, use TGVDenoise (CIE) with a mask
9.  I might use STF/Histogram Transformation to lighten the image a bit
10.  SCNR
11.  Balance R, G and B histograms in HT (line up peaks)
12.  If stars are too bright use Morphologic Transform (erosion) with a range mask for bright stars and/or a star mask for the rest.
13.  Into Photoshop for additional processing
#8 ribuck
ribuck
Posted 04 March 2018 - 03:58 PM
Surprised to see nobody using masked Stretch or LHE so far
#9 wimvb
wimvb
Posted 04 March 2018 - 07:24 PM
I do, if the image needs it.
Here's mine (LRGB imaging workflow). The exact workflow depends on the image, but generally includes the following steps in the order given.
RGB combination
Dynamic crop, RGB and L
DBE on RGB and on L
colour calibration, either the traditional method (background neutralisation, colour calibration), or PCC
Deconvolution (on L only), sometimes just targeting the stars. Not all images benefit from deconvolution, but it shrinks the stars a bit.
Noise reduction (Jon Rista's method), TGV and MMT
Stretching, Masked stretch or Arcsinh stretch on RGB, HT on L
Curve transform on RGB and L
HDRMT or LHE on L if needed
LRGBcombination
star reduction using MT
ACDNR or GreyCstoration noise reduction
  • BenKolt and 1DegreeN like this
#10 ribuck
ribuck
Posted 05 March 2018 - 02:11 PM
Thanks all,
Keep them coming as this is proving to be very interesting.
#11 pfile
pfile
Posted 06 March 2018 - 12:20 AM
for narrowband SHO, i just follow rick's tutorial from when he introduced the ColorMask script.
https://pixinsight.c...hp?topic=7751.0
works pretty well i think.
a variant on this is to linear fit the OIII and SII to the Ha before beginning, which might let you more easily do alternate color balancing methods. i think rick was using unlinked STF -> HT to do the initial stretch, and if you want to use ArcSinH stretch or masked stretch you need to get the colors in the ballpark first (otherwise with the Ha in the green the RGB image usually just looks green.)
or, instead of linear fit, IIRC Vicent Peris had a SHO color balancing technique where he would just use ColorCalibration using the entire image as the white reference. that usually leads to a reasonable starting point for the color masking routine.
rob
#12 Jon Rista
Jon Rista
  • Loc: Colorado
Posted 06 March 2018 - 01:07 AM
I'm on a simplicity and no-NR diet these days. My current workflow:
Pre-Process (Manual)
Deconvolution (maybe)
DBE
Combination (LRGBCombination for color, PixelMath for NB)
Curves (maybe)
That's about all I do these days!
Some examples:
  • psandelle, PI_CO100 and Merc like this
#13 Jon Rista
Jon Rista
  • Loc: Colorado
#14 Jon Rista
Jon Rista
  • Loc: Colorado
Posted 06 March 2018 - 01:08 AM
#15 Salacious B Crumb
Salacious B Crumb
Posted 06 March 2018 - 08:51 PM
No noise reduction or sharpening at all Jon? That's impressive...
- Sal
#16 ribuck
ribuck
Posted 07 March 2018 - 01:24 PM
Any more processes to share.
Would be grateful if we could keep this more about the processes rather than the resulting images.
Rich.
#17 Jon Rista
Jon Rista
  • Loc: Colorado
Posted 07 March 2018 - 03:56 PM
- Sal
That is correct. I stopped doing noise reduction on most of my images around a year ago, and was experimenting with it a bit before that. I still do NR sometimes for some images, but I always process all of them without any NR or other heavy processing at least once. It forces you to work on your acquisition, and forces you to acquire more data to reduce noise in the most optimal manner: by integrating.
I do get more integration these days, for sure. Most of my recent images are tens of hours across two or three narrow band channels.
That said, when I do indeed do NR, it is pretty light. I usually only do one pass of TGV with a very high iteration count with a moderately heavy mask (which smooths out the mottling that can occur at lower counts), or a couple passes of heavily masked MMT. I should demonstrate with an image I recently printed, and did some MMT on.
  • Salacious B Crumb likes this
#18 mherbik
mherbik
Posted 07 March 2018 - 08:23 PM
manual preprocessing sometimes including local normalization sometimes not. I usually do Luminance with and without and compare.
Dynamic crop
DBE
combine rgb
Color calibration RGB(using photmetric calibration)
Decon Lum (possibly skip if cannot improve image)
 with nonlinear mask noise reduction  using multiscale linear transform (same on Lum though more carefully)
stretch several different ways depending on image usually a small histogram stretch then masked or arcs stretch possibly both in small increments.
HDR multiscale transform
noise reduction if required usually to chrominance using TVGDnoise using mask and some experimentation
sharpening using range mask and Atrouswavelet transform
depending on image possibly local histogram equalization usually multiple times using small changes (0.10-0.15)
curves adjustment if required
dark structure enhance script if required.
morphalogical transformation for star reduction
resize change resolution to 300 dpi
#19 Marcelofig
Marcelofig
Posted 08 March 2018 - 02:18 AM
- Sal
May I ask, how do you acquire this data?
What I'm asking if you want to capture 20 hrs, is it better to use 1200 frames of 1 minute or 400 of 3 minutes?
#20 Jon Rista
Jon Rista
  • Loc: Colorado
Posted 08 March 2018 - 04:11 AM
- Sal
These were all with the ASI183MM Pro. It has smaller pixels, and a bit more read noise, than the ASI1600 I usually use. I used 10 minute subs at Gain 53, which is around 2.1e- read noise and 8500e- FWC., on an f/4 scope with a 150mm aperture.
  • psandelle likes this
#21 BenKolt
BenKolt
Posted 08 March 2018 - 12:25 PM
RGB combination
DBE on RGB and on L
LRGBcombination
My PI workflow is ever evolving, but looking through wim's list I see that his closely matches mine.  However, the application of steps changes from image to image depending upon the circumstances.  Also, I have not played around much with ACDNR and GreyCstoration but may be evaluating them more in the future.
One thing that I've been introducing more and more into my workflow is applying more steps to individual calibrated frames prior to registration and integration.  I've had issues with bad gradients that shift during the night, and the result can be a complicated mess to remove after integration.  Sometimes I've been able to mitigate that by applying a low order ABE step to all frames prior to registration.  I've started experimenting using process and image containers, and this helps to automate the steps.  I don't do this all the time, but it's an example of how one can really expand the flexibility of PI.
Best Regards,
Ben
  • starhunter50 likes this
Also tagged with one or more of these keywords: astrophotography
