Bought this 30 miles away from me, so just got back home a while ago. Was used one time. Fits the GP just fine and looks well built and light in weight.
Posted 04 March 2018 - 09:28 AM
Can you fit both scopes in your Vette? Or do you have to pick one or the other on a given night?
Posted 04 March 2018 - 09:34 AM
Have you tested the focuser yet?
Posted 04 March 2018 - 09:35 AM
A couple more and you will have to trade in the vette for a van.
I think i can stan.
Posted 04 March 2018 - 09:36 AM
Very true man.
Posted 04 March 2018 - 09:39 AM
I just gave it a whirl on a light pole. Seems fine with even a 5mm Radian. I notice no color with lower powers, but see some color on the edge of objects with a 5mm Radian. Seems to be very clear and clean so far. A little more snappy than my C5. This scope is also much lower on power with the same eyepiece.
Edited by CHASLX200, 04 March 2018 - 09:40 AM.
Posted 04 March 2018 - 09:49 AM
Beautiful , enjoy your new telescope!
Posted 04 March 2018 - 09:57 AM
Nice Scope .
CS,KLLU,
Posted 04 March 2018 - 10:12 AM
This could be the best buy of the year. Will do a hard side by side with a super sharp C5.
Posted 04 March 2018 - 04:29 PM
I have a Stellarvue finder shoe, but see no where to install it.
Posted 04 March 2018 - 05:01 PM
You have to have the right shoe, and it mounts using 2 screws on the focuser body. There was a picture of it on the forums a week ago, can't find it. I believe they purchased the shoe from Agena.
Posted 04 March 2018 - 05:02 PM
Why did the seller let it go after only one use?
Posted 04 March 2018 - 05:35 PM
He had picked up a Lock Wood 16" Starmaster from Bob S. Said he was not a refractor guy. I saved some cash so it worked out good for me. Scope looks like it was never out of the box. He used it one time.
Gonna put it to the test tonite.
Posted 04 March 2018 - 05:36 PM
I will have to find out. I may not even need a finder anyways.
Posted 04 March 2018 - 06:10 PM
Yep, I posted this: https://www.cloudyni...d/#entry8404955
Works great for Synta types...
Posted 05 March 2018 - 06:20 AM
Seeing was bad last nite with dropping temps, but it was clear. With a 32mm and 21mm Tele Vue plossl's , M41, 42 , 45, 37, and 38 all looked great. M42 also looked super with a 5mm Radian and the 3mm Delite was a little too much for the seeing. Plan to get some 2" eyepieces soon. I would bet a 21mm Ethos would be a killer for this scope.
Posted 05 March 2018 - 09:53 AM
Correct if I'm somehow wrong but your tube has got nothing to do with the new Astro-Tech AT102ED.
Posted 05 March 2018 - 12:37 PM
You are wrong ๐. Thatโs the brand new version just released. ๐Correct if I'm somehow wrong but your tube has got nothing to do with the new Astro-Tech AT102ED.
Edited by MSWcdavis, 05 March 2018 - 12:46 PM.
Posted 05 March 2018 - 12:41 PM
Why stop at 21mm? A 34mm 68 would give wider FOV, probably weigh less, and show faint DSO brighter. For low power I like 4-5mm exit pupil, which would be 28-35mm for an F7. The Hyperion 36mm 72* also comes to mind. Or ES 30mm 82 if you like a counterweight to raise the eyepiece position. Any of these would give a significantly larger FOV and cost much less than a 21 Ethos. The 21 Ethos is really for sub F5 Dobs, although it can certainly be useful in other scopes. Low power for Dobs, medium power for cats. I donโt know how much I would use one in my 4โ Apo though. Not wide enough for low power finder ep and too wide for 95% of targets. I suppose Coat Hanger, Pleiades and Beehive would be good.Seeing was bad last nite with dropping temps, but it was clear. With a 32mm and 21mm Tele Vue plossl's , M41, 42 , 45, 37, and 38 all looked great. M42 also looked super with a 5mm Radian and the 3mm Delite was a little too much for the seeing. Plan to get some 2" eyepieces soon. I would bet a 21mm Ethos would be a killer for this scope.
Edited by SeattleScott, 05 March 2018 - 12:49 PM.
Posted 05 March 2018 - 12:56 PM
Posted 05 March 2018 - 01:48 PM
The holes on a Stellarvue shoe are arranged side to side, while the mounting holes on your focuser are arranged front to back. If you decide that you need a red-dot or optical finder, this shoe should work.
https://agenaastro.c...nder-xfurb.html
Posted 05 March 2018 - 04:47 PM
The 21E is a great EP in almost any Refractor however for this OTA I'd more readily use a 31T5 or similar.
Posted 05 March 2018 - 04:52 PM
They're all good. The 21mm Ethos, the 31mm Nagler, the 41mm Panoptic and a bunch of others too. At F/7, I like the 35mm Panoptic.
Posted 05 March 2018 - 04:57 PM
Jon, I'm in agreement, just the 31T5 seems to be a near perfect eyepiece for me as It has a larger FOV than the 21E, is more comfortable and only gives up minimal FOV to the 40mm SWA (Paragon, 41P, Etc) while maintaining a larger magnification.
Can't go wrong with any decent EP at F7 IMO.
![]() Cloudy Nights LLC Cloudy Nights Sponsor: Astronomics |
