Ed:
In comparing telescope types, one cannot make blanket statements because there are several factors to consider: resolution, image brightness/light throughput and contrast. And when considering contrast, there are two types, the fine scale contrast one is concerned about with the planets and bright objects and the deep sky contrast of a nebulae or galaxy.
- Resolution: Resolution is determined by the aperture alone. This is because the size of the Airy disk is inversely proportional to the aperture and it is ultimately the size of the Airy disk that determines the resolving power of a telescope. In resolving two stars of equal magnitude, a larger CO can help slightly but with stars of unequal magnitude, the greater energy in the diffraction rings is detrimental. All the operational issues like thermal equilibrium, optical quality, collimation, these can affect the resolution but these can be managed. The Dawes Limit is 4.56 inches/D in arc-seconds. With a 4.56 inch scope, the Dawes limit is 1". With a 10 inch scope, it's 0.456".
- Light throughput depends on both the transmission/reflectivity of the optics as well as the size of the central obstruction. Refractive optics are very efficient, overall losses are only a few percent. In the big scheme of things, a refractor can be considered 100% efficient because the errors in the estimation of the reflectivity of the mirror surfaces will be greater than losses in a reflector. A few examples:
A Celestron SCT with Starbright XLT coating has a transmission efficiency of 84% across the visual spectrum. If the CO is 36%, that represents an additional 13% loss so the throughput is 0.84*0.87 = 0.73 = 73%. The equivalent perfect telescope (refractor) would be the the square root of that so 85%.. multiply the aperture by 0.85. For a 6 inch SCT, this would be the equivalent of a 5 inch refractor.
A Newtonian with fresh high transmission coatings and a 16% CO: This would be a best case scenario for any reflector. Coatings can be 95% efficient, the small CO is easily possible with a larger aperture instrument. That would be 0.95*0.95 x (1-0.162) = 0.88 = 88%. The equivalent refractor would be the square root of that = 94%.
A more typical Newtonian would have a 90% coatings and a 25% CO and so the transmission would be 76%, much closer to the SCT.
- Contrast: There are really two types of contrast, fine scale planetary contrast and deep sky contrast.
- Fine scale contrast: The Airy disk consists of a central disk surrounded by a series of diffraction rings. The central obstruction transfers light away from the central disk to the outer rings. This has the effect of spreading the light out and reducing the fine scale contrast. Imagine the pixels on your computer screen were round dots with a series of rings surrounding them. Each pixel would partially effect those nearby. This is how the central obstruction affects fine scale planetary contrast.
One can look at this analytically but there are some rules of thumb: The effect of a central obstruction under 20% in negligible. Beyond that, there is the "clear aperture approximation". To get the equivalent unobstructed aperture, one subtracts the central obstruction's diameter from the aperture. An 8 inch scope with a 2 inch CO is the equivalent of a 6 inch unobstructed scope. In reality, the diffraction effects are related to the area of CO (and the Newtonian's spider) so the effect of a large CO is underestimated.
This is why large aperture planetary scopes are often Newtonians, very small central obstructions are possible.
Deep Sky Contrast: This is primarily a function of stray light control. Roland Christen says it very simply:
"There are two kinds of contrast. One needs to define which contrast you mean. If it's planetary contrast, then baffling plays no part. Planetary contrast is strictly a function of how well the optic is figured. (this would include the CO)
If it's deep sky contrast, then optical perfection plays little or no part, and the main contributer will be how well the tube has been made to exclude stray light (i.e. baffled).
Rolando"
https://www.astromar...&news_id=&page=
In general, refractors are better baffled than reflectors.
- So, as one can see, there is no easy comparison. And these comparisons assume equal optical quality, that the scopes are collimated and that they are free of thermal issues.
In general, it's my experience that a good refractor is able to work at near 100% efficiency, most of the time. Newtonians and CATs face thermal issues that mean they will be operating at less than their peak a good part of the time.
Of course the big player is aperture. If one is looking at a 16 inch Newtonian, even if it is only comparable to a 12 inch refractor, no one owns 12 inch refractors.
