teflon for bearing material
16 replies to this topic
#1 mtsaz
mtsaz
  • Loc: arizona
Posted 08 March 2018 - 10:10 AM
HI- I am building a 12.5" full thickness mirror dob.  I have most of the major construction done- am working on a spider- and secondary holder- and ran into another issue.  What do you use for the "teflon" pads- on the bearing surfaces?  A sheet of 12x12- 1/8" thick from amazon is like 40$.   ---and I need like 1/4 that amount.
What can you use and what thickness do you recommend?  I know I need two pads on the azimuth bearing surfaces, and like 3 of them on the ground board- all opposed by the (I forget name) black formica (stardust or something like that).
I have some 1" thick delrin- I could cut with band saw into thin strips-
Thank you for your help!!
#2 Augustus
Augustus
  • Loc: Connecticut
Posted 08 March 2018 - 10:28 AM
I use this.
https://www.amazon.c...ds=teflon sheet
It works great.
#3 Pinbout
Pinbout
  • Loc: Montclair, NJ
Posted 08 March 2018 - 11:03 AM
this works just as well as Teflon
https://www.intersta...nhoCZGAQAvD_BwE
  • tomykay12 likes this
#4 NiteGuy
NiteGuy
  • Loc: Northern Arizona
Posted 08 March 2018 - 11:04 AM
Go to ScopeStuff.com
You need Virgin Teflon (PTFE) thick enough so that, when grit builds up on it, you can just scrape it clean with a pocket knife. They also have center bearing kits, including center Teflon pads. You'll want to shim the center pad so that it's slightly higher than the pads on the base but then you probably knew that.
12"x3/4"x1/8" and other thicknesses - http://www.scopestuff.com/ss_ts31.htm
1/8" & 1/4" thick Teflon Pads, pre-drilled and countersunk, with screws - http://www.scopestuff.com/ss_tp41.htm
#5 Euclid's Brother
Euclid's Brother
Posted 08 March 2018 - 11:07 AM
I got this.
https://www.grainger...Orders_WillCall
#6 kfiscus
kfiscus
    Baltic Birch Dob Bases
  • Loc: Albert Lea, MN, USA
Posted 08 March 2018 - 10:49 PM
I really like 1/4" stuff- it gives better clearance of exposed bolt heads underneath dob bases.  I've used and liked the cut and drilled blocks that ScopeStuff sells but would like to get some pieces bigger than he has.  If the OP ends up buying a large sheet of 1/4" Teflon, I'd buy the leftovers.
  • Kunama likes this
#7 StevenYood
StevenYood
  • Loc: Suwanee, GA
Posted 09 March 2018 - 03:37 AM
I’ve gotten perfectly satisfactory sheets of Teflon on EBay and cut them to the desired size.
#8 Pinbout
Pinbout
Posted 09 March 2018 - 06:01 AM
You should really try the seaboard. A lot cheaper
#9 kfiscus
kfiscus
Posted 09 March 2018 - 10:25 AM
Thank you, Danny.  I might try some.
#10 EAF
EAF
Posted 09 March 2018 - 09:23 PM
What material are you using for the other surface, the bottom of the bearing and the bottom of the rocker box?  I have seen some references but still, I am stuck on what to use and where to get it.
Ed
#11 Augustus
Augustus
  • Loc: Connecticut
Posted 09 March 2018 - 09:35 PM
Ed
Formica.
#12 mtsaz
mtsaz
  • Loc: arizona
Posted 11 March 2018 - 01:45 PM
It's the 909-42 from Lowe's right?
#13 tomykay12
tomykay12
  • Loc: San Diego
Posted 11 March 2018 - 01:57 PM
Second the Seaboard, also known as Starboard. I've never used it for telescope bearings, but have used it in  alot of  marine applications. Slippery stuff with a light pebbled texture.
  • Pinbout likes this
#14 airbleeder
airbleeder
  • Loc: Powder Springs, Georgia
Posted 11 March 2018 - 03:59 PM
  You can order the Formica 909-42 from Lowes. Teflon 12" bars and sheets from McMaster-Carr.
#15 mac57
mac57
  • Loc: DeLand of Oz, Florida
Posted 11 March 2018 - 07:27 PM
So let me get this straight...  I use the Teflon pads on the upper hunk of wood, and put the sheet on the bottom, right?  I'm thinking of re-making my base and am kinda following along with this thread, especially because Danny is involved, as I have admired his knowledge and experience for years now.  I've never been happy with my stock Orion base, and with summer coming here in Florida, it's the time to take the scope apart and make some improvements.  I'm also toying with the idea of getting a 1/20 or so secondary.  Mark
#16 airbleeder
airbleeder
Posted 11 March 2018 - 07:35 PM
   Teflon bottom hunk, sheet top hunk.
#17 mac57
mac57
Posted 11 March 2018 - 07:38 PM
Thanks, bleeder
