What's on the porch today?
86 replies to this topic
#76 DAVIDG
DAVIDG
  • Loc: Hockessin, De
Posted 16 March 2018 - 04:54 PM
  I removed the retainer ring and place a towel over the mirror and one hand on the towel,  then flipped the assembly upside down and lifted the cell away from the mirror.  I reinstalled the freshly coated mirror reversing the process and their wasn't a mark on it.
          - Dave
Edited by DAVIDG, 16 March 2018 - 04:54 PM.
  • bremms and TOM KIEHL like this
#77 strdst
strdst
  • Loc: Oregon Territory
Posted 18 March 2018 - 11:00 PM
I was able to remove the 3 retainer set screws today. 2 were easy, one was dicey. But now of course, (why is there always a but?) the retainer ring has no interest in moving. I would like to use heat, or oil, or both but for the mirror!
Would it be reasonable to think I could find screws (longer than the Allen set screws) with the same thread and turn them in to put pressure on the retainer ring enough to break it free from the cell? It is pretty stuck.
Better ideas?
#78 clamchip
clamchip
  • Loc: Seattle
Posted 19 March 2018 - 10:16 AM
Thats a good idea, one at a time to break the bond.
If yours is the same as mine the cell is cast iron and the ring is steel so rust could be
making it difficult to remove. Except your ring looks like a different color, mine is just
bright steel.
If you have something to make your fingertips really grippy like those gloves mechanic's
wear these days maybe it will help get it going.
Robert
#79 strdst
strdst
Posted 29 March 2018 - 11:36 PM
Well phooey!
The retainer ring continues to retain. I wanted to clean the mirror enough to see the condition of the coating. I didn't want to get a lot of water between the retainer and cell so I crudely made this plank to spray water up to rinse the mirror without (hopefully) adding to whatever corrosion is holding everything together. Maybe, I thought, it can stay in the cell for cleaning at least. If it needs a re-coat I'm up a creek. So a gallon of distilled water, a fifth of 91% isopropyl alcohol and 37 pounds of wet cotton balls later... it probably needs a re-coat but probably not on my watch. The mirror is way better clean, but the coatings could be much better.
I still like this little fecker just the same
#80 strdst
strdst
Posted 30 March 2018 - 12:52 AM
 The condition of what it's condition is in.
Edited by strdst, 30 March 2018 - 01:59 AM.
  • clamchip and TOM KIEHL like this
#81 strdst
strdst
Posted 06 June 2018 - 02:14 AM
The last time I posted I was frustrated because the mirror wouldn't get out of the cell. Never got it to move but I'm so happy. I have a ridiculous number of fine telescopes... Nippon Kogaku...many, Goto, many, Tak,1, HOC a few, R.A.lots, APL a few, Swift, a few, early Criterion 1, Zeiss 1, and this 4" Fecker.
I'm a refractor kinda guy but maybe not so much anymore. This little Fecker is pretty much my favorite telescope now. At least while observing Jupiter/Saturn. I'll keep a few refractors for stars but I may have finally found what works for me. An 8mm Edmund ep is perfect. I didn't do the math but thats all the magnification I need to feel connected. No damp down after moving. Fecker ROCKS!
  • clamchip, DreamWeaver, gelkin and 2 others like this
#82 Garyth64
Garyth64
  • Loc: SE Michigan
Posted 26 June 2018 - 06:02 PM
Knock, knock, what's this on my porch?
Cutting thru the cardboard, I see what might be old packaging material:
Hmmm,
  • steve t, Bomber Bob, Defenderslideguitar and 1 other like this
#83 bremms
bremms
  • Loc: SC
Posted 26 June 2018 - 06:23 PM
My cell from #472 has 3 3/64" Allen set screws pushing on the retainer ring, not threading into the
retainer ring, just pushing on it so the ring is adjustable to give the mirror play, room, just like a refractor
lens has some room.
What looks like rust is actually paint to prevent the set screws from falling out, or rusting, or moving? but
mine move quite easily.
The retainer ring has 3 felt pads 120 apart where it contacts the mirror, and these are just barely touching
the mirror if at all.
I have an idea Keith, try to just loosen the 3 Allen set screws and see if it releases your retainer.
Why you have the 3 extra set screws, I'm not sure at this stage, but they may be for some other purpose
possibly centering the mirror in the cell?, they look farther down from the edge of the cell?
The Allen wrench for my set screws is 3/64" inch.
Robert
Love the Jackson Pollock Fecker paint.
#84 Garyth64
Garyth64
  • Loc: SE Michigan
Posted 26 June 2018 - 06:59 PM
Digging deeper, I see this:
-really nothing to really create a lot of hype about, but maybe this pic will help:
#85 Garyth64
Garyth64
  • Loc: SE Michigan
Posted 26 June 2018 - 07:06 PM
I'm not really going to make this into a drawn out guessing game,  here is the label:
But, there's no OTAfrown.gif , but I knew that.
It came with all the accessories:
The mount needs to be cleaned and degreased.  It's useable now, but I'll make it shiny.  The box is in great condition.
This will be great on that new tripod I'm making.
Edited by Garyth64, 26 June 2018 - 07:07 PM.
  • steve t, TOM KIEHL, Bomber Bob and 5 others like this
#86 Esso2112
Esso2112
  • Loc: Magnolia, TX
Posted 26 June 2018 - 08:04 PM
I have that exact mount with my Royal Astro R70.  It seems to be a solid mount, except for the tripod. Good find and looks in nice shape.
  • Garyth64 likes this
#87 Garyth64
Garyth64
  • Loc: SE Michigan
Posted 26 June 2018 - 08:13 PM
It is a 7TE-5.  The mount is similar to my 7TE-2.  The 7TE-2 has a azimuth scale, the 7TE-5 does not.  Where the scale fits on the 7TE-2, the mount is tapered on the 7TE-5.  Other than that they are identical.
The legs on the 7TE-5 have a round section of wood between the leg splits.  My 7TE-2 the center sections are square.
I have a couple of loose 60mm scopes that have good optics.  One of them will find a home on this mount.
