Are you a Vixen Fluorite/ED fan?
refractor
295 replies to this topic
#251 Nippon
Nippon
  • Loc: Central Florida
Posted 03 November 2019 - 01:59 PM
I observed with a guy who had a Vixen made 6" f/6 Newtonian on the Vixen Sensor EQ mount and it was all branded Tasco.
  • Simon B likes this
#252 Jason B
Jason B
    Proud father of 5!!
  • Loc: Mid-Michigan
Posted 03 November 2019 - 03:12 PM
I've never seen the Tasco version of the FL102.  Sharp looking scope!
  • donadani likes this
#253 Reid W
Reid W
  • Loc: Shreveport, LA
Posted 03 November 2019 - 04:27 PM
A question to fellow Vixen refractor owners. I have an ED 103s and live in Florida. My dew heater strips seem to struggle keeping the objective lens completely free of dew even on the maximum setting. They don't get totally dewed up just a slight fog. I have two brands of strips. Dew Not and Astrozap and they both get warm to the touch. Most Vixen 4" scopes have similar dew shield dimensions so what works on any one model I figure should work on all. So where do you place your heater strip for the best result?
Thanks, Paul
Do you have a dew shield extension?
#254 Nippon
Nippon
Posted 03 November 2019 - 05:05 PM
No and I've thought about that. Truth is Vixen and Takahashi dew hoods are pretty short and much larger in diameter than the optic they are shielding. I have a Stellarvue 102 triplet and it has a much longer and smaller diameter in relation to the optic dew shield. As a result I rarely have any dewing on the Stellarvue.
  • Castor and Bomber Bob like this
#255 John Huntley
John Huntley
  • Loc: SW England
Posted 04 November 2019 - 05:19 PM
Wouldn't a dew shield that is smaller in diameter than the objective cause some loss of light ?
Of have I missed something ?
#256 John Fitzgerald
John Fitzgerald
    In Focus
  • Loc: ROR Obs. near Pettigrew, Arkansas
Posted 04 November 2019 - 05:33 PM
I think he means smaller than the competitors. It would still be larger than the objective.
#257 Nippon
Nippon
Posted 04 November 2019 - 06:17 PM
Yes I do mean that.
#258 donadani
donadani
  • Loc: Germany
Posted 07 November 2019 - 12:41 AM
Meanwhile I had first-light with the Tasco FL and what should I say... - it has one of the best optics I ever saw - and I saw some right now ;)
After a cooldown for about 45min I did a startest on Altair and could go up to unbelivable 562x! (Vixen HR 1,6) just seeing nice ring patterns on both sides of focus! OF COURSE this is absolutely no usefull magnification for a 4" apo - but only shows how good the optic is corrected. Absolutely no coma could be detected - all rings go centric through just one point in and out. In focus the optics shows an nice, fluffy little ball as nice as I saw only with an Zeiss AS80 until now. When I put in a Ronchi eyepiece the lines look like a zebra-crossing: straight all over and in any direction.
Had three FL-102S until now and this one is by far the best... - so maybe Vixen searched out their best lenses ever made to support Tasco here :)
Kudos Tasco - Kudos! :)
  • Erik Bakker, eros312, Bomber Bob and 1 other like this
#259 Marcus Roman
Marcus Roman
Posted 07 November 2019 - 06:52 AM
Meanwhile I had first-light with the Tasco FL and what should I say... - it has one of the best optics I ever saw - and I saw some right now wink.gif
Had three FL-102S until now and this one is by far the best... - so maybe Vixen searched out their best lenses ever made to support Tasco here smile.gif
Great report! As it refers to the Ronchi test, did you reduce down to 3 lines and if so, how did the external lines resemble when pushed to the borders of the field stop?
Edited by Marcus Roman, 07 November 2019 - 06:52 AM.
#260 donadani
donadani
  • Loc: Germany
Posted 07 November 2019 - 01:08 PM
Hi Marcus,
I used this eyepiece:  http://www.astro-mes...DE V1_1 (2).pdf
Guess I saw about five lines or so - like in the samples in the manual. With most optics you see some bending of the lines in any direction or a spherical zone or something. Not with the Tasco :)
If you have any ideas how I can vary the test - let me know :)
cs
Chris
#261 Marcus Roman
Marcus Roman
Posted 07 November 2019 - 05:48 PM
Hi Marcus,
Guess I saw about five lines or so - like in the samples in the manual. With most optics you see some bending of the lines in any direction or a spherical zone or something. Not with the Tasco smile.gif
cs
Chris
Hi Chris, I have same eyepiece from Dr. Gerd! Very nice and useful! I usually push it up to limit to see just 3 lines, and if they are parallel even when the two external lines touch the field stop, then you have perfect optics!
If they are just a bit a little bent, as is normal even with superb optics, I have been told the optics are close to perfection.
I am sure your gorgeous Tasco Fluorite, which is really extremely beautiful, is also perfect or close to perfection.
Really compliments!
Marco
Edited by Marcus Roman, 07 November 2019 - 05:50 PM.
#262 donadani
donadani
  • Loc: Germany
Posted 08 November 2019 - 12:21 AM
I will check that out with three lines next time the clouds let me... smile.gif
Edited by donadani, 08 November 2019 - 12:22 AM.
#263 Nippon
Nippon
Posted 08 November 2019 - 09:33 AM
Poor Tasco they are most associated with cheap department store toy Christmas scopes. But obviously the Tasco FL102 in this post is a high end Vixen fluorite. Tasco was always an importer and never actually built anything to my knowledge. In the 60s they sold under their brand a range of very good scopes built by manufacturers in Japan. I had a 60mm Tasco refractor in the 60s and it had an excellent objective lens. The provided eyepieces were .965 and were pretty inexpensive designs but while having very narrow fields of view and little eye relief I don't recall the eyepieces being of poor optical quality.
  • eros312, scooke, Bomber Bob and 3 others like this
#264 Jason B
Jason B
    Proud father of 5!!
  • Loc: Mid-Michigan
Posted 09 November 2019 - 09:02 PM
I have seen a few Tasco chromatic refractors with the vixen circle the logo on them but other than Celestron, I didn't think the ED or FL series were anything but Vixen branded.
#265 Blueox4
Blueox4
  • Loc: Upstate New York
Posted 21 December 2019 - 03:17 PM
Yes, a big fan. My FL-70S on a Super Polaris. Lots of fluorite goodness in this thread!
  • Erik Bakker, edif300, eros312 and 6 others like this
#266 Erik Bakker
Erik Bakker
  • Loc: Netherlands, Europe
Posted 21 December 2019 - 03:46 PM
And it pairs well and is very stable on the Super Polaris mount!
  • Blueox4 and Defenderslideguitar like this
#267 Defenderslideguitar
Defenderslideguitar
  • Loc: Connecticut
Posted 21 December 2019 - 04:07 PM
Vixen 80fl
 C-102fl
   Never tire of looking through or looking at the Vixen fl's
  • Erik Bakker, Bomber Bob, Blueox4 and 1 other like this
#268 amys
amys
  • Loc: Groton, CT
Posted 28 December 2019 - 08:14 AM
I have the chance to buy one of the Vixen 80mm f/8 fluorites, which I would plan to use side by side with my Mewlon 210.  It looks to be in good shape but I would actually prefer to get one of the Vixen 102mm f/9 fluorites.  If one of you fine folks who own one needs to thin the herd, raise some cash . . .fingerscrossed.gif praying.gif
  • Defenderslideguitar and 25585 like this
#269 Lucullus
Lucullus
Posted 28 December 2019 - 03:52 PM
Has there ever been a 127mm aperture Vixen flourite refractor?
#270 Nippon
Nippon
Posted 28 December 2019 - 04:52 PM
Not to my knowledge. Closest would be the 130 ED doublet they made at one time
#271 amys
amys
  • Loc: Groton, CT
Posted 29 December 2019 - 08:23 AM
I just posted a want ad for the 102mm f/9.  Getting one of these would be a good end to a truly lousy year.
  • Bagwell likes this
#272 Nippon
Nippon
Posted 29 December 2019 - 09:52 AM
C102 f/9 or not I truly hope you have a better year.
#273 GOLGO13
GOLGO13
  • Loc: West Virginia
Posted 29 December 2019 - 10:06 AM
Maybe this will make you feel better. My new 103s which has a crazy good star test. This is the second time I've owned a 103s and I think this sample is slightly better than my last one. Outfitted with the 34mm 68 pictured it provides a crazy good wide field view.
103s
  • Erik Bakker, Bomber Bob, syxbach and 1 other like this
#274 amys
amys
  • Loc: Groton, CT
Posted 29 December 2019 - 10:15 AM
Thanks so much!
Sent from my iPhone using Tapatalk
#275 amys
amys
  • Loc: Groton, CT
Posted 29 December 2019 - 12:36 PM
Yes, you snagged a beauty!  I’m quite jealous.
Also tagged with one or more of these keywords: refractor
