ATCO missed, ATCO bought
28 replies to this topic
#26 Marc-Andre
Marc-Andre
  • Loc: New Hampshire
Posted 12 April 2018 - 10:47 PM
There no threads on my lens cell, so my dew shield is press fit also.
Thank you for the offer Chuck.  I think I'm set on the dimensions after taking a couple measurements of my cell and storage space in the case.  I'd like to try a couple ideas to develop some skills before having a replacement machined.  In the short time though I've got to travel and make repairs at my dad's place.
  • Chuck Hards likes this
#27 Chuck Hards
Chuck Hards
Posted 13 April 2018 - 07:25 AM
I'll keep my eyes open for some thin-wall stock for a slip-on dew shield, in the meantime.
  • Marc-Andre likes this
#28 Marc-Andre
Marc-Andre
Posted 09 July 2018 - 02:19 PM
I found a source for 16 gage 4" OD aluminum tube.  While I would have liked 4" ID so it would fit, that was not to be found.  So, I decided to use two pieces of the 4" OD tube.  One would be split and glued to the other with JB-weld with 1" extending beyond the inner tube to fit over the lens cell.  I also had to fill the gap in the outer tube with another piece cut to fit.
Edited by Marc-Andre, 09 July 2018 - 02:31 PM.
  • Kasmos and jcruse64 like this
#29 Marc-Andre
Marc-Andre
Posted 09 July 2018 - 02:30 PM
Then I made a profile of the transition using a plastic gift card (used up) to build a taper from the larger to smaller OD and filled the space with JB-weld and fine detail with auto glazing putty.  After final sanding it received self-etching primer, flat black paint in the shield, GM white auto paint, and protective clear finish on the outside.  The slip fit joint received a layer of thin self adhesive Velcro pile. It wasn't inexpensive, but I gained some skills and I'm pleased with the results.
Edited by Marc-Andre, 09 July 2018 - 02:32 PM.
  • deSitter, CharlieB, Bomber Bob and 1 other like this
