Gday Peter
The new data is still truly weird.
When you did the GA, you had clear PE in RA and a flat ( but drifting ) line for DEC.
You then did the DEC lash test, and once more, the mount appears to go at 2x the commanded rate.
What is very interesting tho is how the distance moved for a common pulse seems to alternate ( massively )
on every second pulse???
for Ken
( following is an extract from the debug log to show the extreme variability in reported moves for common pulses )
22:25:10.977 BLT: Entering DecMeasurementStep, state = 0
22:25:10.977 //* =========== Start DEC Lash Test ===========
22:25:11.485 MoveAxis(N, 1357, -) // ( expect 8.164arcsec
22:25:11.484 Star::Find X=89.03, Y=344.83 // dDEC = -0.733"
22:25:14.824 MoveAxis(N, 1357, -) // ( expect 8.164arcsec
22:25:14.823 Star::Find X=88.23, Y=344.87 // dDEC = -2.582"
22:25:18.407 MoveAxis(N, 1357, -) // ( expect 8.164arcsec
22:25:18.404 Star::Find X=79.71, Y=344.75 // dDEC = -27.413"
22:25:21.758 MoveAxis(N, 1357, -) // ( expect 8.164arcsec
22:25:21.756 Star::Find X=77.43, Y=344.82 // dDEC = -7.351"
22:25:25.325 MoveAxis(N, 1357, -) // ( expect 8.164arcsec
22:25:25.323 Star::Find X=68.61, Y=344.80 // dDEC = -28.394"
22:25:28.680 MoveAxis(N, 1357, -) // ( expect 8.164arcsec
22:25:28.678 Star::Find X=66.44, Y=345.05 // dDEC = -7.023"
22:25:32.250 MoveAxis(N, 750, -) // ( expect 4.512arcsec
22:25:32.249 Star::Find X=57.06, Y=344.91 // dDEC = -30.179"
22:25:34.995 MoveAxis(N, 750, -) // ( expect 4.512arcsec
22:25:34.993 Star::Find X=54.99, Y=344.74 // dDEC = -6.640"
22:25:37.954 MoveAxis(N, 750, -) // ( expect 4.512arcsec
22:25:37.952 Star::Find X=51.38, Y=344.80 // dDEC = -11.631"
22:25:40.712 MoveAxis(N, 750, -) // ( expect 4.512arcsec
22:25:40.710 Star::Find X=49.63, Y=344.80 // dDEC = -5.634"
22:25:43.670 MoveAxis(N, 750, -) // ( expect 4.512arcsec
22:25:43.668 Star::Find X=45.72, Y=344.03 // dDEC = -12.476"
22:25:46.417 MoveAxis(N, 750, -) // ( expect 4.512arcsec
22:25:46.416 Star::Find X=44.01, Y=344.36 // dDEC = -5.554"
You then did a cal that appeared to work reasonably well ( and gave results that matched the beginning )
and in this case, the DEC appears to have moved almost as requested ( tho with odd spacings per pulse ).
Whats weird is the RA never came back the full distance ( possibly due to PE )
but the DEC returned to zero well before expected.
It then started guiding in DEC reasonably, but at a set point,
it got a larger error and then swapped into large oscillations.
The 2 interesting bits here are when it went into large oscillations, it also lost the underlying linearity of the DEC drift
almost as if some pulses have got lost????
Looking closely at the oscillations, you can also see that when they start, the pulses sent to fix them
appear to get ignored?? ( ie Kens theory they are being stacked up somewhere )
This stack up error is whaht we saw in the early IOptron firmwares.
Truly weird
Full run showing GA, then DEC lash, then Cal, then guiding
Lash Test
Calibrate
Guiding
DEC wobble
