Let's use a hypothetical 8" dob. If the secondary blocks 25% of the tube, does that mean it would equal a 6 inch refractor with same focal length/ratio and they would have similar views?
Posted 11 April 2018 - 11:27 PM
Posted 11 April 2018 - 11:41 PM
Yes, that's what the guys say in a lot of the posts. However, to buy a 6" refractor with zero chromatic abberation, you are handing over some serious dinero. Reflectors of any size do not have a problem with chromatic abberation. When they do, it is the eyepiece that is at fault. My feeling is, keep your reflector well collimated, use good orthoscopic or high quality eyepieces, and you will get nice crisp images of planets and the Moon. No need to stress out your mastercard buying the massive 6" refractor, and the massive mount and tripod it needs to ride upon.
Posted 12 April 2018 - 01:41 AM
Posted 12 April 2018 - 03:30 AM
Since the blockage is by area then a 25% secondary is down at 6% by area so that makes a significant change.
I would say aperture blocked is almost insignificant, if your secondary blocks 6% then take into account the loss at the 2 reflection surfaces, they are likely to be down at 85% transmission so each mirror throws away 15%, 2 mirrors means 0.852 = 0.72 or 72% gets to the eyepiece. So at the mirrors you have lost 22%, the blockage of the sceondary is getting irrelevant.
That nice 6 element eyepiece = 12 surfaces, even if 1% loss at each surface means 0.9912 = 88% transmission so another 12% has gone.
So transmission at surfaces is now 0.72x0.88 = 0.63 or 63%.
The presumption is that everythiung reflects and transmits at 100% perfection. Except that is wrong and wrong by a lot. So your 6% blockage by the secondary eventually becomes irrelevant. Also the mirror coating is for protection and not for transmission so that is going to be pretty poor.
The above is likely why a good doublet well ant-reflection coated and simple eyepieces TV Plossl and Ortho's have such a following. It is also why you pay a fair chunk extra for the high reflection coatings.
Posted 12 April 2018 - 05:19 AM
That nice 6 element eyepiece = 12 surfaces, even if 1% loss at each surface means 0.9912 = 88% transmission so another 12% has gone. shocked.gif shocked.gif
In general, a 6 element eyepiece may consist of pairs of achromats so there are only 6 air - glass surfaces. And multicoatings can be better than 99% transmission. Tests on Type 6 Nagler eyepieces with 7 elements show the transmission to be in the 95%-96% range.
As far as the original question, the effect of the Newtonian secondary: There is no simple answer to this question. There are three factors to consider, the light throughput, the resolution and the fine scale "planetary" contrast.
-Throughput: As has been discussed, a 25% secondary covers 6.25% of the mirror's area so the light throughput is 94%. One also has to consider the reflective losses of the two mirrors. These numbers vary depending on the type of coating and the coatings age, brand new high quality coatings might be 95%. If one uses 90% which seems like a reasonable number for relatively new coatings, then each mirror transmits 90% of light, the two of the 81%. Multiple the losses together, this means overall throughout is 76%. Compared to a telescope without a secondary and perfect transmisson, this would be the equivalent of a 7.0 inch. A refractor with a dielectric diagonal is quite close to perfect, with a standard diagonal, it would lose about 10%.
- Resolution: The pure resolving power, the ability to resolve a close double star, is unaffected by the central obstruction.
- Fine scale "planetary contrast": This is where things get more complicated. The short story is the secondary obstruction causes a loss of fine scale contrast when viewing the planets. There's a lot of analysis and discussion of the effect of the CO but there are a few generalizations: A CO under 20% has very little effect. There is an old "clear aperture" rule of thumb: Subtract the diameter of the secondary from the aperture and you have the aperture of the equivalent unobstructed (refractor). This is where the 8 inch Newtonian = 6 in refractor comes from.
The long story is this: A objective or mirror does not produce stars that are truly points of light, they produce a dot of light surrounded by a series of faint rings, this is called the Airy disk. The angular diameter of the Airy disk is inversely proportional to the aperture. The greater the aperture, the smaller the disk. This is why larger telescopes have greater resolving power, they produces smaller points. A reasonably analogy is the pixels on your computer monitor or smartphone screen. The smaller the pixels, the greater the resolution. This is an image of the Airy disk:
http://www.rocketmim...lvingPower.html
On steady night, one can see the Airy disk structure at high magnifications. It's easier with smaller telescopes since the disk is larger.
The effect of the secondary mirror is transfer energy from the bright central disk into the diffraction rings. If one thinks of an image as being produced by a series of Airy disks the way your computer screen produces an image, then it can be seen that a dimmer central disk with brighter rings would tend to smear the image of very fine details.
Bottom line: Comparing telescopes of different types is not easy. Many factors come into play, the quality of the optics, the thermal stability of the telescope, the central obstruction, the aperture of the telescope. Far and away, the most important factors are the quality of the optics and the aperture. And of course the cost.
Last year I was privately discussing splitting some close doubles with a fellow Cloudy Nights member on the east coast. He was using a 175mm apochromatic triplet refractor that cost $20,000. I was using a 10 inch (250mm) Dobsonian that I bought used on Astromart 15 years ago for $240. One double in particular I had split cleanly with my $240 scope which had eluded the expensive refractor. This was due to the greater resolving power of the larger aperture and the more stable atmosphere (better seeing) of my location.
Posted 12 April 2018 - 08:31 AM
One other thing to consider.....a typical SCT or newt of 8 inch aperture is a rather pedestrian assemblage. It is good and useful, but would not be considered a premium instrument. It would not be built to tight tolerances but according to the market. It would be a Ford, Chevy, Toyota.
A six inch refractor would probably be a pretty fancy schmancy telescope. Nobody is going to try to get a bargain on that much glass. So, it would be built to very high standards of optics, coatings, and mechanical engineering. It would be a Lincoln, Cadillac, Lexus.
Not necessarily true, of course, but probably.
I would not expect the mass produced SCT or newt to perform as well as the handcrafted refractor.
Alex
Posted 12 April 2018 - 11:54 AM
Alex
Posted 12 April 2018 - 12:20 PM
I don't even think about it or care. It's part of the system. All I care about is that it's clean, has a good coating and is flat. That's about it.
If I want super fine details, I just use an aperture mask and "cheat" the optical system. Tutherwise, not much use worrying about it. If you have any kind of conventional reflector scope, you can't avoid one. Let me be clear, "conventional," not tri-shiefspiegler, if I spelled that right, or tilted whatever.
Posted 12 April 2018 - 12:42 PM
>>>>>> Without it you can't see the image created by the primary.
Sure you can, but the image is degraded by the diffraction spikes caused by your silly old big ears.
Alex
Posted 12 April 2018 - 01:58 PM
Posted 12 April 2018 - 02:04 PM
How about the effect of greater aperture. At some point, the airy disk becomes too
small to see. So central obstruction size is more important with small scopes than big
ones. The question is when is the aperture so big that central obstruction ceases to
matter (besides the small loss in light gathering). Thoughts anyone?
As Jon already mentioned, less than 20% is generally imperceptible.
Posted 12 April 2018 - 02:22 PM
Consider that the image in your eyepiece likely has a ~30-50% brightness drop-off from the center to the edge (yet most people can barely perceive it). Your secondary is a fraction of that (as other said, its like ~6%). So, no, a 6 inch refractor is not like an 8 inch dob because of the secondary. The secondary has a small effect.
Posted 12 April 2018 - 02:58 PM
This refers to low contrast planetary where obstruction effects matter most.How about the effect of greater aperture. At some point, the airy disk becomes too
Posted 12 April 2018 - 03:11 PM
It becomes very challenging to compare different designs and different apertures to arrive at a conclusion about what are similar or equivalent views. Jon covered it well above.
Equivalent or similar are also in the eye of the beholder so aesthetics are a major subjective consideration. Some people find secondary diffraction spikes highly objectionable. Refractors have an advantage in that they can put the most light in the central disk or first diffraction ring. This can make the image appear more crisp. Smaller aperture under greater magnification will have a darker background (smaller exit pupil) compared to larger aperture at the same magnification. Obstructions can soften the image somewhat, as can roughness or various aberrations. The smaller aperture and arrangement of the objective tends to make refractors more forgiving of seeing and thermal equalization--up to a point.
I have tried to do some analysis of different sizes comparing the encircled energy of different obstructions at the same angular distance compared to a refractor to see where things cross. All else being equal the contrast for fine detail of equivalent quality of figure/color correction/etc. seems to be rather close to the adjustment for linear obstruction percentage. This doesn't account for greater image brightness of the larger aperture, or the somewhat greater point source resolution of high contrast areas (e.g. resolving two very close airy disks.) However, it does seem to match some of what I have noticed comparing planetary views through my refractors, SCT, and Dobs. (Now if I just had a 6" ED/apo for comparison...)
One of the more noticeable aspects of the numerical evaluation that seems to carry over to the eyepiece has been the "softness" of planetary images at higher powers in my SCT. Some of this could be roughness or issues with the figure, but the calcs indicate that a surprisingly large remainder of light is spread over a much wider area than for no or low obstruction. For me the result is that even when it was in near perfect seeing it topped out at around 38x/inch, vs. 50x/inch with ED refractors. I have not had the same level of seeing to explore the limits of the 10" Dob (~25% obstruction) but I have had some indication that it is topping out somewhere above 400x for my eye, roughly 42x/inch, maybe a bit more.
As an approximate rule of thumb for planetary detail, subtracting the linear obstruction seems to be a reasonable approximation. It is probably somewhat conservative for evaluating the performance of the obstructed scope with respect to planetary detail, but not dramatically so.
Limiting stellar magnitudes (and DSO's and moons) are a different matter more closely correlated to total system light transmission and effective aperture.
Posted 12 April 2018 - 04:39 PM
Let's assume the primary and secondary of your hypothetical 8" Newt with a 25% CO has enhanced coating on the mirrors that get you 94% reflectivity. On the refractor, let's assume it is a triplet and each air-glass interface (6 of them) have 99% transmission and the diagonal is a 99% reflective dielectric.
Based on the above assumptions a 7.57" refractor would have the same light gathering as the 8" Newt. So not enough of a resolution difference between the two to matter. Of course, you cannot buy a production refractor that is 7.57". But of course you can get a 152mm one quite easily. In that case, a Newtonian would have to be 6.37" to have the same light gathering as the 6.0" refractor.
The views will be different between the two and the character of the view will be different:
With all that said however, when both instruments are fully acclimated with no thermals, and the optics are very clean and well collimated, the views can be quite close (except for the coma and spider vane spikes in the Newtonian).
So generally that "aesthetic" view will be a little harder to attain from the larger aperture Newtonian. With every gain, you have a loss.
Edited by BillP, 12 April 2018 - 04:57 PM.
Posted 12 April 2018 - 04:52 PM
Posted 12 April 2018 - 09:40 PM
That's what I thought the thread would be about as well. Good post.
Posted 13 April 2018 - 02:21 AM
Posted 13 April 2018 - 02:24 AM
Edited by Asbytec, 13 April 2018 - 02:27 AM.
Posted 13 April 2018 - 02:56 AM
Read the first post. This thread was originally in the beginners forum.
Posted 13 April 2018 - 03:05 AM
I think your numbers are optimistic for the Newtonian, pessimistic for the refractor . For example, A-P specs their through put at a minimum of 97%. That's for a triplet , a doublet could be slightly better.
On the other hand Newtonian coatings degrade with time, lens coatings do not. I think that 90% reflectivity is optimistic for a mirror that is not brand new.
Posted 13 April 2018 - 03:37 AM
"Some of this could be roughness or issues with the figure, but the calcs indicate that a surprisingly large remainder of light is spread over a much wider area than for no or low obstruction. For me the result is that even when it was in near perfect seeing it topped out at around 38x/inch, vs. 50x/inch with ED refractors."
Red, that's intetesting. It sounds as if your saying the reduction in peak intensity is partly responsible for image brightness. I've often wondered the same.
Like you, I max out on Jove near 0.6mm exit pupil or 40x/inch. I believe refractors can push a little higher, by all accounts, closer to 0.3mm exit pupil or above 50x/inch.
Discussion like this are fascinating, its great to know how our equipment works. Bottom line is, though, an 8" Newt is a capable scope in it's own right and despite the presence of 6" APOs.
There was a discussion about this a few weeks ago (can't recall where.) From what I recall several of us were talking about the ratio of light outside of X number of diffraction rings vs. the encircled energy within. It starts becoming rather significant at SCT type obstructions. The calcs I have done in the past are derivative from Telescope optics.net central obstruction values--I did some interpolations which are only going to be generally correct rather than truly quantitative for these complex functions since key ones fall precisely midway between their table values.
By the end of the 3rd ring refractors and unobstructed scopes have about 95% of the energy within, and surprisingly short range to that. At 25% C.O. it drops slightly to a little under 94% (0.938) encircled energy and by 35% C.O. it is down to about 92% (0.918). While the numbers don't sound that different, the recovery from there on out is slow so the ratio outside that is a better representation of the degradation of low contrast features. Very roughly the inside/outside ratio past the 3rd ring will be nearly 20:1 for a refractor, and not too far from that with obstructions less than 20%. At 25% the ratio is about 15:1, and by 35% is about 11:1. (Also, this doesn't account for the somewhat slower recovery of all the obstructed apertures in the inner rings.) So I guess one way to think of it is the SCT having far more noise that will reduce lower contrast details when side by side with typical Newt, and more so vs. a refractor. This to me is the essence of the somewhat airbrushed effect I see in all of the SCT's I have viewed through, including my own.
At very low obstructions, such as 15%, the ratio above is a still impressive 18:1.
P.S. I think you meant to type 0.5mm vs. 0.3mm above.
Posted 13 April 2018 - 04:20 AM
Posted 13 April 2018 - 12:01 PM
To follow up a bit on what Jon said in post #5, consider the Orion 8" f5.9 dob. The central obstruction is 47 mm, so the light loss to the obstruction is (47/203)^2 = 5.4 %. The mirror coatings are advertised to be 94% reflective. So, ignoring loss due to the spider vanes, the net throughput efficiency is (1-.054)X0.94^2 = 0.836.
The equivalent aperture is SQRT(0.836)X8" = 7.3". The coatings probably won't remain at 94%, and at some point may deteriorate a few percent, so a conservative estimate would put the equivalent aperture of the Orion 8" f/5.9 dob equal to a 7" aperture with 100% transmission efficiency.
Using the conservative rule of thumb that Jon alluded to, the performance of the 8" dob on subtle planetary detail should be around (203 -47) = 156 mm, that is, about the same as a 6" refractor with good color correction.
Not a bad deal.
Dom Q.
![]() Cloudy Nights LLC Cloudy Nights Sponsor: Astronomics |
