Classic Edmund Astroscan 2001 SERIAL NUMBER REGISTRY -- Add Your Info Here
classic reflector
155 replies to this topic
#151 JSven
JSven
Posted 01 November 2024 - 12:49 PM
I saw an original post about Richard Berry's Using Your Astroscan, did anyone ever get a scanned copy of that? I would love a copy just for my completest sake.
#152 TrackballJerry
TrackballJerry
  • Loc: Eugene, Oregon, USA
Posted 16 November 2024 - 07:24 PM
I just tuned up another Astroscan that was donated to our astronomy club. This one has a round-cornered rectangular yellow label that says "SN: M00639, Made in China" inside the focuser It has a black drawtube. No markings on the plastic around the bolt sockets. The secondary cover in the middle of the glass plate says "Edmund Scientific's" (with apostrophe) in white slightly raised letters curving around the top and "Astroscan" in red taller raised lettering across the center. In tiny raised black letters below that it says "PAT.NO.D247.854" The dust cap has Edmund's stylized "ES" in big raised lettering above the center bar, the word "ASTROSCAN" in what looks like Helvetica or a similar font across the bar, and a smaller repeat of the ES logo plus "Edmund Scientific, Barrington, NJ USA" below the bar. The scope came with the base and a locking bolt, a strap, and a metal peep-sight finder. It's a deeper red than many I've seen, yet the Sun warning sticker on the focuser is faded to near invisibility. No clue when it was purchased, but the Internet says production shifted to China in the early 2000s.
#153 TrackballJerry
TrackballJerry
Posted 24 November 2024 - 01:07 AM
I wound up helping another club member tune up his Astroscan. Here's the data: Serial number 40817 on an orange circle. Black drawtube. "Made in USA" on the plastic around the bolt holes. "Edmund" embossed on the dust cap. No idea when it was purchased.
I learned something interesting about the deteriorating foam issue: The foam under the primary that keeps the primary pushed upward against the retaining ring degrades over time and the primary slumps, ruining its collimation. The traditional solution is to remove the retaining ring, lift out the primary, and replace the foam. But getting that retaining ring out (and back in!) without scratching the mirror is easier said than done. Turns out there's a simpler solution: Reach in with a pianist's long stretch between your middle finger and thumb and grasp the mirror by its edge. Rotate and push down on the mirror. You're tearing it free of the foam and grinding the foam down. The degraded foam is gooey, so it won't turn to dust, but it loses the last of its springiness so now the mirror rests on the bottom of the plastic case rather than being pushed up against the retaining ring. Turns out the case bottom has a circular ring that's just as flat as the retaining ring, so the mirror rests nice and flat. You can put the scope back together and fine-tune the collimation by putting shims under the glass plate, without ever removing the primary mirror. Much safer that way.
#154 TrackballJerry
TrackballJerry
Posted 24 November 2024 - 01:16 AM
Our club has been given several more Astroscans. I'm working on them one at a time to tune them up. Here's the data on the latest:
Serial number: 287386 hand written on a white oval label. There's also a circular blue label with nothing printed on it inside the focuser housing.
The drawtube is black.
There's no "Made in..." embossing on the plastic around the bolt holes.
The cap has "Edmund" embossed in it. Given that this was one of several Astroscans stored together, I wouldn't bet this cap originally came on this scope. Nor the drawtube, for that matter, although that's a bit more likely.
#155 steveincolo
steveincolo
  • Loc: Boulder, Colorado, US
Posted 04 May 2025 - 10:35 AM
Freebie at this years Stellafane swap tables. It was very dirty and missing the primary. The optical window and secondary plus the retainer rings came in a seperate box.  I took it for the dust cover as my yardsale Astroscan was missing the cover. Yellow machine printed label. "SN: M00582" and below that is "MADE IN CHINA".  Black focuser tube. Sun warning label on the focuser. Where the secondary holder attaches to the optical window is marked "Astroscan" in red across the middle with a "TM" over the "n". Below that is "PAT. PEND." Above those around the periphery is "EDMUND SCIENTIFIC CO".  "Barrington, N.J." is at the bottom.
I just picked up the very next one, serial number M00583 (of course also made in China), from a local thrift store.  The optics are in fine shape, but the focuser sticks and skips.  I may try the UHMW tape mentioned in this forum.  It’ll be a fine scope for summer camping.
Edited by steveincolo, 04 May 2025 - 10:35 AM.
#156 astrotorben
astrotorben
Posted 23 May 2025 - 01:31 PM
While appreciating criswille's updation of the registry list, I was also unimpressed with their end run on the forum advertising rules. I may have accepted cookies but did not have to download any of other suggested programs. Nothing bad appeared immediately, but who knows. Having taken whatever hit there was, here is an xlsx and pdf of their Excel file.
attachicon.gif Copia de Edmund Astroscan 2001 Serial Number Registry2.xlsx
attachicon.gif Copia de Edmund Astroscan 2001 Serial Number Registry2.pdf
Is anyone still updating the list(s)?
Clear skies from Denmark
Torben
  • jragsdale likes this
Also tagged with one or more of these keywords: classic, reflector
