Jupiter, Saturn & Mars, May 27-28 UT, Cyprus
19 replies to this topic
#1 Foehammer
Foehammer
  • Loc: Cyprus
Posted 29 May 2018 - 05:17 AM
A night of good seeing.
Jupiter displays a wealth of features, particularly the merging SSTB ovals seen here setting, Saturn with a couple bright spots in the polar region (evident in all subframes although very hard to see here) and of course Mars, at 14.7" with Syrtis Major prominent.
Thanks for looking
Agapios
  • davidmcgo, Deep13, Sunspot and 34 others like this
#2 Conor Maclaud
Conor Maclaud
  • Loc: 07064, NJ.
Posted 29 May 2018 - 05:41 AM
One of the best results I've ever seen with such size of telescope!
#3 Merk
Merk
  • Loc: Cyprus, Nicosia
Posted 29 May 2018 - 05:47 AM
Very nice Agapios, especially Jupiter and Mars!
#4 wargrafix
wargrafix
  • Loc: Trinidad
Posted 29 May 2018 - 07:20 AM
*shuffles feet*
Dannnggggg. I have yet to push my gear to its limits.
The are some gorgeous images! The Mars is the winner
#5 Foehammer
Foehammer
  • Loc: Cyprus
Posted 29 May 2018 - 08:34 AM
Thank you everybody. For these captures, Jupiter was at 39 degress whereas Mars and Saturn at 32 & 31 respectively. The seeing was fair with moments of good (this is about as good as I get for this location) and this was an all-night session. Very enjoyable to observe the major planets with comfortable temperatures and good conditions!
I have more data but as always they will show up later down the line.
#6 Foehammer
Foehammer
  • Loc: Cyprus
Posted 29 May 2018 - 08:37 AM
The C9,25 is a very capable mid-size planetary telescope. This is my 2nd such OTA and visually when the seeing is good the views are amazing! Under excellent seeing I have had incredible results on Jupiter and Mars during the '16 apparitions. I only wonder what it would produce with the planets in Australian or Caribbean seeing/altitudes!
#7 Foehammer
Foehammer
  • Loc: Cyprus
Posted 29 May 2018 - 02:25 PM
Correction: The SSTB ovals are NOT in this data set. I have them registered on previous data which I will upload tomorrow!
#8 Billytk
Billytk
  • Loc: Geneva, Fl.
Posted 29 May 2018 - 03:38 PM
Very nice!
#9 Az Frank
Az Frank
  • Loc: Tucson Arizona
Posted 29 May 2018 - 10:49 PM
Some fine captures Agapios!
#10 CPellier
CPellier
Posted 30 May 2018 - 02:54 AM
Particularily good with superb color rendition, especially Mars.
Edited by CPellier, 30 May 2018 - 02:54 AM.
#11 Quaternion
Quaternion
  • Loc: USA
Posted 30 May 2018 - 04:42 AM
Excellent work. I especially love your Mars image.
Do you have any capture details you can share, in terms of video length, percent stacked, WinJupos or not?
Thanks for any advice you can share.
#12 Foehammer
Foehammer
  • Loc: Cyprus
Posted 30 May 2018 - 05:25 AM
Jupiter: 60sec videos, approx 128fps, 25% stacked. Derotation 12 minutes.
Saturn: 120sec videos, approx 100fps, 15% stacked. Derotation 4 minutes.
Mars: 90sec videos, approx 200fps, 25% stacked. Derotation 16 minutes.
I typically use Firecapture in autorun mode and record series of videos ideally approx 2 hours centered on the transit time of each object. I do this because a) My local seeing is never consistent enough to allow me to choose when to capture. This provides me with a good window of opportunity to catch better seeing even if I'm not glued on the monitor, and b) I really enjoy producing animations from the resulting stacks. Then I use autostakkert batch mode to process the resulting videos accordingly and go through them in Registax with the same wavelet scheme to isolate areas of better seeing. Once those areas are found I might re-stack them with stricter percentage and slightly different wavelet schemes. Then, winjupos to derotate and back to registax for additional wavelet sharpening (very mild, typically only 1 &2 sliders on this stage). Finally, photoshop to correct color balance/saturation and levels adjustments.
#13 Foehammer
Foehammer
  • Loc: Cyprus
Posted 30 May 2018 - 05:34 AM
Here are the animations produced from these data sets.
https://www.agapiose...y-anim_orig.gif
https://www.agapiose...t-anim_orig.gif
https://www.agapiose...rs-gif_orig.gif
  • TorstenEdelmann, John Boudreau, R Botero and 1 other like this
#14 TorstenEdelmann
TorstenEdelmann
  • Loc: Landsberg, Germany
Posted 30 May 2018 - 07:31 AM
Excellent work. Mars is just fantastic !
Torsten
  • Foehammer likes this
#15 Foehammer
Foehammer
  • Loc: Cyprus
Posted 30 May 2018 - 07:35 AM
Torsten
What's fantastic is your capture software! Thank you so much for your comments!
#16 lukasik
lukasik
  • Loc: Dacula, Georgia
Posted 30 May 2018 - 08:48 AM
Fantastic work Agapios!  So good.
#17 sfugardi
sfugardi
  • Loc: MA
Posted 30 May 2018 - 11:38 AM
Agapios, excellent image set! Mars is my favorite of these 3. Details look great all around. Congratulations on these
Steve
#18 AstroDan2015
AstroDan2015
  • Loc: Racine, Wisconsin
Posted 30 May 2018 - 03:00 PM
Hi Agapios,
They are all great!
Yes, I can see twin storms on Saturn as well.
The SPC is so large on Mars that it extends all the way up to and possibly into the very southern edge of the Hellas Asteroid Impact Basin, I don't recall this occurring before.
Speaking of Hellas, it does not look right this season. The CO2 glaciers inside of it should be reflecting sunlight and they are not. Your image shows that it is neither filled with clouds nor fog, so maybe it is dust that is obscuring the sun's light from reflecting off of these glaciers?
They need to redirect the HST in order to see what's going on up there.
Edited by AstroDan2015, 30 May 2018 - 03:01 PM.
#19 R Botero
R Botero
  • Loc: Kent, England
Posted 31 May 2018 - 01:40 AM
Excellent shots but Mars takes the prize :waytogo:
#20 CPellier
CPellier
Posted 31 May 2018 - 01:50 AM
Hi Agapios,
They are all great!
Hi Dan, Mars has passed it southern spring equinox (May 22nd) so Hellas has been free from ice and fog for many weeks already and it's normal :)
The edge of winter SPC is extending onto Hellas every martian year. This year thanks to the season and the geometric viewing from Earth, wee see it clearly.
