SL2/200D or D5300 unmodded
18 replies to this topic
#1 coenie777
coenie777
  • Loc: Pretoria - South Africa
Posted 09 June 2018 - 03:46 PM
Any views on whether the Canon SL2 managed to close the gap on Nikon's D5300 (seeing that it uses the same sensor as the 80D)?
For deepsky, and no current need to stick with Canon, should one get SL2 with more modern processor and chip or stick with the tried and tested D5300? Image comparisons on Dpreview tells me D5300 still has edge:
https://www.dpreview...897566010148793
DxOMark show D5300 clearly ahead of the SL2 in terms of dynamic range and noise:
https://www.dxomark....5300___1171_919
And Photonstophotos also tells the same story.
http://www.photonsto...,Nikon D5300_14
What is the experience under the stars?
#2 dhalgren
dhalgren
  • Loc: New Jersey, USA
Posted 14 June 2018 - 07:02 AM
I have had my SL2 since March and I have been very happy so far. I did not really have an option of going away from Canon, I have too much invested in lenses, T-rings, and the ability to find all the controls by feel in total darkness. grin.gif
#3 coenie777
coenie777
Posted 14 June 2018 - 08:33 AM
Thanks for the reply. Canon has served me very well but I am also wondering what I will be missing. I only have once Canon lens (70-200) so I can afford to make the leap if it means better image quality.
#4 Jerry Lodriguss
Jerry Lodriguss
    Vendor
  • Loc: Voorhees, NJ
Posted 14 June 2018 - 12:27 PM
You need to compare the raw files on the DPReview comparator, and if you do, you will see that there isn't much difference visually with noise in the deepest shadow areas (which is where it counts).
Personally I don't pay any attention to the DXO Mark scores because how they arrive at them is opaque.
Photons to Photons is the one to pay attention to but the numbers in the charts you link to are derived from the DxO data.
Here is another chart showing readout noise at various ISOs comparing the two cameras from Photons to Photons where I think the data is original. This is the one I would pay the most attention to.
It shows the Canon with 3.555 e- of read noise at ISO 200, and the Nikon with 2.732 e-.
That is a little bit of a difference in the Nikon's favor.
Unless you are shooting under exceptionally dark skies with either slow focal ratios or filters, this probably won't make much of a difference.
Between these two cameras, I would pick the one you like the most in terms of the features and ergonomics.
The quality of the long-exposure deepsky images produced with them will almost certainly come down to the photographer's skill and expertise than the camera's technical capabilities.
That said, if you are really serious and plan to shoot calibration frames, the D5300 is kind of weird with flats with some lenses.  And some of the recent Canons have had problems with artifacts from the autofocus pixels. You should research this here on Cloudy Nights where it is documented, if not actually solved.
"One road leads to despair and utter hopelessness and the other to total extinction." Be sure to choose wisely.  Ok, so it's not quite that bad... :-)
Jerry
Edited by Jerry Lodriguss, 14 June 2018 - 12:29 PM.
  • fmeschia likes this
#5 coenie777
coenie777
Posted 15 June 2018 - 02:09 PM
Thanks Jerry, as always a wise word to put it all in perspective.
I have settled on the 200D and look forward to the marked lower noise and higher QE over my current 40D.
#6 dhalgren
dhalgren
Posted 16 June 2018 - 07:46 PM
I took this with my SL2 this morning. It is cropped in Paint Shop Pro directly from the .CR2 and converted to .png, no processing. Orion 80ED, SkyGlow filter, 3 min. ISO 800, Long Exposure Noise Reduction Enabled. I think you will be happy with the SL2, I have been having fun with mine.
#7 carolinaskies
carolinaskies
  • Loc: Greenville SC
Posted 15 August 2018 - 06:55 PM
I picked up an SL2 earlier this year. Due to poor weather since the end of April I haven't done any AP with it.
The difference between the SL2 and 5300 aren't significant in end result.  I give the edge to SL2 for Liveview imaging of planets if that's a main subject.
For a look at performance of the SL2 here is a video I posted on Youtube jumping my ISO up while retaining the same timing.  https://youtu.be/al7E6PVKu7c
#8 Michael Covington
Michael Covington
    Author
  • Loc: Athens, Georgia, USA
Posted 20 August 2018 - 11:18 PM
I have the same question; in particular, whether there are artifacts from the autofocus pixels.  (Surely standard calibration should take care of that.)
I currently have a lot of Canons plus a D5300 (bought because it was such an advance over the Canons at the time it came out).  PhotonsToPhotos tests tell me that the Canon 200D seems to have caught up.  (Jerry points out a slightly higher read noise level at ISO 200, but only slightly.  Photographically, 3.5/2.7 is a factor of 1.3, which is less than 0.4 stop.
So... How well is the 200D serving people in practice?
#9 RichA
RichA
  • Loc: Toronto, Canada
Posted 20 August 2018 - 11:20 PM
All Nikons beat Canons for sensor quality.  Courtesy of Sony.
#10 Michael Covington
Michael Covington
    Author
Posted 20 August 2018 - 11:42 PM
I know the D5300 has a *slight* edge in measured sensor performance, but it is very slight.  I am curious about *other* drawbacks or advantages of the cameras.
Nikon's raw files use a (slightly) lossy compression scheme to store 14-bit values in less than 14 bits.  Canon does not.  In theory, this might produce both better pictures from Canons and worse test results (if the compression masks any of the noise).  But I don't know.
Anyone out there actually using a 200D for astrophotography?  I've looked at the sensor specs.  What I want to know about is actual astrophotographic experience.
Edited by Michael Covington, 20 August 2018 - 11:46 PM.
#11 carolinaskies
carolinaskies
Posted 21 August 2018 - 07:59 AM
The last time I got to use my Canon 200d was months ago before the clouds rain and utterly inconsistent weather settled in this year. I have been pleased with its performance up to that point for an unmodified camera.
Part of the reason of course for choosing the 200d Canon was for the live view capture ability which is superior to the Nikon. The early reports and comparisons of chips show that the 200 d while being the new cheapest entry by Canon into the AP SC class and having the rotatable screen have performance extremely close to that of the 5300.
I'm on my mobile phone right now so I don't have access to my pictures but I know that there's a couple of threads on here where I did share them.
Depending on how you intend to shoe weather with a higher ISO and shorter time frame or a lower ISO on a higher time frame I think the Canon is a good DSLR for the money features and performance.
Since now we are using software to do stacking and image manipulation the differences between the various models is becoming less of a concern as long as the performance is similar enough.
And recently I know that when I checked the companies who are doing the mods for astrophotography have included the 200d which wasn't the case 6 months ago.
I haven't dug around the web recently even on Astro been to check for 200 D photos but maybe that's something I'll have to do to see if I can find someone who's had better opportunity that I to do some shooting with their 200d.
#12 Michael Covington
Michael Covington
    Author
Posted 21 August 2018 - 09:07 AM
Thanks.  The biggest concern that I have is whether the special pixels that are used for focusing leave any artifacts in the picture.  On the other thread, someone has said that Canon sensors have traditionally suffered more self-heating than Nikon, but we don't know if that is still the case.  Of course I would like to know about fixed-pattern noise too.
#13 coenie777
coenie777
Posted 22 August 2018 - 02:44 PM
Just an update since my post #5;
I bought a D5300 in the end. So unfortunately I cannot assist with any SL2 images. Since I went from an old 40D to the 5300 there is no real comparison I can make in terms of image quality. One thing I am missing is the much smaller file size of my 40D with the resultant faster downloads. But such is the price of advancement I guess.
Would still love to see some side by side comparisons between SL2 and 5300. I will gladly provide test data if anyone with knowledge of what to do with it needs it.
#14 SandyHouTex
SandyHouTex
  • Loc: Houston, Texas, USA
Posted 25 August 2018 - 09:32 AM
Except that cameras are systems and not just a sensor.  Depending on the philosophy of the manufacturer, once the sensor takes the image, it is then manipulated in certain ways before the camera outputs it.
  • Michael Covington likes this
#15 Michael Covington
Michael Covington
    Author
Posted 25 August 2018 - 09:17 PM
We all know the D5300 is an excellent camera, about as good as any DSLR money can buy right now for astrophotography (except that it's unmodified and some others have bigger sensors and electronic first curtain shutter).
We want to know whether the 200D is perceptibly worse or indistinguishable.
In favor of Canon: a more consistent product line, lossless compression of the raw file, and electronic first curtain shutter (as I understand it, under the rubric of Silent Shooting).
So I'd really like to see some 200D astrophotos.
#16 ccs_hello
ccs_hello
Posted 25 August 2018 - 09:47 PM
Try this
P.S., there is no iso invariant test side-by-side so I have to resort to studio image comparison,,,
#17 ccs_hello
ccs_hello
Posted 25 August 2018 - 09:48 PM
ISO6400
#18 Traveler
Traveler
  • Loc: The Netherlands
Posted 26 August 2018 - 01:41 AM
Also not pro Nikon D5300/5500: the Liveview is not that good as liveview from Canon.
#19 Alen K
Alen K
Posted 26 August 2018 - 08:49 AM
Although I have nothing to offer Michael's quest for actual astrophotos with the 200D, it certainly does have an attractive set of specs for AP and an attractive price. If the sensor is an evolution of that in the 80D then it seems likely that it would perform at least as well (semi-ISO-less). (It is slightly smaller so not actually the same sensor.) One consideration if it is to remain unmodded is that the Nikons seem to have somewhat better sensitivity to Halpha (and the Pentax models also using Sony sensors a little better still, FWIW). Canon's have always been a little lacking in that respect and really do need to be modified for most emission nebula.
