Jupiter 09/06/2018 [DSLR]
5 replies to this topic
#1 SunBlack
SunBlack
  • Loc: Rome (IT)
Posted 09 June 2018 - 06:04 PM
Last night 05/06/2018 at 22.30h LT with a Canon 6D mod, stack of 215 exps from a video 1:1 5x Live View captured by EOS Camera Movie Record , 1/30s 400iso on a Celestron C8. Eyepiece projection with a Celestron zoom 8-24mm set at 16mm. Crop and PP in Registax 2 e Paint Shop X7
Edited by SunBlack, 10 June 2018 - 10:13 AM.
  • Starman27, starcam, psandelle and 10 others like this
#2 AKHalea
AKHalea
  • Loc: Houston, Texas, USA
Posted 10 June 2018 - 02:16 PM
Wow! That came out real nice with the GRS taking almost center stage! Well done ..... Anil
  • JerryWise likes this
#3 RedLionNJ
RedLionNJ
  • Loc: Red Lion, NJ, USA
Posted 10 July 2018 - 07:35 PM
That eyepiece doesn't appear to be doing terribly much in the way of increasing the f-ratio.  You may be better off with a 2x or 2.5x Barlow or PowerMate.
This is promising, though.  Include more frames in the stack, too.
#4 BQ Octantis
BQ Octantis
  • Loc: Outback NT, Australia
Posted 12 July 2018 - 10:18 PM
Beautiful color contrast, but the entire disk looks a bit onion-y (which I typically only get on the limb). This comes from not enough dynamic range in the stack, and 215 frames seems like a very low number…have you tried increasing the stack? I typically do 1000 input (Live View .mp4) frames per processed output frame. This is because I can stack 100 seconds of frames without smearing due to planet rotation, and I only get ~10 fps from my Canon T3i through AstroDSLR. The stack is certainly blurrier, but also more tolerant to stronger sharpening methods; I then derotate 2-5 processed frames in Photoshop (so 2000-5000 frames total), which further cleans up any lingering artifacts (e.g., onion, edge-rind, shot noise). The output from my stacker is 16-bits per channel, and I do all processing at 16 bits between Gimp and Photoshop. Are you processing at 16-bits?
Separately, you can use a much shorter focal length on Jupiter through an 8" SCT—it's plenty bright,so you can trade some SNR/shot noise for more pixels across the disk. I use orthoscopic eyepieces vice a zoom, and I use the shortest focal length that lets Jupiter practically fill the entire frame at 5x Live View. For my Jupiter shots on 6 July through my 7" Cass-Mak (2700mm f/15), I used a 12.5mm eyepiece. Here's the 1000-frame stack from a 100-second Live-View .mp4:
which is highly tolerant to sharpening:
which I then derotated and combined with two other output frames, resharpened, and scaled to acceptable acutance:
With an 8", you should get at least as many pixels across Jupiter as my 7" (seeing notwithstanding).
If you're not happy with the output, you can always scale down; at least then all the artifacts are smaller than the pixel resolution:
BQ
Edited by BQ Octantis, 12 July 2018 - 10:38 PM.
  • Moonwalker1968 likes this
#5 SunBlack
SunBlack
  • Loc: Rome (IT)
Posted 13 July 2018 - 01:26 AM
in my recent jupiter works posted in this forum i eliminated onion rings artifact
#6 SandyHouTex
SandyHouTex
Posted 14 July 2018 - 09:20 AM
That’s an excellent Jupiter pic.  Nice work.
