STC optical multispectra filter
7 replies to this topic
#1 suvowner
suvowner
  • Loc: Arkansas
Posted 13 June 2018 - 12:19 PM
anyone tried or have thoughts how well this filter would work for eaa or even regular nebulae imaging with a osc camera ??
would this be good enough to get close to narrow band imaging without having to get new mono camera and narrowband filters ??
https://stcoptics.com/en/astro/
https://www.cyclopso...spectra-filter/
STC Astro Multispectra filter is a general-purpose light pollution suppression filter designed to use with DSLRs cameras. It will effectively reduce the interference from artificial lighting, such as mercury and sodium street light, yet allow the important nebula emission lines to pass, thus enhancing the contrast of astronomical objects. Supporting by Dr. Wei-Hao Wang, it is improved to passing more than 95% of the light from the main spectral lines from emission nebula, such as the predominant Hydrogen-Alpha line at 656.3nm, the Oxygen III line at 495.9 & 500.7nm, and the Hydrogen-Beta line at 486.1nm. It is coated by the use of the IBAD (Ion beam-assisted deposition) technology on SchottĀ® B270 optical glass, working for higher durability and easily cleaning. Since light pollution and airglow are filtered out with ASTRO filter, much more of the interesting wavelengths of the deep-sky object will be recorded in these longer exposures.
https://www.youtube....h?v=iI0z2i7wfj0  (around 4:30 he gets to the stc optical booth)
Edited by suvowner, 13 June 2018 - 02:19 PM.
#2 nic35
nic35
Posted 13 June 2018 - 01:57 PM
It is definitely not a narrow band filter - or anything close.  Its a general purpose Light Pollution filter - with reduced transmissivity in the IR beyond about 700nm compared to say a Astronomik CLS (non CCD).
I'm not at all sure how good it is.  I recommend starting into filters with this topic:  https://www.cloudyni...-2?hl= optolong
It leads to many useful resources.
john
#3 suvowner
suvowner
  • Loc: Arkansas
Posted 13 June 2018 - 02:44 PM
Idas light pollution filter on the top and the stc on the bottom, they look pretty close to me. I have an LPS-D1, so it looks to me as if the Lps-D2 and the multi-spectra are very close, The only thing to gain over the lps D1 might be SII ??
  • fff68512fc9861eace1a6c514bf7b7ef_e88f7650-6416-4a82-8a6c-af06c52be162_590x590.jpg
Edited by suvowner, 13 June 2018 - 02:45 PM.
#4 ccs_hello
ccs_hello
Posted 13 June 2018 - 05:29 PM
IMHO, there is not too much a point for nick picking.
If need to purchase today, I'd go for a reasonable priced LPR which has the right thread size for your needs.
The reason is that, more and more LED based lighting are being deployed to replace the classic, power-hungry street lights.
AFAIK, LED lights are broadband and LPR filter to such illumination will no longer be effective.  Call it the progress.
  • roelb likes this
#5 suvowner
suvowner
  • Loc: Arkansas
Posted 13 June 2018 - 05:49 PM
i dont have any significant led in my area for now, but i think idas has a new p2 filter that does block led pollution
#6 ccs_hello
ccs_hello
Posted 13 June 2018 - 06:56 PM
Some idas LPS discussions
https://www.cloudyni...s-d1-vs-lps-p2/
#7 lakerunr
lakerunr
  • Loc: WI
Posted 26 November 2018 - 09:04 PM
I've got one of these, a 48mm STC Astro Multi-Spectra that screws into the flattener on my WO Z73 APO. Have used it with my Nikon D750 stock DSLR. Seems to help block some light pollution, but adds a horrendous blue cast to images (NEF). The higher ISO, the worse. At 1600, the un-processed histogram of the color channels shows red and green in left third plot, and blue almost to right border. Takes a lot of color balance tuning to get colors aligned in order to do any decent processing. I have got some  decent images with it, but the blue tinted subs are not confidence-inspiring. I will try to do some with/without filter imaging same object/conditions when I get a chance for purposes of a fair comparison.
I don't know of any reason why using the filter in the flattener would be any different than using a clip-in version.
#8 lakerunr
lakerunr
  • Loc: WI
Posted 29 December 2018 - 11:45 PM
Follow-up: I got a gray card and set up a custom white balance for using this filter through the flattener. Now histogram looks normal. Been getting pretty good results, but some star bloat and diffraction ring on brighter stars. Not sure this is due to filter, but will re-shoot the targets exhibiting the issue w/o filter at earliest opportunity.
