Comparing the 18mm UFFs and 17.5mm Morpheus eyepieces
18 replies to this topic
#1 Mr. Bill
Mr. Bill
  • Loc: Northeastern Cal
Posted 13 June 2018 - 02:52 PM
Another good night with SQM 21.5+ skies starting at 12:30 AM.
Spent two hours comparing views of same MW objects using first the 17.5mm Morpheus and then the 18mm UFFs in my Lunt/APM 100mm APOs.
Contrast and image sharpness was to my eyes the same which is to say excellent and same number of stars in each noted in open clusters, so they both get high points. No apparent coma or astigmatism noted in either. Eye relief and ease of eye placement similar with a nod to the UFFs for my eyes....YMMV.
Big difference was the apparent fov, 65 degrees for the UFFs and 76 degrees for the Morpheus.
In a nutshell, if you like big immersive views with a moderate amount of field curvature 80% out from on axis, the Morpheus are your choice.
OTOH, if you want a really flat field almost to the fieldstop with just a touch of field curvature at the edge and don't mind the smaller apparent fov, the UFFs are it.
Edited by Mr. Bill, 13 June 2018 - 02:53 PM.
  • jdown, havasman, Xeroid and 2 others like this
#2 nicoledoula
nicoledoula
Posted 13 June 2018 - 04:00 PM
And if wider fields are ones thing, buying EP's that are better corrected than the Morpheus isn't out of the question.
#3 GamesForOne
GamesForOne
  • Loc: Knoxville, TN
Posted 13 June 2018 - 04:11 PM
What options would that include for 1.25" barrel size of > 17mm focal length?
I have a Pentax XW20 pair and it displays considerable field curvature in the binos at the field edges.
Michael Mc
#4 Mr. Bill
Mr. Bill
Posted 13 June 2018 - 04:23 PM
IMO, field curvature is inherent in the binocular objectives and the Morpheus' larger apparent fov shows it up more.
I believe that the APM UFFs were designed around the APM BTs to minimize field curvature at the eyepiece; that's why they are included with APM's BT binoculars.
Someone that has an APO telescope with a known flat field and the 17.5mm Morpheus would be able to test  the amount of field curvature in the ep.
Edited by Mr. Bill, 13 June 2018 - 08:40 PM.
#5 Nightfly
Nightfly
  • Loc: Dark Skies, Maine
Posted 13 June 2018 - 04:55 PM
I can attest to the small amount of FC with the 18mm UFF's and excellent on-axis performance in the Orion BT100.  Contrast is superb as well.
I was checking out Barnard 142/143 and these eyepieces framed it very well.  These dark nebulae filled the field with wonderful sharpness and contrast.  Surpassed the photos.
If these EP's were built around the binocular, the rest of the series should be grand as well.  The 24's are pending......
#6 starzonesteve
starzonesteve
Posted 13 June 2018 - 04:59 PM
The 24’s are spectacular in my APM 120mm
#7 duck2k
duck2k
  • Loc: Fountain Hills, AZ
Posted 13 June 2018 - 05:05 PM
I enjoyed the wider field of the Morpheus 17.5
the 18 UFF have a narrower field, but the targets are
no less beautiful.
while I have many eyepieces for my APM’s (and they are all good), the
17.5, 12.5 Morpheus, and my APM 24 mm UFF remain in my eyepiece
Edited by duck2k, 13 June 2018 - 05:07 PM.
  • Moravianus likes this
#8 GrahamDFyffe
GrahamDFyffe
  • Loc: Central Arizona
Posted 13 June 2018 - 11:19 PM
I love the APM 24’s in my new Oberwerk BT 100 XL’s. Did I hear some rumor about APM bringing out a 90° eyepiece?
  • duck2k likes this
#9 wargentin
wargentin
  • Loc: France
Posted 25 June 2018 - 06:54 PM
I've received a pair of APM UFFs 18mm. With my APM 100 ED APO, I can see easily field curvature. In fact, the last 20 or 25% of the field are blurry. It is possible to focus stars near the fieldstop, but then the center of the field is blurry.
In this regard, they are clearly inferior to my Televue eyepieces (24 Pans, 13T6) which are sharp almost to the fieldstop, with zero field curvature.
On the other hand, for terrestrial observations, the 24 Pans have way too much distortion, and I don't like them for daytime. The APM UFFs 18 have only a hint of pincushion distortion, and I find them much more enjoyable for daytime.
Apart from the fact that they are NOT ultra-flat, I think these APM eyepieces are excellent.
#10 GamesForOne
GamesForOne
Posted 25 June 2018 - 08:12 PM
Blurry in the last 25%? Wow, everyone's eyes are different. I sure don't see that in my APM 100 90-deg APOs.
Michael Mc
#11 Mr. Bill
Mr. Bill
Posted 25 June 2018 - 08:35 PM
Michael Mc
+1......I see mild field curvature the last 10-15% in my Lunt/APM 100 APOs
Edited by Mr. Bill, 25 June 2018 - 08:37 PM.
#12 wargentin
wargentin
  • Loc: France
Posted 27 June 2018 - 05:50 PM
I should have said "slightly blurry", or "not as perfect as the Panoptics". smile.gif
Last night I tried the APM UFF on my 120/900 ED refractor: the field curvature was barely perceptible at the edge.
Then I tested the APM on my XT10g with a Paracorr Type I: there was a slight astigmatism near the fieldstop, but I can't say I saw field curvature. So it has probably a flat field.
With the 24 Pan on the same scope, I could detect a slight field curvature, but the curvature is inverted: the focuser must be moved outwards to achieve the best image near the fieldstop. I had never noticed that before!
My guess is that the 24 Pan has field curvature, whose convexity points towards the eyepiece, and which matches perfectly the field curvature of the APM binoculars.
I am more and more impressed by the 24 Pan…
#13 Beg
Beg
  • Loc: Bear River, CO
Posted 06 November 2018 - 02:16 AM
I'm not impressed at all with the 24 Pans in my binos. Excessive curvature to the point of being annoying. The 17.5 Morpheus just can't be beat. The 18 UFF are really nice, but I think the Morpheus are something special as a total package with eye relief, fov, and general comfort and sharpness.
Edited by Beg, 06 November 2018 - 02:17 AM.
#14 denis0007dl
denis0007dl
    Binoviewers Expert
  • Loc: Umag, Croatia, Europe
Posted 06 November 2018 - 01:20 PM
I dont like Pans as well becasue too strong curvate + too short eye releaf.
I like much better APM 24mm UFFs, I can recommend them to you for try.
Much more comfortable, flatter, more impressive view, cheaper.
  • Beg and duck2k like this
#15 duck2k
duck2k
Posted 06 November 2018 - 04:25 PM
+1
#16 Beg
Beg
Posted 06 November 2018 - 04:49 PM
 Denis,
Why do the 24 pans work well in the binoviewers, as well as being one of the highest rated ep's out there, and then work not so well in the BT's. ???  Focal ratio?
Edited by Beg, 06 November 2018 - 04:54 PM.
#17 duck2k
duck2k
Posted 07 November 2018 - 12:31 AM
The APM 24mm UFF is 65 degree field (Pan is 68), and it removes the curvature of the field from the edge resulting in a less distorted flatter view. The Pans give about 15mm eye relief, where the APM gives about 20mm eye relief.  This is why I enjoy the APM 24mm.
APM have great flat field eyepieces (even the 15mm was impressive to me).  I have both the 18mm, and the 17.5mm Morphs.  While I love flat field, sometimes that 76 degree view spoils me.  Very close in my opinion of both.
Edited by duck2k, 07 November 2018 - 12:34 AM.
  • Beg and Mr. Bill like this
#18 Mr. Bill
Mr. Bill
Posted 07 November 2018 - 02:01 PM
IMO, the APM UFFs were designed around cancelling out most of the normal FC in the APM BTs....
I don't notice any difference between the Pans and the UFFs in real or apparent fov.
The big deal for me is the greater eye relief and eye placement comfort of the UFFs.
  • GamesForOne and duck2k like this
#19 Tamiji Homma
Tamiji Homma
  • Loc: California, USA
Posted 07 November 2018 - 04:10 PM
When I measured TFOV difference  between Panoptic 24 and APM UFF 24,
APM UFF 24 had about 1% wider TFOV than Panoptic 24.
Unless you measure it, you wouldn't notice :)
Panoptic 24 field stop 27.05mm
APM UFF 24 field stop 27.32mm
Tammy
  • Mr. Bill and GamesForOne like this
