Lunt solar wedge used at around F/6?
4 replies to this topic
#1 CHASLX200
CHASLX200
  • Loc: Tampa area Florida
Posted 14 June 2018 - 05:26 AM
Bought a TMB 105/650 and wonder if it would be ok to use my 1.25" Lunt solar wedge?
#2 rigel123
rigel123
  • Loc: SW Ohio
Posted 14 June 2018 - 05:57 AM
I would call Lunt since you are on the edge of what they recommend (4" and under) for that wedge.  For 6" and under they recommend the 2" on their website.
#3 nicknacknock
nicknacknock
    A man of many qualities, even if they are mostly bad ones
  • Loc: Nicosia, Cyprus
Posted 14 June 2018 - 05:58 AM
Would be just fine, but unfortunately, nothing much to observe in white light these days :shrug:
Recommend this site to quickly check for any sunspots. You are in luck actually, there IS something to observe now :)
#4 nicknacknock
nicknacknock
Posted 14 June 2018 - 06:00 AM
The wedge should have a ND filter installed but the image is still too bright. A polarizing filter threaded to the eyepiece will allow you to control the amount of light since the diagonal acts as the second part of the polarizing effect - just rotate the eyepiece to get to the brightness you prefer.
#5 CHASLX200
CHASLX200
Posted 14 June 2018 - 06:03 AM
 I have a moon filter that helped a lot when i used it in a AT102 ED at F/7..  The TMB is so sharp so it would be a fun solar scope once more spots start showing up. One day things will start to heat up again.
