QHY183M under Ubuntu Mate does not download/displays images
2 replies to this topic
#1 anwenet
anwenet
Posted 18 June 2018 - 12:42 AM
I am having issue with downloading images from the camera QHY183 mono, running on Ubuntu Mate.
Tried to change cables, powered USB 3 and 2 hubs.
Is it something to do with firmware upload?
Let me know if you need any more information.
Here is an output from Ubuntu syslog:
Jun 18 00:46:27 anwenet-desktop kernel: [ 48.985485] usb 1-1.3: new high-speed USB device number 4 using ehci-pci
Jun 18 00:46:27 anwenet-desktop kernel: [ 49.095104] usb 1-1.3: New USB device found, idVendor=1618, idProduct=c183
Jun 18 00:46:27 anwenet-desktop kernel: [ 49.095111] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
Jun 18 00:46:27 anwenet-desktop kernel: [ 49.095115] usb 1-1.3: Product: WestBridge
Jun 18 00:46:27 anwenet-desktop kernel: [ 49.095119] usb 1-1.3: Manufacturer: Cypress
Jun 18 00:46:27 anwenet-desktop kernel: [ 49.095122] usb 1-1.3: SerialNumber: 0000000004BE
Jun 18 00:46:27 anwenet-desktop mtp-probe: checking bus 1, device 4: "/sys/devices/pci0000:00/0000:00:1d.0/usb1/1-1/1-1.3"
Jun 18 00:46:27 anwenet-desktop mtp-probe: bus: 1, device: 4 was not an MTP device
Jun 18 00:46:27 anwenet-desktop systemd-udevd[2879]: Process '/sbin/fxload -t fx3 -I /usr/local/lib/qhy/firmware/QHY183.img -D /dev/bus/usb/001/004' failed with exit code 185.
Jun 18 00:46:27 anwenet-desktop kernel: [ 49.167167] usb 1-1.3: usbfs: USBDEVFS_CONTROL failed cmd fxload rqt 64 rq 160 len 4096 ret -71
Jun 18 00:46:27 anwenet-desktop systemd-udevd[2879]: Process '/sbin/fxload -t fx3 -I /usr/local/lib/qhy/firmware/QHY183.img -D ' failed with exit code 255.
Jun 18 00:46:27 anwenet-desktop upowerd[1780]: unhandled action 'bind' on /sys/devices/pci0000:00/0000:00:1d.0/usb1/1-1/1-1.3
Jun 18 00:46:28 anwenet-desktop kernel: [ 49.272939] usb 1-1.3: USB disconnect, device number 4
Jun 18 00:46:28 anwenet-desktop upowerd[1780]: unhandled action 'unbind' on /sys/devices/pci0000:00/0000:00:1d.0/usb1/1-1/1-1.3
Jun 18 00:46:28 anwenet-desktop kernel: [ 49.497321] usb 1-1.3: new high-speed USB device number 5 using ehci-pci
Jun 18 00:46:28 anwenet-desktop kernel: [ 49.612991] usb 1-1.3: New USB device found, idVendor=1618, idProduct=c184
Jun 18 00:46:28 anwenet-desktop kernel: [ 49.612998] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
Jun 18 00:46:28 anwenet-desktop kernel: [ 49.613002] usb 1-1.3: Product: Q183-Cool
Jun 18 00:46:28 anwenet-desktop kernel: [ 49.613005] usb 1-1.3: Manufacturer: QHYCCD
Jun 18 00:46:28 anwenet-desktop mtp-probe: checking bus 1, device 5: "/sys/devices/pci0000:00/0000:00:1d.0/usb1/1-1/1-1.3"
Jun 18 00:46:28 anwenet-desktop mtp-probe: bus: 1, device: 5 was not an MTP device
Jun 18 00:46:28 anwenet-desktop upowerd[1780]: unhandled action 'bind' on /sys/devices/pci0000:00/0000:00:1d.0/usb1/1-1/1-1.3
Here is output from ./SingleFrameMode
SingleFrameMode, Version: 1.10
Press any key to start test application...
SDK resources initialized.
Idx: 1, OpenQHYCCD QHY183M-227bea45a63f9f4d6 success.
SetQHYCCDStreamMode set to: 0, success.
InitQHYCCD success.
GetQHYCCDOverScanArea:
Overscan Area startX x startY : 0 x 0
Overscan Area sizeX x sizeY : 0 x 0
GetQHYCCDEffectiveArea:
Effective Area startX x startY: 0 x 0
Effective Area sizeX x sizeY : 0 x 0
GetQHYCCDChipInfo:
Chip size width x height : 13.306 x 8.842 [mm]
Pixel size width x height : 2.400 x 2.400 [um]
Image size width x height : 5544 x 3684
This is a mono camera.
SetQHYCCDParam CONTROL_USBTRAFFIC set to: 10, success.
SetQHYCCDParam CONTROL_GAIN set to: 10, success
SetQHYCCDParam CONTROL_OFFSET set to: 140, success.
SetQHYCCDParam CONTROL_EXPOSURE [us] set to: 20000, success.
SetQHYCCDResolution roiStartX x roiStartY : 0 x 0, success.
SetQHYCCDResolution roiSizeX x roiSizeY : 5544 x 3684, success.
SetQHYCCDBinMode set to: binX: 1, binY: 1, success.
SetQHYCCDParam CONTROL_TRANSFERBIT set to: 10, success.
ExpQHYCCDSingleFrame(pCamHandle) - start...
ExpQHYCCDSingleFrame(pCamHandle) - end...
ExpQHYCCDSingleFrame success.
Will try to allocate 61272288 [uchar] data array for image.
SetQHYCCDParam CONTROL_EXPOSURE set to: 20000 [us], success.
Allocated data array of 61272288 [uchar].
#2 k4xtt
k4xtt
Posted 18 June 2018 - 03:27 AM
Running Linux Mate here also on big desktop system.  I have never plugging in a camera to it yet, always used windows laptop.  Will try this system and see what I get.
The lines:
"Jun 18 00:46:27 anwenet-desktop systemd-udevd[2879]: Process '/sbin/fxload -t fx3 -I /usr/local/lib/qhy/firmware/QHY183.img -D /dev/bus/usb/001/004' failed with exit code 185.
and
Jun 18 00:46:27 anwenet-desktop systemd-udevd[2879]: Process '/sbin/fxload -t fx3 -I /usr/local/lib/qhy/firmware/QHY183.img -D ' failed with exit code 255."
indicate problems and I don't know how to fix that right off the top of my head.
Stay tuned.
k4xtt
#3 astrosoft
astrosoft
  • Loc: Czech Republic, Europe
Posted 19 June 2018 - 12:15 PM
Hi all,
we will release a new version of our Linux/Mac drivers as well as TSX's X2 drivers for both OS.
The QHY183M is working now, but still have to fix another problem with longer exposures which still
produces bad images. I work on that hard, so please be patient. Sorry, for such delays and problems.
Thank you,
Jan
  • ccs_hello likes this
