Hooked on small scopes
332 replies to this topic
#1 contrailmaker
contrailmaker
Posted 20 June 2018 - 10:10 AM
I re-discovered how much fun a small telescope can be after buying my TV60 earlier this year. I had just had cervical surgery and was limited to lifting 10 lb. The whole rig weights in at about 7 lb including the tripod and it’s given me great views of the constellations and planets. It will soon serve mostly as a travel scope. I was so impressed by the views it delivers and by the quality of Televue scopes that I recently acquired this beautiful TV76 for the days when the seeing doesn’t justify setting up the larger scopes at my place (the TV60 is at a different location).  It will also allow me to use a binoviewer as is my preference. Can’t wait for first light. But, the new telescope curse is in full swing over here.
 I very much doubt this will be my last small refractor.
CM
Edited by contrailmaker, 20 June 2018 - 12:56 PM.
  • CollinofAlabama, Scott Beith, paulsky and 41 others like this
#2 db2005
db2005
  • Loc: Living in Denmark, under Bortle 5 skies.
Posted 20 June 2018 - 10:39 AM
Congrats on a very nice scope set up! In my opinion small refractors are frequently underrated (maybe not in this forum...), but in my experience they are absolutely perfect for getting out under the skies quickly and making the best use of observing opportunities. A small high-quality refractor under the skies shows more than a monster scope packed away in the garage. My personal favourite small APO is the Vixen SD81S: light, portable, and just enough aperture to be quite useful on Moon, planets, clusters, double stars and even bright DSOs. Perfect for grab-and-go astronomy.
Seriously, every observer should own a 3-inch class APO...
  • Scott Beith, doctordub, GlenM and 18 others like this
#3 GamesForOne
GamesForOne
  • Loc: Knoxville, TN
Posted 20 June 2018 - 11:23 AM
Even better: Try two together -- one for each eye!
Edited by GamesForOne, 20 June 2018 - 11:42 AM.
  • Scott Beith, contrailmaker and db2005 like this
#4 Garyth64
Garyth64
  • Loc: SE Michigan
Posted 20 June 2018 - 11:29 AM
Be careful, anyone with more little scope is nuts.
  • Scott Beith, Sarkikos, Castor and 1 other like this
#5 IMB
IMB
    APM Telescopes Vendor Affiliate
  • Vendor Affiliate
Posted 20 June 2018 - 11:33 AM
<...> Seriously, every observer should own a 3-inch class APO...
Absolutely! These instruments are so versatile and pleasure to use.
Even though I own a pretty good 120 mm telescope, I still observe much more with my 72 mm.
  • Sarkikos, Castor, contrailmaker and 2 others like this
#6 Sarkikos
Sarkikos
  • Loc: Per sylvam ad astra
Posted 20 June 2018 - 11:52 AM
"Hooked on Small Scopes."  So am I.  Look at my sig.  I guess I'm nuts, too!
Edited by Sarkikos, 20 June 2018 - 11:53 AM.
  • Jaimo!, Castor, contrailmaker and 6 others like this
#7 RAKing
RAKing
  • Loc: West of the D.C. Nebula
Posted 20 June 2018 - 12:06 PM
It's wonderful that there are so many great choices out there that allow us to enjoy our hobby to the best of our physical and fiscal abilities.
Ron
(former cervical fusion patient)
  • Castor, contrailmaker and rogeriomagellan like this
#8 contrailmaker
contrailmaker
Posted 20 June 2018 - 12:54 PM
Ron
Thanks! I’m already cleared to go back to work.
That Vixen SD81S was very tempting. But, the chance of acquiring the kindly used TV76 at a good price won out. Give me a couple of minutes and I’ll think of a good reason to buy the Vixen anyway.grin.gif
CM
  • Castor and mikeDnight like this
#9 kmparsons
kmparsons
  • Loc: Texas
Posted 20 June 2018 - 12:55 PM
I just purchased the smallest scope I have ever gotten, the Astro-Tech 60mm f/6 FPL-53 doublet. The scope is a beauty. Everything about it says "quality." Of course, we are having a week of rain and heavy clouds in SE Texas. Can't wait to try it out! I plan to use it as a travel scope, so can anyone recommend a small but sturdy tripod that can fit into carry-on luggage? Thanks!
  • Alterf, Sarkikos, Castor and 2 others like this
#10 RAKing
RAKing
Posted 20 June 2018 - 12:59 PM
That Vixen is a very nice scope.  I am sure you will enjoy it, too. waytogo.gif
I have been recovering from a second spinal fusion since February.  Lifting restrictions are a PITA - or maybe I should say a pain in the back (or neck in your case).  I can now handle about 20 pounds, but going over that is risky.
The little TV scopes are modern day classics in my book.  I am sure you will love that little 76.
Ron
#11 contrailmaker
contrailmaker
Posted 20 June 2018 - 01:10 PM
I’m using the Manfrotto compact advanced with quick release plate for my TV60. There are other compact models in the Manfrotto line. They make good quality mount/tripods.
CM
  • Sarkikos, Castor and IMB like this
#12 kmparsons
kmparsons
  • Loc: Texas
Posted 20 June 2018 - 01:13 PM
Thanks. I have been thinking along the lines of Manfrotto. I would really like something with an extendable head that I could crank up or down.
  • Sarkikos likes this
#13 contrailmaker
contrailmaker
Ron
What a coincidence, mine was on February 12.
All I can say is that as much as it has been a pain recovering from the surgery, it sure was a lot worse before. Get well soon!
CM
  • RAKing likes this
#14 Erik Bakker
Erik Bakker
  • Loc: Netherlands, Europe
Posted 20 June 2018 - 01:14 PM
I am hooked on small and light high quality refractors too. They are so easy to get out and observing with, day and night. I've owned a couple of them from the very light Celestron FL 55S to the substantial Zeiss AS 80/840 and a few in-between. Found the ones with the best combination of views, convenience, portability and user friendliness unsurpassed. Those with great optics and a weight with mount and eyepiece under 6 kg are my favorites. The lighter, the better. Aperture around 3" is an optimum for me too.
  • Sarkikos, Castor, contrailmaker and 3 others like this
#15 clearwaterdave
clearwaterdave
  • Loc: Western Maine
Posted 20 June 2018 - 01:47 PM
Mine are not ED or apo's but I enjoy them very much both in the day and night time. If I ever see an apo/ed nearby and for a good price I may bite.,but for now my small inexpensive frac's are doing a good job of keeping me busy and smiling.,waytogo.gif
  • CollinofAlabama, Scott Beith, Jon Isaacs and 6 others like this
#16 desertlens
desertlens
  • Loc: 36°N 105°W
Posted 20 June 2018 - 01:50 PM
I have scopes up to an 8" SCT but my most used is probably an SV80ST which stays mounted for unexpected opportunities. Several nights ago I was able to see the entire Veil nebula with a Borg 55FL, a 25mm Abbe and an OIII filter (very cool!). Small refractors are much underrated and maybe I'm just lazy :).
  • RAKing, Castor, contrailmaker and 2 others like this
#17 Jon Isaacs
Posted 20 June 2018 - 03:15 PM
I enjoy observing with small scopes .  I've owned a number of scopes 80 mm and under including this 60 mm F/7 Parks-Carton.
But i settled on 80 mm as being just right.. Currently I have four , a Celestron 80 mm F/5 fitted with a 2 inch William Optics focuser,  an AT-80LE (F/6, FPL-53), an WO Megrez II FD (F/7,FPL53) and Meade 310, the 80 mm F/11 manufactured by Mizar. .
  • CollinofAlabama, Vesper818, mattyfatz and 15 others like this
#18 Tyson M
Tyson M
  • Loc: Canada
Posted 20 June 2018 - 04:37 PM
I absolutely love small scopes. I have the perfect 80mm now , but I'm somewhat afraid to travel with it because it is a triplet and I am afraid of knocking it out of collimation, perhaps irrationally.
Now I may be looking for another small 80mm scope that fits in my photo backpack for travel.
  • rogeriomagellan and IMB like this
#19 Sarkikos
Sarkikos
Posted 21 June 2018 - 05:54 AM
Extendable heads/columns are a great feature, especially for refractors, which have a wide range in eyepiece height between zenith and horizon.  You can extend the column instead of shifting your chair up and down, or standing up and sitting back down.
Another benefit of an extendable column is that you don't have to bring out a cumbersome and heavy astro-chair.  All you need is a light, adjustable camping stool.  You can sling one of those across your shoulders as you take the scope and mount outside.  https://www.camptime...rd-roll-a-stool
Edited by Sarkikos, 21 June 2018 - 05:57 AM.
  • CollinofAlabama, Vesper818, Erik Bakker and 3 others like this
#20 rerun
rerun
Posted 21 June 2018 - 10:22 AM
A very fine scope your new TV60 , Congratulations. I am hooked by small refractors. Yesterday I made a short observation of the moon. I had to go up early in the morning for work. But for a short view on the moon the litte FOA60 is great. I used my williams bino with 20mm williams eyepices and enjoyed the  half  hour viewing the moon. It takes no time to built it up and the fun is great. I sleeped very well after this observation.
Thats why I love little scopes so much.
Clear skies Markus
  • paulsky, elwaine, Lewis Cason and 13 others like this
#21 russell23
russell23
  • Loc: Upstate NY
Posted 21 June 2018 - 11:40 AM
I just picked up a Williams Optics Z61 as a nice wide TFOV scope and travel scope.  At home I have a nice table top tripod for it but I’m going to need something for travel.
So far I’ve only had a chance to look at the Moon with it one evening.  Zero CA at 106x in the twilight sky.  Sometime this summer I will get a chance to really test it as a widefield scope.
  • paulsky, Vesper818, Alterf and 13 others like this
#22 Bomber Bob
Bomber Bob
  • Loc: The Swamp, USA
Posted 21 June 2018 - 11:49 AM
Cute, Classic, & CA-free:  my 1960 Swift Model 838 sports a 50mm F14 lens by Takahashi, a cable-less GEM, and with a Vixen 36mm adapter uses 1.25" accessories.
It's the lightest equatorial grab & go that I have.  Views are super sharp -- even in the rinky-dinky finder.
  • Vesper818, Lewis Cason, m9x18 and 15 others like this
#23 Erik Bakker
Erik Bakker
Like Markus, I observed the first quarter moon last night. Around dusk. At 25-75x. A stunning sight in my smallest scope and favorite grab-n-go, a 82mm ED. Especially at 30x and 2.4 degrees, the sight was breathtaking with numerous craters, mountains, ridges, subtle and stark albedo features. Meanwhile the earthshine gently glowing, the moon hanging silently in the spacious field of a still bluish sky.
  • mattyfatz, Lewis Cason, m9x18 and 11 others like this
#24 Blueox4
Blueox4
  • Loc: Upstate New York
Posted 21 June 2018 - 12:09 PM
I haven’t had my bigger refractor out since I picked up this little gem. The ES 92 17mm eyepiece is hard to balance on my mount but I was floored by the viewing last night.
  • stevew, Erik Bakker, mattyfatz and 15 others like this
#25 jay.i
jay.i
  • Loc: Minneapolis, MN
Posted 21 June 2018 - 12:55 PM
  • Vesper818, Erik Bakker, Moondust and 14 others like this
